查看: 5103|回复: 15
[疑问] VD独服是新机器?
发表于 2011-3-18 22:39:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
VD独服是新机器吗,是的话他们也太舍得了。
戴尔的机器。
System Information
        Manufacturer: Dell Inc.
        Product Name: PowerEdge R210
Intel的CPU。
Processor Information
        Socket Designation: CPU1
        Type: Central Processor
        Family: Xeon
        Manufacturer: Intel
        ID: E5 06 01 00 FF FB EB BF
        Signature: Type 0, Family 6, Model 30, Stepping 5
        Flags:
                FPU (Floating-point unit on-chip)
                VME (Virtual mode extension)
                DE (Debugging extension)
                PSE (Page size extension)
                TSC (Time stamp counter)
                MSR (Model specific registers)
                PAE (Physical address extension)
                MCE (Machine check exception)
                CX8 (CMPXCHG8 instruction supported)
                APIC (On-chip APIC hardware supported)
                SEP (Fast system call)
                MTRR (Memory type range registers)
                PGE (Page global enable)
                MCA (Machine check architecture)
                CMOV (Conditional move instruction supported)
                PAT (Page attribute table)
                PSE-36 (36-bit page size extension)
                CLFSH (CLFLUSH instruction supported)
                DS (Debug store)
                ACPI (ACPI supported)
                MMX (MMX technology supported)
                FXSR (Fast floating-point save and restore)
                SSE (Streaming SIMD extensions)
                SSE2 (Streaming SIMD extensions 2)
                SS (Self-snoop)
                HTT (Hyper-threading technology)
                TM (Thermal monitor supported)
                PBE (Pending break enabled)
        Version: Intel(R) Xeon(R) CPU           X3450  @ 2.67GHz
        Voltage: 1.2 V
        External Clock: 4800 MHz
        Max Speed: 3600 MHz
        Current Speed: 2666 MHz
        Status: Populated, Enabled
        Upgrade: Socket LGA1366
        L1 Cache Handle: 0x0700
        L2 Cache Handle: 0x0701
        L3 Cache Handle: 0x0702
        Serial Number: Not Specified
        Asset Tag: Not Specified
        Part Number: Not Specified
        Core Count: 4
        Core Enabled: 4
        Thread Count: 8
        Characteristics:
                64-bit capable
三星的硬盘,才用了10多个小时。
=== START OF INFORMATION SECTION ===
Device Model:     SAMSUNG HE253GJ
Serial Number:    S2B5J90B102230
Firmware Version: 1AJ30001
User Capacity:    250,000,000,000 bytes
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   8
ATA Standard is:  Not recognized. Minor revision code: 0x28
Local Time is:    Fri Mar 18 04:35:52 2011 EDT
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       15
发表于 2011-3-18 22:40:34 | 只看该作者
我没买,我后悔了.........
发表于 2011-3-18 22:41:00 | 只看该作者
不过想想买了没用可能更后悔......
参与人数 1威望 +20 收起 理由
我是人 + 20 买了送人就不会后悔了。。。
发表于 2011-3-18 22:41:22 | 只看该作者
我没买到
发表于 2011-3-18 22:41:44 | 只看该作者
不是说是二手的
发表于 2011-3-18 22:42:54 | 只看该作者
LZ运气真好
发表于 2011-3-18 22:43:11 | 只看该作者
听说是二手?
发表于 2011-3-18 22:50:10 | 只看该作者
发表于 2011-3-18 22:56:29 | 只看该作者
发表于 2011-3-18 23:08:17 | 只看该作者
硬盘不好忽悠,所以是新的吧
而且硬盘不贵
再说了那容量的就得比新的还难找
所以
呵呵
GMT+8, 2026-4-22 18:08 , Processed in 0.071581 second(s), 11 queries , Gzip On, MemCache On.
