楼主: shc
比挖Monero收益更高的代币: ETN(收益约是XMR的1.8倍)
发表于 2018-1-12 13:49:24 | 只看该作者
我用代理连接这个矿池,有点问题,一直搞不明白,大佬帮看下:
[2018-01-12 13:00:12] 2.0 KH/s, shares: 1/0 +1, upstreams: 1, miners: 3 (max 3) +1/-0
[2018-01-12 13:01:12] 2.0 KH/s, shares: 2/0 +1, upstreams: 1, miners: 5 (max 5) +2/-0
[2018-01-12 13:02:12] 0.0 KH/s, shares: 2/0 +0, upstreams: 1, miners: 5 (max 5) +0/-0
[2018-01-12 13:03:12] 0.0 KH/s, shares: 2/0 +0, upstreams: 1, miners: 5 (max 5) +0/-0
[2018-01-12 13:03:26] #000 rejected (2/1+0) diff 120001 "Block expired" (385 ms)
[2018-01-12 13:04:12] 0.0 KH/s, shares: 2/1 +0, upstreams: 1, miners: 5 (max 5) +0/-0
[2018-01-12 13:05:12] 0.0 KH/s, shares: 2/1 +0, upstreams: 1, miners: 5 (max 5) +0/-0
[2018-01-12 13:06:12] 0.0 KH/s, shares: 2/1 +0, upstreams: 1, miners: 5 (max 5) +0/-0
[2018-01-12 13:07:12] 0.0 KH/s, shares: 2/1 +0, upstreams: 1, miners: 5 (max 5) +0/-0
[2018-01-12 13:08:12] 0.0 KH/s, shares: 2/1 +0, upstreams: 1, miners: 5 (max 5) +0/-0
[2018-01-12 13:09:12] 0.0 KH/s, shares: 2/1 +0, upstreams: 1, miners: 5 (max 5) +0/-0
[2018-01-12 13:10:13] 0.0 KH/s, shares: 2/1 +0, upstreams: 1, miners: 5 (max 5) +0/-0
[2018-01-12 13:11:13] 2.0 KH/s, shares: 3/1 +1, upstreams: 1, miners: 5 (max 5) +0/-0
[2018-01-12 13:12:13] 0.0 KH/s, shares: 3/1 +0, upstreams: 1, miners: 5 (max 5) +0/-0
[2018-01-12 13:13:13] 0.0 KH/s, shares: 3/1 +0, upstreams: 1, miners: 5 (max 5) +0/-0
[2018-01-12 13:14:13] 0.0 KH/s, shares: 3/1 +0, upstreams: 1, miners: 5 (max 5) +0/-0
[2018-01-12 13:14:19] #000 no active pools, stop
[2018-01-12 13:14:25] #000 use pool etn-us-west1.nanopool.org:13333 45.32.71.82
[2018-01-12 13:15:13] 0.0 KH/s, shares: 3/1 +0, upstreams: 1, miners: 5 (max 5) +0/-0
[2018-01-12 13:16:13] 0.0 KH/s, shares: 3/1 +0, upstreams: 1, miners: 6 (max 6) +1/-0
[2018-01-12 13:17:13] 0.0 KH/s, shares: 3/1 +0, upstreams: 1, miners: 6 (max 6) +0/-0
[2018-01-12 13:18:13] 0.0 KH/s, shares: 3/1 +0, upstreams: 1, miners: 6 (max 6) +0/-0
[2018-01-12 13:19:13] 0.0 KH/s, shares: 3/1 +0, upstreams: 1, miners: 6 (max 6) +0/-0
[2018-01-12 13:20:13] 0.0 KH/s, shares: 3/1 +0, upstreams: 1, miners: 6 (max 6) +0/-0
[2018-01-12 13:21:13] 0.0 KH/s, shares: 3/1 +0, upstreams: 1, miners: 6 (max 6) +0/-0
[2018-01-12 13:22:13] 0.0 KH/s, shares: 3/1 +0, upstreams: 1, miners: 6 (max 6) +0/-0
经常出现上面错误,提交shares失败,
42#
发表于 2018-1-12 13:50:09 | 只看该作者
他们矿池算力这么低,要等很久才挖到一个Block呐,手续费是0.1%,但是看你有没有耐性了
43#
发表于 2018-1-12 13:51:00 | 只看该作者
920c 发表于 2018-1-12 13:50
他们矿池算力这么低,要等很久才挖到一个Block呐,手续费是0.1%,但是看你有没有耐性了 ...
也就是说达到一定的ETN要花费更长的时间对吗?
44#
发表于 2018-1-12 13:53:05 | 只看该作者
[2018-01-12 13:00:12] 2.0 KH/s, shares: ...
diff要改为5000
46#
发表于 2018-1-12 13:55:10 | 只看该作者
我在config.json修改为"custom-diff": 5000,  还是没有用,经常性的错误,大概每提交10次,有一次失败
47#
发表于 2018-1-12 13:58:27 | 只看该作者
huaan123 发表于 2018-1-12 13:55
我在config.json修改为"custom-diff": 5000,  还是没有用,经常性的错误,大概每提交10次,有一次失败 ...
算力太低,不建议用nanopool,他家是固定diff 120000
48#
发表于 2018-1-12 13:59:48 | 只看该作者
或者你提高你的custom-diff为10000
49#
发表于 2018-1-12 14:01:44 | 只看该作者
1K算力,一天大概挖多少ETN是正常的?
50#
发表于 2018-1-12 14:02:31 | 只看该作者
算力多少才不算低啊?
GMT+8, 2026-4-28 06:26 , Processed in 0.064145 second(s), 8 queries , Gzip On, MemCache On.
