查看: 7697|回复: 26
W4 Networks 新讯息
发表于 2009-11-16 16:44:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
As some of you may (or may not of) noticed, your old VPS control panel is no longer functional. The new location of the panel is ' http://my.w4networks.com '. We have just finished importing clients from our Kansas City, MO (VPS IPs starting with 204.*) location. After importing, we had to manually view each individual account which was imported to verify proper client information and package plan on each VPS. Several changes had to be made a long the way and we are asking you to PLEASE log in to the new panel to verify all information so we can clear up any discrepancies which may exist. Your login for the new panel is your VPS hostname and password. If you are unsure if your VPS hostname, you can login to your billing center (currently located at: http://support.w4networks.com/whmcs/ ) and view your service product details (http://support.w4networks.com/wh ... tion=productdetails). Once logging into ' http://my.w4networks.com ' and verifying all information, there is no need to contact us. If you notice something wrong with the information, please submit a ticket! Please note, that we currently do not have any operating system reloading template currently available. We first working to get all customers properly imported into the new control panel. Scranton, PA clients (VPS IPs starting with 64.* / 66.* / 96.*), we hope to have you up and running on the new panel very soon. We are waiting for verification on our IP Blocks at this location and want to verify the importing went smoothly from our Kansas City, MO location. Once the import takes place and we verify and correct the data, another notification email will be sent out. I would like to thank everyone for their patience in this time of transition. The mess from previous ownership as been very frustrating for both us and our customers. We are working very hard to get everything running smoothly (how it should be) to make sure everyone has a great experience hosting with us. As always, if you have any questions, comments or suggestions, please submit a ticket! Thanks, Nick C. W4 Networks http://www.w4networks.com/
大致上的意思是:
1.旧面版失效,新面版在 http://my.w4networks.com ,登入帐号:hostname 密码应是原来密码,密码忘了也可重新索取密码。
2.刚完成引进 (204头)的Kansas City, MO 的 vps,要大家进入新面版核对你的vps内容,是否正确?
3.貌似将来会更换ip。
先不要re-install,不然会无法访问?!
我有重启(REBOOT)过,没任何问题。
[ 本帖最后由 DrrX 于 2009-11-16 17:14 编辑 ]
发表于 2009-11-16 16:44:55 | 只看该作者
发表于 2009-11-16 16:47:27 | 只看该作者
他们换solusvm了
用你的帐号登录 my.w4networks.com 看看所有的信息是不是对的
[ 本帖最后由 pigicoffee 于 2009-11-16 16:49 编辑 ]
发表于 2009-11-16 19:11:04 | 只看该作者
回复 3# 的帖子
过渡期,最好备份数据
发表于 2009-11-17 00:42:26 | 只看该作者
我是这样的,先re-install  arch linux 0.8 i686 .. 直接挂掉..
然后再re-install Cent OS 5 i386 ..没用。。
只好发Tikect给支持人员...顺便要他给我开下TUN。
客服后来回信问我,是说否尝试安装64位版本的OS,说他这只能安装32位的...
我无语,然后我将我安装步骤详细讲了一遍他听,并要求他给我装Cent OS 5 i386 .
刚刚给我装好,我看了下,居然又装成Cent OS5 (FULL)还是有许多我不想的要的东西 。。现在也不敢重装了。。只好慢慢卸载...然后试了下TUN。。没装.....
PS:刚才VPS又被重启了,可能我太急了些,没事就ping通不通...通了就SSH。。。
发表于 2009-11-17 00:44:46 | 只看该作者
哈哈。在/dev/net/里看到tun了,估计客服正在给我装...
刚去看了一眼,VPS又重启了..又被客服T出来了..
发表于 2009-11-17 00:46:32 | 只看该作者
W4的VPS挺不错的
发表于 2009-11-17 01:00:48 | 只看该作者
发表于 2009-11-17 01:05:23 | 只看该作者
 楼主| 发表于 2009-11-17 01:08:02 | 只看该作者
回复 5# 的帖子
听起来,似乎服务有进步,值得继续关注!
GMT+8, 2026-4-24 18:15 , Processed in 0.064669 second(s), 10 queries , Gzip On, MemCache On.
