查看: 5054|回复: 17
买了一百个GVH挂机,suspend了。下面看我直播
发表于 2014-8-27 12:17:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
第一轮交锋:
Hi, can you give me a refund?
No, absolutely not. Your VMs were causing the server to have an average load of almost 100.
发表于 2014-8-27 12:18:31 | 只看该作者
一百个。。。,那得好多钱吧
嗯,一千块钱了  发表于 2014-8-27 12:21
 楼主| 发表于 2014-8-27 12:19:16 | 只看该作者
why?I'm just running Hitleap on it
that's NOT abuse. I asked a lot of providers and they don't consider this as abuse
You were consistently generating a load of 3-4 PER VM, which caused the entire host node to be unstable. As per our terms of service, we cannot provide refunds for abuse.
发表于 2014-8-27 12:21:47 | 只看该作者
no zuo no die
上LET去骂,在这骂没用
发表于 2014-8-27 12:23:49 | 只看该作者
Please delete all my vm.
发表于 2014-8-27 12:24:39 | 只看该作者
整台母鸡都是你的了!
(干嘛部直接买毒妇?)
 楼主| 发表于 2014-8-27 12:29:19 | 只看该作者
说着说着,被关TK了,我再发一个
As the former ticket
https://secure.greenvaluehost.com/viewticket.php?tid=173179&c=0zldmkbm
I run this in all other providers and don't cause suspension
and I bought one with you for trial and don't cause suspension
why you suspend me when I BULK-BUY?
That's a cheating conduct
发表于 2014-8-27 12:35:35 | 只看该作者
 楼主| 发表于 2014-8-27 12:37:58 | 只看该作者
The COMBINED load you were generating was outrageous.
But WHEN I ORDERED 20, I SHOULD HAVE 20 TIMES THE RESOURCE WHEN I GENERATE 20 TIMES THE LOAD
接着又关TK了
发表于 2014-8-27 12:38:38 | 只看该作者
负载接近100 滥用
GMT+8, 2025-12-25 00:02 , Processed in 0.317187 second(s), 11 queries , Gzip On, MemCache On.
