查看: 3626|回复: 6
yum install screen 问题
发表于 2014-1-22 14:56:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
[root@e9Z ~]# yum install screen
Setting up Install Process
No package screen available.
Nothing to do
怎么回事  怎么解决呢?
发表于 2014-1-22 14:57:20 | 只看该作者
什么源
yum search screen
发下所有结果
 楼主| 发表于 2014-1-22 14:58:20 | 只看该作者
tanyuxiang 发表于 2014-1-22 14:57
什么源
yum search screen
[root@9Z ~]# yum search screen
============================ Matched: screen ============================
vim-common.x86_64 : The common files needed by any version of the VIM
                  : editor.
vim-enhanced.x86_64 : A version of the VIM editor which includes recent
                    : enhancements.
vim-minimal.x86_64 : A minimal version of the VIM editor.
3ddesktop.x86_64 : OpenGL program for switching virtual desktops in 3D
BitchX.x86_64 : Text mode IRC (Internet Relay Chat) client
caca-utils.x86_64 : Colour AsCii Art Text mode graphics utilities based
                  : on libcaca
clex.x86_64 : File manager with an ncurses interface
dbf.x86_64 : Fast convert for dBase, Clipper, FoxBase and Visual FoxPro
           : databases
djvulibre.x86_64 : DjVu viewers, encoders and utilities
ed.x86_64 : The GNU line editor.
fbdump.x86_64 : Take screenshots using the framebuffer device
fwlogwatch.x86_64 : Firewall log analyzer, report generator and realtime
                  : response agent
gruler.x86_64 : Customizable screen ruler
inconsolata-fonts.noarch : High-resolution programmer's font
kbd.x86_64 : Tools for configuring the console (keyboard, virtual
           : terminals, etc.)
kflamesaver.x86_64 : Screensaver with flames
kolourpaint.x86_64 : Free easy-to-use paint program
monsterz.noarch : Little arcade puzzle game, similar to the famous
                : Bejeweled
most.x86_64 : Text viewer similar to more or less, but with additional
            : capabilities
ncurses.x86_64 : A terminal handling library
oxine.x86_64 : Lightweight, purely OSD based xine frontend
perl-CGI-Screen.noarch : Extension for easy creation of multi screen CGI
                       : scripts
perl-Catalyst-Plugin-StackTrace.noarch : Display a stack trace on the
                                       : debug screen
perl-Curses.x86_64 : Perl module for terminal screen handling and
                   : optimization
perl-Term-Clui.noarch : The Command-Line User Interface
perl-Term-Screen.x86_64 : Term::Cap based screen positioning module
perl-Text-BarGraph.noarch : Generate ASCII bar graphs
pktstat.x86_64 : Displays a live list of active connections and what
               : files are being transferred
powertop.x86_64 : Tool that helps you find what software is using the
                : most power
python-beautifulsoup.noarch : Python library for screen-scraping HTML
python-osd.x86_64 : Python wrapper for libosd
pyvnc2swf.noarch : A VNC session recorder to Flash movie
qcomicbook.x86_64 : Viewer for comic book archives
qiv.x86_64 : Quick Image Viewer
ratpoison.x86_64 : Ratpoison window manager
rtorrent.x86_64 : Console-based BitTorrent client
screenie.noarch : Small frontend for screen
spacepong.noarch : An innovative Python SDL game that is controlled with
                 : the mouse
spinner.x86_64 : Anti-idle timeout preventer
stellarium.x86_64 : Stellarium renders 3D photo-realistic skies in real
                  : time
svgalib.x86_64 : Low-level fullscreen SVGA graphics library
tmux.x86_64 : Terminal multiplexer program
topless.noarch : display command output on the whole screen like ``top''
tpb.x86_64 : Utility to enable the IBM ThinkPad(tm) special keys
tslib.x86_64 : Abstraction layer for touchscreen panel event
tuxsaver.x86_64 : KDE screensaver showing the adventures of Tux, living
                : at the SouthPole
unpaper.x86_64 : Post-processing of scanned and photocopied book pages
vramsteg.x86_64 : Text-based progress bars
wmctrl.x86_64 : Command line tool to interact with an X Window Manager
x2x.x86_64 : Link two X displays together, simulating a multiheaded
           : display
xautomation.x86_64 : Control input to X Windows from the command line
xlockmore.x86_64 : Screen lock and screen saver.
xonclock.x86_64 : On-screen analog clock
xosd.x86_64 : Displays transparent text on your screen like the OSD of
            : TVs
xosd-devel.x86_64 : Development files for the XOSD on-screen display
                  : library
xpenguins.x86_64 : Cute little penguins that walk along the tops of your
                 : windows
发表于 2014-1-22 16:29:25 | 只看该作者
发表于 2014-1-22 17:09:13 | 只看该作者
用tmux吧, 比screen好多了
发表于 2014-1-22 17:10:40 | 只看该作者
- -用rpm 远程安装把。
GMT+8, 2026-4-27 11:22 , Processed in 0.067142 second(s), 13 queries , Gzip On, MemCache On.
