查看: 9977|回复: 37
推荐一款新面板,比国产完善
发表于 2013-8-28 14:45:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
众所皆知Kloxo的作者挂了嘛,然后开源了,然后有大神就Fork了一套Kloxo,改名叫做KLOXO-MR,经我试用,效果不错,特来推荐
(Centos6我怎么都装不成功,希望有大神可以研究出怎么装,5一切正常)、
项目地址:https://github.com/mustafaramadhan/kloxo/tree/dev
私人演示地址:https://60.190.217.130:7777/  admin admin123456(没外网地址 ,部分功能不可用)
http://60.190.217.130:10000
看看就行了。。别改密码
Kloxo-MR Features
OS: Redhat/CentOS 5 and 6 (32bit and 64bit) or their variants
Billing: AWBS, WHMCS, HostBill, TheHostingTool, AccountLab Plus and Blesta (note: claim by billing's author)
Web server: Nginx, Nginx-Proxy and Lighttpd-proxy; beside Httpd and Lighttpd (in progress: Varnish, Hiawata, ATS and Httpd 2.4)
Php: Dual-php with php 5.3/5.4 as primary and php 5.2 as secondary (in progress: multiple-php)
PHP-type for Apache: php-fpm_worker/_event and fcgid_worker/_event; beside mod_php/_ruid2/_itk and suphp/_worker/_event
Mail server: qmail-toaster instead special qmail (in progress: change from courier-imap to dovecot as imap/pop3)
Database: MySQL or MariaDB
Database Manager: PHPMyAdmin; Adminer, MyWebSql and SqlBuddy as additional
Webmail: Afterlogic Webmail Lite, Telaen, Squirrelmail and Roundcube; Horde and T-Dah dropped
FTP server: Pure-ftpd
DNS Server: Bind, Djbdns and Powerdns (in progress)
Addons: ClamAV, Spamassassin/Bogofilter/Spamdyke and RKHunter
Fixed many bugs of Kloxo Official (including security issues)
And many more!
我来简单翻译下
KLOXO-MR的产品特点
OS:兼容REHL/Centos 5 6,32bit 64bit以及他们的衍生版本(fedora?)
Billing:兼容上面提到的财务系统
Web Server:这是最屌的一部分,比一些国产的好多了(lumange竟然是全777,kloxo自带用户分离防止跨站)Nginx, Nginx-代理、Lighttpd代理; Httpd and Lighttpd 做后端(正在处理兼容性的: Varnish, Hiawata, ATS and Httpd 2.4)
Mail Server:mail-toaster instead special qmail (in progress: change from courier-imap to dovecot as imap/pop3)
Database: MySQL 和 MariaDB
Database Manager: PHPMyAdmin; Adminer, MyWebSql 和 SqlBuddy 作为可选附件
DNS Server: Bind, Djbdns and     Powerdns (in progress)支持PowerDns哦!这可是好东西啊
Addons: ClamAV(杀毒软件), Spamassassin/Bogofilter/Spamdyke and RKHunter
Fixed many bugs of Kloxo Official (including security issues)修复了Kloxo官方版的一堆BUG(其实老版本还没什么BUG,作者挂了以后,升级的版本倒是一堆BUG)
And many more!
发表于 2013-8-28 23:08:50 | 只看该作者
Httpd 2.4可以suphp方式运行么
另外,mr=MyRepublic
 楼主| 发表于 2013-8-28 14:46:06 | 只看该作者
安装方法
A. 事前准备
    cd /
    # 升级系统
    yum update -y
    # 安装一些辅助工具
    yum install yum-utils yum-priorities vim-minimal subversion curl zip unzip -y
    yum install telnet wget -y
    #关闭SELINUX
    setenforce 0
    echo 'SELINUX=disabled' > /etc/selinux/config
    cd /
B. 安装 Kloxo-MR (选择 B.1 或者 B.2)
B.1 如果想尝试最新的开发板:
   - Install/reinstall/upgrade -- data not destroyed with this fork(简单地说就是不会摧毁以前KLOXO的数据)
     for existing kloxo (6.1.x), run 'sh /script/update' first.
如果以前安装了kloxo了,先运行 sh /script/update
    # delete if exist, create kloxo temp dir
    rm -rf /tmp/kloxo; mkdir /tmp/kloxo ; cd /tmp/kloxo;
    rm -f ./kloxo-mr-dev.sh
    # get kloxo-mr-dev installer from github
    wget https://github.com/mustafaramadhan/kloxo/raw/dev/kloxo/install/kloxo-mr-dev.sh --no-check-certificate
    # install kloxo
    sh ./kloxo-mr-dev.sh
    # better reboot
    reboot
B.2. 对于用户想用的Stable版:
    # move repo dir
    cd /etc/yum.repos.d/
    # get repo file -- no need for 6.5.0.c and after
    wget https://github.com/mustafaramadhan/kloxo/raw/release/kloxo-mr.repo --no-check-certificate
    # move to /
    cd /
    # install (and then run 'sh /usr/local/lxlabs/kloxo/install/setup.sh')yum之后要运行初始化
    yum install kloxomr -y
    # better reboot
    reboot
发表于 2013-8-28 14:47:36 | 只看该作者
url在哪里啊?
发表于 2013-8-28 14:48:16 | 只看该作者
界面截图呢?
发表于 2013-8-28 14:50:50 | 只看该作者
想试试~~哈哈
占用怎么样啊
 楼主| 发表于 2013-8-28 14:51:53 | 只看该作者
截图就是kloxo的,你们要的图片
 楼主| 发表于 2013-8-28 14:53:26 | 只看该作者
junhan 发表于 2013-8-28 14:50
想试试~~哈哈
占用怎么样啊
占用不是很大。。以前256M都装得下kloxo  128就别试了。。
发表于 2013-8-28 14:56:19 | 只看该作者
有无翻译文件, 另外一个就是能否长期维护。 这个最重要。
发表于 2013-8-28 14:57:56 | 只看该作者
没中文不舒服~
 楼主| 发表于 2013-8-28 15:01:16 | 只看该作者
看看就行了。。别改密码
GMT+8, 2026-4-18 05:38 , Processed in 0.122680 second(s), 14 queries , Gzip On, MemCache On.
