楼主: oldghost
申请了阿里云测试VPS,大家帮忙访问看看性能
 楼主| 发表于 2011-12-31 21:15:15 | 只看该作者
ericls 发表于 2011-12-31 21:12
比景安那个号
是的,价格差了几倍啊。。。
22#
 楼主| 发表于 2011-12-31 21:21:04 | 只看该作者
Unix Bench跑完了,分数如下:
Benchmark Run: Sat Dec 31 2011 20:24:00 - 20:52:02
2 CPUs in system; running 1 parallel copy of tests
Dhrystone 2 using register variables       10900933.3 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     2136.6 MWIPS (10.2 s, 7 samples)
Execl Throughput                               3424.0 lps   (29.9 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        361954.4 KBps  (30.1 s, 2 samples)
File Copy 256 bufsize 500 maxblocks           96307.0 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks       1085888.1 KBps  (30.1 s, 2 samples)
Pipe Throughput                              548618.0 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 109980.2 lps   (10.0 s, 7 samples)
Process Creation                              11505.0 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   5745.0 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   1278.9 lpm   (60.0 s, 2 samples)
System Call Overhead                         768654.7 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   10900933.3    934.1
Double-Precision Whetstone                       55.0       2136.6    388.5
Execl Throughput                                 43.0       3424.0    796.3
File Copy 1024 bufsize 2000 maxblocks          3960.0     361954.4    914.0
File Copy 256 bufsize 500 maxblocks            1655.0      96307.0    581.9
File Copy 4096 bufsize 8000 maxblocks          5800.0    1085888.1   1872.2
Pipe Throughput                               12440.0     548618.0    441.0
Pipe-based Context Switching                   4000.0     109980.2    275.0
Process Creation                                126.0      11505.0    913.1
Shell Scripts (1 concurrent)                     42.4       5745.0   1354.9
Shell Scripts (8 concurrent)                      6.0       1278.9   2131.5
System Call Overhead                          15000.0     768654.7    512.4
System Benchmarks Index Score                                         775.3
Benchmark Run: Sat Dec 31 2011 20:52:02 - 21:20:08
2 CPUs in system; running 2 parallel copies of tests
Dhrystone 2 using register variables       21239925.0 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     4275.8 MWIPS (10.2 s, 7 samples)
Execl Throughput                               6810.6 lps   (29.8 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        111238.3 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks           30365.9 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks        301978.9 KBps  (30.1 s, 2 samples)
Pipe Throughput                             1069454.4 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 381158.4 lps   (10.0 s, 7 samples)
Process Creation                              21193.5 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   8935.2 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   1351.8 lpm   (60.1 s, 2 samples)
System Call Overhead                        1374327.1 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   21239925.0   1820.0
Double-Precision Whetstone                       55.0       4275.8    777.4
Execl Throughput                                 43.0       6810.6   1583.9
File Copy 1024 bufsize 2000 maxblocks          3960.0     111238.3    280.9
File Copy 256 bufsize 500 maxblocks            1655.0      30365.9    183.5
File Copy 4096 bufsize 8000 maxblocks          5800.0     301978.9    520.7
Pipe Throughput                               12440.0    1069454.4    859.7
Pipe-based Context Switching                   4000.0     381158.4    952.9
Process Creation                                126.0      21193.5   1682.0
Shell Scripts (1 concurrent)                     42.4       8935.2   2107.3
Shell Scripts (8 concurrent)                      6.0       1351.8   2253.1
System Call Overhead                          15000.0    1374327.1    916.2
System Benchmarks Index Score                                         918.5
23#
发表于 2011-12-31 21:28:28 | 只看该作者
路过表示支持了.......
24#
 楼主| 发表于 2011-12-31 21:43:39 | 只看该作者
Kokgog 发表于 2011-12-31 21:36
试下这个 http://s3.amazonaws.com/geekbench/Geekbench-2.2.3-Linux.tar.gz
这个要怎么下参数啊?
25#
发表于 2011-12-31 21:35:19 | 只看该作者
看你是玩还是买了
买肯定要选性价比高的
26#
 楼主| 发表于 2011-12-31 21:42:54 | 只看该作者
Captain 发表于 2011-12-31 21:35
还你是玩还是买了
买肯定要选性价比高的
只是玩玩看,太贵了
27#
发表于 2011-12-31 21:36:56 | 只看该作者
28#
 楼主| 发表于 2011-12-31 21:50:26 | 只看该作者
[root@AY111231031554aaf1af2 Geekbench-2.2.3-Linux]# ./geekbench_x86_32 --help
./geekbench_x86_32: /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by ./geekbench_x86_32)
出错了,少了文件,要怎么处理
29#
发表于 2011-12-31 21:51:17 | 只看该作者
oldghost 发表于 2011-12-31 21:43
这个要怎么下参数啊?
先解压
64位执行 ./dist/Geekbench-2.2.3-Linux/geekbench_x86_64
32位,执行./dist/Geekbench-2.2.3-Linux/geekbench_x86_32
阿里云应该是64位吧,测试完之后可以提交到web页
30#
 楼主| 发表于 2011-12-31 22:02:12 | 只看该作者
Kokgog 发表于 2011-12-31 21:51
先解压
32位,执行./dist/Geekbench-2.2.3-Lin ...
是32位的,我32,64都执行了,还是不行啊
GMT+8, 2026-4-15 12:28 , Processed in 0.067346 second(s), 6 queries , Gzip On, MemCache On.
