查看: 5951|回复: 16
我好像买到假的4核vps,怎么维权?
发表于 2015-1-29 09:26:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
购买了某家的vps,显示是4核心的cpu。但是很奇怪的是,这4核心cpu每一个核,不管是什么时间段,被利用率都是一模一样的。
这样正常吗?
是在真正的4核cpu吗?
为什么会出现这个情况?
top - 04:24:37 up 5 days, 23:01,  1 user,  load average: 0.80, 0.66, 0.62
Tasks:  59 total,   1 running,  56 sleeping,   0 stopped,   2 zombie
Cpu0  : 16.3%us,  2.3%sy,  0.0%ni, 80.0%id,  0.7%wa,  0.0%hi,  0.0%si,  0.7%st
Cpu1  : 16.3%us,  2.3%sy,  0.0%ni, 80.0%id,  0.7%wa,  0.0%hi,  0.0%si,  0.7%st
Cpu2  : 16.3%us,  2.3%sy,  0.0%ni, 80.0%id,  0.7%wa,  0.0%hi,  0.0%si,  0.7%st
Cpu3  : 16.3%us,  2.3%sy,  0.0%ni, 80.0%id,  0.7%wa,  0.0%hi,  0.0%si,  0.7%st
Mem:   2097152k total,  1991332k used,   105820k free,        0k buffers
Swap:        0k total,        0k used,        0k free,  1103916k cached
top - 04:25:04 up 5 days, 23:02,  1 user,  load average: 0.67, 0.64, 0.61
Tasks:  63 total,   1 running,  54 sleeping,   0 stopped,   8 zombie
Cpu0  : 32.9%us,  8.5%sy,  0.0%ni, 53.7%id,  0.0%wa,  0.0%hi,  0.0%si,  4.9%st
Cpu1  : 32.9%us,  8.5%sy,  0.0%ni, 53.7%id,  0.0%wa,  0.0%hi,  0.0%si,  4.9%st
Cpu2  : 32.9%us,  8.5%sy,  0.0%ni, 53.7%id,  0.0%wa,  0.0%hi,  0.0%si,  4.9%st
Cpu3  : 32.9%us,  8.5%sy,  0.0%ni, 53.7%id,  0.0%wa,  0.0%hi,  0.0%si,  4.9%st
Mem:   2097152k total,  2053076k used,    44076k free,        0k buffers
Swap:        0k total,        0k used,        0k free,  1189076k cached
然后,再贴上我从第二家买的vps,他们的每一个核心,占用率都是不一样的,这个才是正常的吧?
top - 01:29:10 up 92 days, 21:49,  1 user,  load average: 0.54, 0.69, 0.92
Tasks: 223 total,   2 running, 216 sleeping,   0 stopped,   5 zombie
Cpu0  : 20.4%us, 11.6%sy,  0.7%ni, 66.0%id,  0.3%wa,  0.0%hi,  0.7%si,  0.3%st
Cpu1  :  0.3%us,  0.3%sy,  0.0%ni, 99.0%id,  0.0%wa,  0.0%hi,  0.0%si,  0.3%st
Cpu2  :  2.3%us,  2.3%sy,  0.0%ni, 95.0%id,  0.0%wa,  0.0%hi,  0.0%si,  0.3%st
Cpu3  : 10.6%us,  7.0%sy,  0.0%ni, 82.1%id,  0.0%wa,  0.0%hi,  0.0%si,  0.3%st
Cpu4  : 17.2%us,  7.3%sy,  0.0%ni, 75.2%id,  0.0%wa,  0.0%hi,  0.0%si,  0.3%st
Cpu5  :  7.3%us,  2.3%sy,  0.0%ni, 90.0%id,  0.0%wa,  0.0%hi,  0.0%si,  0.3%st
Cpu6  :  0.0%us,  0.0%sy,  0.0%ni,100.0%id,  0.0%wa,  0.0%hi,  0.0%si,  0.0%st
Cpu7  :  0.0%us,  0.0%sy,  0.0%ni,100.0%id,  0.0%wa,  0.0%hi,  0.0%si,  0.0%st
Mem:   1913388k total,  1856632k used,    56756k free,   116600k buffers
Swap:  4194296k total,   144620k used,  4049676k free,  1216692k cached
发表于 2015-1-29 09:36:50 来自手机 | 只看该作者
如果某宝买的就认栽吧!都知道某宝是大坑……
发表于 2015-1-29 10:49:34 | 只看该作者
买VPS主要看内存大小,硬盘速度啊,又不是毒妇,深究CPU没意义吧,给你开真实24核又如何,CPU又不可能给你用满.
发表于 2015-1-29 10:50:18 | 只看该作者
12315   你可以打这个电话
怪人 该用户已被删除
发表于 2015-1-29 10:52:18 来自手机 | 只看该作者
发表于 2015-1-29 10:53:22 | 只看该作者
怪人 发表于 2015-1-29 10:52
多一核价格贵不小,国内两大马就知道了
国内二大马是独享核心CPU,如果你买了这个CPU,那这一核,就全归你用。
发表于 2015-1-29 11:00:41 | 只看该作者
怎么可能。。算上HT每台母鸡一般也就32-64个核吧,一台母鸡跑这么点用户他们早倒闭了。。
发表于 2015-1-29 21:36:52 | 只看该作者
h0stl0c 发表于 2015-1-29 11:00
怎么可能。。算上HT每台母鸡一般也就32-64个核吧,一台母鸡跑这么点用户他们早倒闭了。。 ...
确实不可能分物理的,常见的能保证质量又能降低成本的方法是按处理频率来计算,每一个虚拟化核心换算成一个数值的处理频率,然后多个核心就是叠加了处理频率.而且还能实现按资源使用去平均化分配到母鸡的物理核心上面.
发表于 2015-1-29 21:40:12 | 只看该作者
誰说的,一个刀片服务器4u的可以240核心2.1Ghz
GMT+8, 2026-4-15 17:57 , Processed in 0.291701 second(s), 14 queries , Gzip On, MemCache On.
