查看: 5202|回复: 22
linode的Benchmarks
发表于 2009-11-18 15:11:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
一直忘记跑了,所以今天想起来,还是跑跑看看,2个node都跑了,fremont81m,fremont92
----------81--------------
   BYTE UNIX Benchmarks (Version 5.1.2)
   System: li92-250.members.linode.com: GNU/Linux
   OS: GNU/Linux -- 2.6.18.8-linode22 -- #1 SMP Tue Nov 10 16:12:12 UTC 2009
   Machine: i686 (i386)
   Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
   CPU 0: Intel(R) Xeon(R) CPU L5420 @ 2.50GHz (5004.4 bogomips)
          Hyper-Threading, MMX, Physical Address Ext
   CPU 1: Intel(R) Xeon(R) CPU L5420 @ 2.50GHz (5004.4 bogomips)
   CPU 2: Intel(R) Xeon(R) CPU L5420 @ 2.50GHz (5004.4 bogomips)
   CPU 3: Intel(R) Xeon(R) CPU L5420 @ 2.50GHz (5004.4 bogomips)
   06:06:46 up 11 min,  1 user,  load average: 0.00, 0.04, 0.05; runlevel 3
Benchmark Run: Wed Nov 18 2009 06:06:46 - 06:34:46
4 CPUs in system; running 1 parallel copy of tests
Dhrystone 2 using register variables       10072093.4 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     2271.3 MWIPS (10.2 s, 7 samples)
Execl Throughput                               1693.9 lps   (29.9 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        380063.9 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks          107935.0 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks        817774.0 KBps  (30.0 s, 2 samples)
Pipe Throughput                              642227.0 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                  80329.2 lps   (10.0 s, 7 samples)
Process Creation                               3980.2 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   4147.7 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   1260.8 lpm   (60.1 s, 2 samples)
System Call Overhead                         495168.6 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   10072093.4    863.1
Double-Precision Whetstone                       55.0       2271.3    413.0
Execl Throughput                                 43.0       1693.9    393.9
File Copy 1024 bufsize 2000 maxblocks          3960.0     380063.9    959.8
File Copy 256 bufsize 500 maxblocks            1655.0     107935.0    652.2
File Copy 4096 bufsize 8000 maxblocks          5800.0     817774.0   1410.0
Pipe Throughput                               12440.0     642227.0    516.3
Pipe-based Context Switching                   4000.0      80329.2    200.8
Process Creation                                126.0       3980.2    315.9
Shell Scripts (1 concurrent)                     42.4       4147.7    978.2
Shell Scripts (8 concurrent)                      6.0       1260.8   2101.3
System Call Overhead                          15000.0     495168.6    330.1
System Benchmarks Index Score                                         611.9
 楼主| 发表于 2009-11-18 15:11:46 | 只看该作者
Benchmark Run: Wed Nov 18 2009 06:34:46 - 07:02:54
4 CPUs in system; running 4 parallel copies of tests
Dhrystone 2 using register variables       39676402.6 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     9027.8 MWIPS (10.1 s, 7 samples)
Execl Throughput                               6334.9 lps   (29.9 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        245239.3 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks           66833.7 KBps  (30.1 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks        564078.8 KBps  (30.0 s, 2 samples)
Pipe Throughput                             2523648.3 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 435423.0 lps   (10.0 s, 7 samples)
Process Creation                              12108.9 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                  10253.7 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   1505.4 lpm   (60.1 s, 2 samples)
System Call Overhead                        1567171.0 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   39676402.6   3399.9
Double-Precision Whetstone                       55.0       9027.8   1641.4
Execl Throughput                                 43.0       6334.9   1473.2
File Copy 1024 bufsize 2000 maxblocks          3960.0     245239.3    619.3
File Copy 256 bufsize 500 maxblocks            1655.0      66833.7    403.8
File Copy 4096 bufsize 8000 maxblocks          5800.0     564078.8    972.5
Pipe Throughput                               12440.0    2523648.3   2028.7
Pipe-based Context Switching                   4000.0     435423.0   1088.6
Process Creation                                126.0      12108.9    961.0
Shell Scripts (1 concurrent)                     42.4      10253.7   2418.3
Shell Scripts (8 concurrent)                      6.0       1505.4   2509.0
System Call Overhead                          15000.0    1567171.0   1044.8
System Benchmarks Index Score                                        1315.7
 楼主| 发表于 2009-11-18 15:12:34 | 只看该作者
92号
-----------92--------------
   System: li93-35: GNU/Linux
   CPU 0: Intel(R) Xeon(R) CPU L5420 @ 2.50GHz (5004.9 bogomips)
   CPU 1: Intel(R) Xeon(R) CPU L5420 @ 2.50GHz (5004.9 bogomips)
   CPU 2: Intel(R) Xeon(R) CPU L5420 @ 2.50GHz (5004.9 bogomips)
   CPU 3: Intel(R) Xeon(R) CPU L5420 @ 2.50GHz (5004.9 bogomips)
   06:12:19 up 1 min,  1 user,  load average: 0.27, 0.10, 0.03; runlevel 3
Benchmark Run: Wed Nov 18 2009 06:12:19 - 06:40:17
Dhrystone 2 using register variables       10085656.0 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     2238.1 MWIPS (10.2 s, 7 samples)
Execl Throughput                               1709.8 lps   (29.9 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        388303.4 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks          109023.4 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks        832475.0 KBps  (30.0 s, 2 samples)
Pipe Throughput                              647235.0 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                  88610.4 lps   (10.0 s, 7 samples)
Process Creation                               4222.6 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   4194.3 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   1294.9 lpm   (60.0 s, 2 samples)
System Call Overhead                         498596.8 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   10085656.0    864.2
Double-Precision Whetstone                       55.0       2238.1    406.9
Execl Throughput                                 43.0       1709.8    397.6
File Copy 1024 bufsize 2000 maxblocks          3960.0     388303.4    980.6
File Copy 256 bufsize 500 maxblocks            1655.0     109023.4    658.8
File Copy 4096 bufsize 8000 maxblocks          5800.0     832475.0   1435.3
Pipe Throughput                               12440.0     647235.0    520.3
Pipe-based Context Switching                   4000.0      88610.4    221.5
Process Creation                                126.0       4222.6    335.1
Shell Scripts (1 concurrent)                     42.4       4194.3    989.2
Shell Scripts (8 concurrent)                      6.0       1294.9   2158.2
System Call Overhead                          15000.0     498596.8    332.4
System Benchmarks Index Score                                         625.0
 楼主| 发表于 2009-11-18 15:12:45 | 只看该作者
Benchmark Run: Wed Nov 18 2009 06:40:17 - 07:08:18
Dhrystone 2 using register variables       40119431.1 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     9010.6 MWIPS (10.2 s, 7 samples)
Execl Throughput                               6396.7 lps   (29.9 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        244074.2 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks           63611.4 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks        652377.3 KBps  (30.0 s, 2 samples)
Pipe Throughput                             2541760.8 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 439369.0 lps   (10.0 s, 7 samples)
Process Creation                              12348.8 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                  10572.1 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   1572.1 lpm   (60.1 s, 2 samples)
System Call Overhead                        1606445.2 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   40119431.1   3437.8
Double-Precision Whetstone                       55.0       9010.6   1638.3
Execl Throughput                                 43.0       6396.7   1487.6
File Copy 1024 bufsize 2000 maxblocks          3960.0     244074.2    616.3
File Copy 256 bufsize 500 maxblocks            1655.0      63611.4    384.4
File Copy 4096 bufsize 8000 maxblocks          5800.0     652377.3   1124.8
Pipe Throughput                               12440.0    2541760.8   2043.2
Pipe-based Context Switching                   4000.0     439369.0   1098.4
Process Creation                                126.0      12348.8    980.1
Shell Scripts (1 concurrent)                     42.4      10572.1   2493.4
Shell Scripts (8 concurrent)                      6.0       1572.1   2620.1
System Call Overhead                          15000.0    1606445.2   1071.0
System Benchmarks Index Score                                        1342.8
发表于 2009-11-18 15:13:03 | 只看该作者
分数不错哦
发表于 2009-11-18 15:21:56 | 只看该作者
Benchmarks? UnixBench?
发表于 2009-11-18 15:26:04 | 只看该作者
回复 6# 的帖子
看到个 UNIX Benchmarks (Version 5.1.2)
发表于 2009-11-18 15:27:18 | 只看该作者
回复 7# 的帖子
UNIX Benchmarks 简称 UnixBench?
 楼主| 发表于 2009-11-18 15:32:52 | 只看该作者
http://www.hermit.org/Linux/Benchmarking/
软件叫unixbench
打出来的分数叫System Benchmarks Index Score,可能是我简称的不正确。
发表于 2009-11-18 15:37:36 | 只看该作者
回复 8# 的帖子
是的,不过版本很多,分数也不一样。
GMT+8, 2026-4-24 21:00 , Processed in 0.074211 second(s), 10 queries , Gzip On, MemCache On.
