查看: 2066|回复: 2
[Windows VPS] CentOS 5求助php-mcrypt 装不上
发表于 2013-10-18 17:17:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
CentOS 5系统
yum install php-mcrypt
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
* base: ftp.osuosl.org
* epel: mirrors.solfo.com
* extras: mirror.spro.net
* updates: mirrors.easynews.com
Setting up Install Process
Resolving Dependencies
--> Running transaction check
---> Package php-mcrypt.i386 0:5.1.6-15.el5.centos.1 set to be updated
--> Processing Dependency: php-api = 20041225 for package: php-mcrypt
--> Finished Dependency Resolution
php-mcrypt-5.1.6-15.el5.centos.1.i386 from extras has depsolving problems
  --> Missing Dependency: php-api = 20041225 is needed by package php-mcrypt-5.1.6-15.el5.centos.1.i386 (extras)
Error: Missing Dependency: php-api = 20041225 is needed by package php-mcrypt-5.1.6-15.el5.centos.1.i386 (extras)
You could try using --skip-broken to work around the problem
You could try running: package-cleanup --problems
                        package-cleanup --dupes
                        rpm -Va --nofiles --nodigest
The program package-cleanup is found in the yum-utils package.
GMT+8, 2026-4-23 11:52 , Processed in 0.177212 second(s), 11 queries , Gzip On, MemCache On.
