查看: 7338|回复: 45
申请了阿里云测试VPS,大家帮忙访问看看性能
发表于 2011-12-31 20:53:53 | 只看该作者
移动速度也是非常犀利
发表于 2011-12-31 20:53:36 | 只看该作者
电信速度很快
 楼主| 发表于 2011-12-31 20:50:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
昨天申请了阿里云的测试VPS,今天接到阿里云mm的电话,后来发了邀请码给我,可以测试7天,网站刚架好,大家帮忙访问看看效果。
网站:http://42.120.40.62
探针:http://42.120.40.62/p.php
Unix Bench跑完了,分数如下:
Benchmark Run: Sat Dec 31 2011 20:24:00 - 20:52:02
2 CPUs in system; running 1 parallel copy of tests
Dhrystone 2 using register variables       10900933.3 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     2136.6 MWIPS (10.2 s, 7 samples)
Execl Throughput                               3424.0 lps   (29.9 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        361954.4 KBps  (30.1 s, 2 samples)
File Copy 256 bufsize 500 maxblocks           96307.0 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks       1085888.1 KBps  (30.1 s, 2 samples)
Pipe Throughput                              548618.0 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 109980.2 lps   (10.0 s, 7 samples)
Process Creation                              11505.0 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   5745.0 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   1278.9 lpm   (60.0 s, 2 samples)
System Call Overhead                         768654.7 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   10900933.3    934.1
Double-Precision Whetstone                       55.0       2136.6    388.5
Execl Throughput                                 43.0       3424.0    796.3
File Copy 1024 bufsize 2000 maxblocks          3960.0     361954.4    914.0
File Copy 256 bufsize 500 maxblocks            1655.0      96307.0    581.9
File Copy 4096 bufsize 8000 maxblocks          5800.0    1085888.1   1872.2
Pipe Throughput                               12440.0     548618.0    441.0
Pipe-based Context Switching                   4000.0     109980.2    275.0
Process Creation                                126.0      11505.0    913.1
Shell Scripts (1 concurrent)                     42.4       5745.0   1354.9
Shell Scripts (8 concurrent)                      6.0       1278.9   2131.5
System Call Overhead                          15000.0     768654.7    512.4
System Benchmarks Index Score                                         775.3
Benchmark Run: Sat Dec 31 2011 20:52:02 - 21:20:08
2 CPUs in system; running 2 parallel copies of tests
Dhrystone 2 using register variables       21239925.0 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     4275.8 MWIPS (10.2 s, 7 samples)
Execl Throughput                               6810.6 lps   (29.8 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        111238.3 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks           30365.9 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks        301978.9 KBps  (30.1 s, 2 samples)
Pipe Throughput                             1069454.4 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 381158.4 lps   (10.0 s, 7 samples)
Process Creation                              21193.5 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   8935.2 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   1351.8 lpm   (60.1 s, 2 samples)
System Call Overhead                        1374327.1 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   21239925.0   1820.0
Double-Precision Whetstone                       55.0       4275.8    777.4
Execl Throughput                                 43.0       6810.6   1583.9
File Copy 1024 bufsize 2000 maxblocks          3960.0     111238.3    280.9
File Copy 256 bufsize 500 maxblocks            1655.0      30365.9    183.5
File Copy 4096 bufsize 8000 maxblocks          5800.0     301978.9    520.7
Pipe Throughput                               12440.0    1069454.4    859.7
Pipe-based Context Switching                   4000.0     381158.4    952.9
Process Creation                                126.0      21193.5   1682.0
Shell Scripts (1 concurrent)                     42.4       8935.2   2107.3
Shell Scripts (8 concurrent)                      6.0       1351.8   2253.1
System Call Overhead                          15000.0    1374327.1    916.2
System Benchmarks Index Score                                         918.5
参与人数 2威望 +12 收起 理由
laoma348 + 10 亲,求加分~~
robin123 + 2 很给力!
发表于 2011-12-31 20:51:09 来自手机 | 只看该作者
移动表示速度不错
发表于 2011-12-31 20:52:43 | 只看该作者
看簽名吧...
发表于 2011-12-31 20:51:59 | 只看该作者
VPS.NET..
 楼主| 发表于 2011-12-31 20:52:02 | 只看该作者
ali727 发表于 2011-12-31 20:51
移动表示速度不错
我电信访问蛮快的,不过价格也是不便宜啊,299一个月。。。
发表于 2011-12-31 20:52:31 | 只看该作者
联通表示杠杠的
 楼主| 发表于 2011-12-31 20:58:32 | 只看该作者
zzzu 发表于 2011-12-31 20:52
联通表示杠杠的
看来一分钱一分货真不假啊,这个299一个月
发表于 2011-12-31 20:58:51 | 只看该作者
GMT+8, 2026-4-14 22:26 , Processed in 0.085112 second(s), 12 queries , Gzip On, MemCache On.
