12
返回列表 发新帖
楼主: Porter
[疑问] VD独服是新机器?
 楼主| 发表于 2011-3-18 23:49:13 | 只看该作者
既然大家一致同意,那么就认为VD的机器是二手的吧。
顺便上个跑分。
  1. ========================================================================
  2.    BYTE UNIX Benchmarks (Version 5.1.2)
  3.    System: cl-***.volumedrive.com: GNU/Linux
  4.    OS: GNU/Linux -- 2.6.18-194.32.1.el5 -- #1 SMP Wed Jan 5 17:52:25 EST 2011
  5.    Machine: x86_64 (x86_64)
  6.    Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
  7.    CPU 0: Intel(R) Xeon(R) CPU X3450 @ 2.67GHz (5320.1 bogomips)
  8.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
  9.    CPU 1: Intel(R) Xeon(R) CPU X3450 @ 2.67GHz (5320.0 bogomips)
  10.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
  11.    CPU 2: Intel(R) Xeon(R) CPU X3450 @ 2.67GHz (5320.0 bogomips)
  12.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
  13.    CPU 3: Intel(R) Xeon(R) CPU X3450 @ 2.67GHz (5319.9 bogomips)
  14.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
  15.    CPU 4: Intel(R) Xeon(R) CPU X3450 @ 2.67GHz (5319.9 bogomips)
  16.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
  17.    CPU 5: Intel(R) Xeon(R) CPU X3450 @ 2.67GHz (5319.9 bogomips)
  18.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
  19.    CPU 6: Intel(R) Xeon(R) CPU X3450 @ 2.67GHz (5319.9 bogomips)
  20.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
  21.    CPU 7: Intel(R) Xeon(R) CPU X3450 @ 2.67GHz (5319.9 bogomips)
  22.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
  23.    04:54:38 up  8:34,  4 users,  load average: 0.04, 0.01, 0.06; runlevel 3
  24. ------------------------------------------------------------------------
  25. Benchmark Run: Fri Mar 18 2011 04:54:38 - 05:22:50
  26. 8 CPUs in system; running 1 parallel copy of tests
  27. Dhrystone 2 using register variables       15359197.6 lps   (10.0 s, 7 samples)
  28. Double-Precision Whetstone                     3036.3 MWIPS (9.9 s, 7 samples)
  29. Execl Throughput                               4990.4 lps   (30.0 s, 2 samples)
  30. File Copy 1024 bufsize 2000 maxblocks        643840.1 KBps  (30.0 s, 2 samples)
  31. File Copy 256 bufsize 500 maxblocks          180444.3 KBps  (30.0 s, 2 samples)
  32. File Copy 4096 bufsize 8000 maxblocks       1608931.9 KBps  (30.0 s, 2 samples)
  33. Pipe Throughput                             1155708.3 lps   (10.0 s, 7 samples)
  34. Pipe-based Context Switching                 132251.3 lps   (10.0 s, 7 samples)
  35. Process Creation                              15995.6 lps   (30.0 s, 2 samples)
  36. Shell Scripts (1 concurrent)                   8226.7 lpm   (60.0 s, 2 samples)
  37. Shell Scripts (8 concurrent)                   3386.2 lpm   (60.0 s, 2 samples)
  38. System Call Overhead                         948922.8 lps   (10.0 s, 7 samples)
  39. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  40. Dhrystone 2 using register variables         116700.0   15359197.6   1316.1
  41. Double-Precision Whetstone                       55.0       3036.3    552.0
  42. Execl Throughput                                 43.0       4990.4   1160.5
  43. File Copy 1024 bufsize 2000 maxblocks          3960.0     643840.1   1625.9
  44. File Copy 256 bufsize 500 maxblocks            1655.0     180444.3   1090.3
  45. File Copy 4096 bufsize 8000 maxblocks          5800.0    1608931.9   2774.0
  46. Pipe Throughput                               12440.0    1155708.3    929.0
  47. Pipe-based Context Switching                   4000.0     132251.3    330.6
  48. Process Creation                                126.0      15995.6   1269.5
  49. Shell Scripts (1 concurrent)                     42.4       8226.7   1940.3
  50. Shell Scripts (8 concurrent)                      6.0       3386.2   5643.6
  51. System Call Overhead                          15000.0     948922.8    632.6
  52.        ========
  53. System Benchmarks Index Score                                        1223.0
  54. ------------------------------------------------------------------------
  55. Benchmark Run: Fri Mar 18 2011 05:22:50 - 05:50:42
  56. 8 CPUs in system; running 8 parallel copies of tests
  57. Dhrystone 2 using register variables       58630886.5 lps   (10.0 s, 7 samples)
  58. Double-Precision Whetstone                    19567.3 MWIPS (9.8 s, 7 samples)
  59. Execl Throughput                              28564.9 lps   (30.0 s, 2 samples)
  60. File Copy 1024 bufsize 2000 maxblocks        444545.1 KBps  (30.0 s, 2 samples)
  61. File Copy 256 bufsize 500 maxblocks          116390.6 KBps  (30.0 s, 2 samples)
  62. File Copy 4096 bufsize 8000 maxblocks       1165370.5 KBps  (30.0 s, 2 samples)
  63. Pipe Throughput                             5684460.9 lps   (10.0 s, 7 samples)
  64. Pipe-based Context Switching                1692720.8 lps   (10.0 s, 7 samples)
  65. Process Creation                              80783.5 lps   (30.0 s, 2 samples)
  66. Shell Scripts (1 concurrent)                  38956.6 lpm   (60.0 s, 2 samples)
  67. Shell Scripts (8 concurrent)                   5584.4 lpm   (60.0 s, 2 samples)
  68. System Call Overhead                        5575320.1 lps   (10.0 s, 7 samples)
  69. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  70. Dhrystone 2 using register variables         116700.0   58630886.5   5024.1
  71. Double-Precision Whetstone                       55.0      19567.3   3557.7
  72. Execl Throughput                                 43.0      28564.9   6643.0
  73. File Copy 1024 bufsize 2000 maxblocks          3960.0     444545.1   1122.6
  74. File Copy 256 bufsize 500 maxblocks            1655.0     116390.6    703.3
  75. File Copy 4096 bufsize 8000 maxblocks          5800.0    1165370.5   2009.3
  76. Pipe Throughput                               12440.0    5684460.9   4569.5
  77. Pipe-based Context Switching                   4000.0    1692720.8   4231.8
  78. Process Creation                                126.0      80783.5   6411.4
  79. Shell Scripts (1 concurrent)                     42.4      38956.6   9187.9
  80. Shell Scripts (8 concurrent)                      6.0       5584.4   9307.3
  81. System Call Overhead                          15000.0    5575320.1   3716.9
  82.        ========
  83. System Benchmarks Index Score                                        3737.2
发表于 2011-3-18 23:50:31 | 只看该作者
R210....
我后悔了
发表于 2011-3-18 23:58:00 | 只看该作者
 楼主| 发表于 2011-3-20 22:12:37 | 只看该作者
补一个虚拟机跑分。
顺便问一下KVM+libvirt+qemu怎么显示真实的CPU信息?
  3.    System: debian: GNU/Linux
  4.    OS: GNU/Linux -- 2.6.32-5-686 -- #1 SMP Wed Jan 12 04:01:41 UTC 2011
  5.    Machine: i686 (unknown)
  7.    CPU 0: QEMU Virtual CPU version 0.9.1 (5320.1 bogomips)
  8.           x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET
  9.    CPU 1: QEMU Virtual CPU version 0.9.1 (5320.1 bogomips)
  10.           x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET
  11.    CPU 2: QEMU Virtual CPU version 0.9.1 (5320.1 bogomips)
  12.           x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET
  13.    CPU 3: QEMU Virtual CPU version 0.9.1 (5320.1 bogomips)
  14.           x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET
  15.    00:14:39 up 22:08,  1 user,  load average: 0.16, 0.03, 0.01; runlevel 2
  16. ------------------------------------------------------------------------
  17. Benchmark Run: Sun Mar 20 2011 00:14:39 - 00:43:02
  18. 4 CPUs in system; running 1 parallel copy of tests
  19. Dhrystone 2 using register variables       14511615.7 lps   (10.0 s, 7 samples)
  20. Double-Precision Whetstone                     2736.5 MWIPS (10.1 s, 7 samples)
  21. Execl Throughput                               2956.9 lps   (29.9 s, 2 samples)
  22. File Copy 1024 bufsize 2000 maxblocks        510281.2 KBps  (30.0 s, 2 samples)
  23. File Copy 256 bufsize 500 maxblocks          134541.7 KBps  (30.0 s, 2 samples)
  24. File Copy 4096 bufsize 8000 maxblocks       1448306.2 KBps  (30.0 s, 2 samples)
  25. Pipe Throughput                              897497.2 lps   (10.0 s, 7 samples)
  26. Pipe-based Context Switching                 229538.7 lps   (10.0 s, 7 samples)
  27. Process Creation                               8931.4 lps   (30.0 s, 2 samples)
  28. Shell Scripts (1 concurrent)                   6421.6 lpm   (60.0 s, 2 samples)
  29. Shell Scripts (8 concurrent)                   2461.5 lpm   (60.0 s, 2 samples)
  30. System Call Overhead                        3020445.5 lps   (10.0 s, 7 samples)
  31. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  32. Dhrystone 2 using register variables         116700.0   14511615.7   1243.5
  33. Double-Precision Whetstone                       55.0       2736.5    497.5
  34. Execl Throughput                                 43.0       2956.9    687.6
  35. File Copy 1024 bufsize 2000 maxblocks          3960.0     510281.2   1288.6
  36. File Copy 256 bufsize 500 maxblocks            1655.0     134541.7    812.9
  37. File Copy 4096 bufsize 8000 maxblocks          5800.0    1448306.2   2497.1
  38. Pipe Throughput                               12440.0     897497.2    721.5
  39. Pipe-based Context Switching                   4000.0     229538.7    573.8
  40. Process Creation                                126.0       8931.4    708.8
  41. Shell Scripts (1 concurrent)                     42.4       6421.6   1514.5
  42. Shell Scripts (8 concurrent)                      6.0       2461.5   4102.5
  43. System Call Overhead                          15000.0    3020445.5   2013.6
  44.        ========
  45. System Benchmarks Index Score                                        1124.5
  46. ------------------------------------------------------------------------
  47. Benchmark Run: Sun Mar 20 2011 00:43:02 - 01:11:27
  48. 4 CPUs in system; running 4 parallel copies of tests
  49. Dhrystone 2 using register variables       57889164.2 lps   (10.0 s, 7 samples)
  50. Double-Precision Whetstone                    10925.3 MWIPS (10.0 s, 7 samples)
  51. Execl Throughput                              14782.5 lps   (29.9 s, 2 samples)
  52. File Copy 1024 bufsize 2000 maxblocks        597095.2 KBps  (30.0 s, 2 samples)
  53. File Copy 256 bufsize 500 maxblocks          157927.7 KBps  (30.0 s, 2 samples)
  54. File Copy 4096 bufsize 8000 maxblocks       1983265.9 KBps  (30.0 s, 2 samples)
  55. Pipe Throughput                             3580944.7 lps   (10.0 s, 7 samples)
  56. Pipe-based Context Switching                 904558.4 lps   (10.0 s, 7 samples)
  57. Process Creation                              48732.3 lps   (30.0 s, 2 samples)
  58. Shell Scripts (1 concurrent)                  21619.2 lpm   (60.0 s, 2 samples)
  59. Shell Scripts (8 concurrent)                   2824.5 lpm   (60.0 s, 2 samples)
  60. System Call Overhead                        9924745.4 lps   (10.0 s, 7 samples)
  61. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  62. Dhrystone 2 using register variables         116700.0   57889164.2   4960.5
  63. Double-Precision Whetstone                       55.0      10925.3   1986.4
  64. Execl Throughput                                 43.0      14782.5   3437.8
  65. File Copy 1024 bufsize 2000 maxblocks          3960.0     597095.2   1507.8
  66. File Copy 256 bufsize 500 maxblocks            1655.0     157927.7    954.2
  67. File Copy 4096 bufsize 8000 maxblocks          5800.0    1983265.9   3419.4
  68. Pipe Throughput                               12440.0    3580944.7   2878.6
  69. Pipe-based Context Switching                   4000.0     904558.4   2261.4
  70. Process Creation                                126.0      48732.3   3867.6
  71. Shell Scripts (1 concurrent)                     42.4      21619.2   5098.9
  72. Shell Scripts (8 concurrent)                      6.0       2824.5   4707.6
  73. System Call Overhead                          15000.0    9924745.4   6616.5
  74.        ========
  75. System Benchmarks Index Score                                        3057.1
发表于 2011-3-20 23:36:51 | 只看该作者
   新JJ
发表于 2011-3-21 00:04:50 | 只看该作者
除了硬盘是新的, 其他都是二手 品牌机。
GMT+8, 2026-4-23 22:41 , Processed in 0.059622 second(s), 8 queries , Gzip On, MemCache On.
