楼主: DrrX
W4 Networks 新讯息
发表于 2009-11-17 12:44:21 | 只看该作者
原帖由 MaYi 于 2009-11-17 00:44 发表
哈哈。在/dev/net/里看到tun了,估计客服正在给我装...
刚去看了一眼,VPS又重启了..又被客服T出来了..
  那可以搞VPN了。
发表于 2009-11-17 22:58:13 | 只看该作者
回复 11# 的帖子
能在看到/dev/net/tun设备了。
不过
modprobe tun
FATAL: Could not load /lib/modules/2.6.18-128.2.1.el5.028stab064.8PAE/modules.dep: No such file or directory
我看了下lib/moudels目录下是空的
不知道这样是否可以VPN,暂时还没有时间研究
W4的服务现在还真不错了。
看看他的语气老诚恳的
ME:
I tried to install the Arch Linux 0.8 i686 to vps , but it can not start, and then I tried to install CentOS5 i386 to it , it can not start also ...
I have seen in the control panel vps 's disk space is 0KB...
Pls help me re-install the CentOS 5 i386 to my VPS.
and can you enable the tun moudle to my vps ?
Thanks and Regards ..
W4:
Apologies for the delay. We had to rebuild your account and also re-do a template file.
The reason your VPS stats show 0KB in the control panel is because your VPS was not running and actually was destroyed I believe when you attempted to install arch linux twice in a short period of time before the last build was completed installing.
I went ahead and completely re-built your VPS, with CentOS 5 i386. I also setup tun and updated all the packages to the newest versions. Let me know if you have any more issues!
On a side note, we are going to be going through all our templates and customizing them for our use. I currently pulled all the templates down, since a few did not come with proper packages needed and some came bloated with too many packages.
Thanks,
Nick C.
W4 Networks
http://www.w4networks.com
发表于 2009-11-18 11:22:02 | 只看该作者
回复 12# 的帖子
modprobe tun
就是无法加载的意思吧,还是得母机设置了。
发表于 2009-11-18 11:49:52 | 只看该作者
W4 整个母机包括 官网都挂了....
难道在改IP?
发表于 2009-11-18 12:02:08 | 只看该作者
回复 14# 的帖子
不是要换到burst.net 机房么?
 楼主| 发表于 2009-11-18 18:57:11 | 只看该作者
恢复了,vps的ip不变。
发表于 2009-11-18 19:07:16 | 只看该作者
原帖由 DrrX 于 2009-11-18 18:57 发表
恢复了,vps的ip不变。
好消息
 楼主| 发表于 2009-11-18 19:16:27 | 只看该作者
W4 的 solusVM 的控制面板的 IP 在 Scranton ,而 VPS 的 IP 仍在 Kansas City。
发表于 2009-11-18 19:49:48 | 只看该作者
原帖由 DrrX 于 2009-11-18 19:16 发表
还是你说对了,只是换了控制面板服务器。
20#
 楼主| 发表于 2009-11-18 21:50:27 | 只看该作者
回复 19# 的帖子
我发ticket问了,结果如何?我会来回复。
GMT+8, 2026-4-25 12:45 , Processed in 0.064937 second(s), 9 queries , Gzip On, MemCache On.
