查看: 4349|回复: 5
VPS上不去了,提示:“server unexpectedly closed network connection”
发表于 2013-12-24 13:44:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
30金钱
RT,然后我找了另外一台VPS:
[root@Wilson ~]# ssh -vv 66.45.229.XXX
OpenSSH_5.3p1, OpenSSL 1.0.0-fips 29 Mar 2010
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: Applying options for *
debug2: ssh_connect: needpriv 0
debug1: Connecting to 66.45.229.XXX [66.45.229.XXX] port 22.
debug1: Connection established.
debug1: permanently_set_uid: 0/0
debug1: identity file /root/.ssh/identity type -1
debug1: identity file /root/.ssh/id_rsa type -1
debug1: identity file /root/.ssh/id_dsa type -1
debug1: Remote protocol version 2.0, remote software version OpenSSH_5.3
debug1: match: OpenSSH_5.3 pat OpenSSH*
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_5.3
debug2: fd 3 setting O_NONBLOCK
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug2: kex_parse_kexinit: diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1
debug2: kex_parse_kexinit: ssh-rsa,ssh-dss
debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rijndael-cbc@lysator.liu.se
debug2: kex_parse_kexinit: hmac-md5,hmac-sha1,umac-64@openssh.com,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96
debug2: kex_parse_kexinit: none,zlib@openssh.com,zlib
debug2: kex_parse_kexinit: first_kex_follows 0
debug2: kex_parse_kexinit: reserved 0
debug2: mac_setup: found hmac-md5
debug1: kex: server->client aes128-ctr hmac-md5 none
debug1: kex: client->server aes128-ctr hmac-md5 none
debug1: SSH2_MSG_KEX_DH_GEX_REQUEST(1024<1024<8192) sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_GROUP
Connection closed by 66.45.229.XXX
哪位大哥能看懂吗?
最佳答案
查看完整内容
前端有跑 cisco 的 dpi 之類的東西? 然後你 sshd 應該要升級補 patch
发表于 2013-12-24 13:44:12 | 只看该作者
 楼主| 发表于 2013-12-25 12:26:32 | 只看该作者
木有人回答。。
发表于 2013-12-25 13:00:55 | 只看该作者
openssh 出问题了
发表于 2013-12-25 13:52:01 | 只看该作者
重新生成一下openssh的公钥私钥dh链看看
发表于 2013-12-25 21:02:02 | 只看该作者
才 30 錢,唉,技術不值錢,真難賺...
所以人家說,做技術的,沒餓死是運氣,餓死應該的.
GMT+8, 2026-4-27 03:01 , Processed in 0.293598 second(s), 10 queries , Gzip On, MemCache On.
