查看: 9062|回复: 32
[疑问] bluevm4G内存100G硬年付40刀测评,对不对的起这价自己看!!!
发表于 2013-5-23 00:09:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这个vps是@云生买的,后来他不要了就卖给我了,今天刚拿到,就做个简单的测试吧,
VPS配置如下
2048 MB of Guaranteed RAM
4096 MB of Burstable RAM
4 CPU @ 2.0+ Ghz
1 IP Address
100 GB of Disk
3 TB of Bandwidth
刚才洗澡趁这段时间测试了UBI跑分综合性能测试:
应该是按照最下面的数值吧?而不是上面的那个吧?懂得人自己心里肯定清楚,如下
上面的数值:
Dhrystone 2 using register variables         116700.0   18898330.7   1619.4
Double-Precision Whetstone                       55.0       3106.1    564.7
Execl Throughput                                 43.0       6348.1   1476.3
File Copy 1024 bufsize 2000 maxblocks          3960.0     724142.8   1828.6
File Copy 256 bufsize 500 maxblocks            1655.0     210080.4   1269.4
File Copy 4096 bufsize 8000 maxblocks          5800.0    1820986.6   3139.6
Pipe Throughput                               12440.0    1205176.9    968.8
Pipe-based Context Switching                   4000.0     351642.1    879.1
Process Creation                                126.0      20261.6   1608.1
Shell Scripts (1 concurrent)                     42.4       6641.8   1566.5
Shell Scripts (8 concurrent)                      6.0       2135.7   3559.5
System Call Overhead                          15000.0     929600.6    619.7
System Benchmarks Index Score                                        1377.2
最下面的数值
Dhrystone 2 using register variables         116700.0   53401548.7   4576.0
Double-Precision Whetstone                       55.0      11756.3   2137.5
Execl Throughput                                 43.0      17631.6   4100.4
File Copy 1024 bufsize 2000 maxblocks          3960.0     580784.4   1466.6
File Copy 256 bufsize 500 maxblocks            1655.0     157175.6    949.7
File Copy 4096 bufsize 8000 maxblocks          5800.0    1483604.6   2557.9
Pipe Throughput                               12440.0    3581785.0   2879.2
Pipe-based Context Switching                   4000.0    1089901.6   2724.8
Process Creation                                126.0      55168.7   4378.5
Shell Scripts (1 concurrent)                     42.4      20154.9   4753.5
Shell Scripts (8 concurrent)                      6.0       2828.9   4714.9
System Call Overhead                          15000.0    2874701.3   1916.5
System Benchmarks Index Score                                        2777.5
DD测试,256mb和1G的分别测试了三次和俩次
[root@mfacdpft ~]# dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
4096+0 records in
4096+0 records out
268435456 bytes (268 MB) copied, 3.44655 seconds, 77.9 MB/s
4096+0 records in
4096+0 records out
268435456 bytes (268 MB) copied, 3.77418 seconds, 71.1 MB/s
4096+0 records in
4096+0 records out
268435456 bytes (268 MB) copied, 3.1846 seconds, 84.3 MB/s
[root@mfacdpft ~]# dd if=/dev/zero of=test bs=64k count=16k oflag=dsync
16384+0 records in
16384+0 records out
1073741824 bytes (1.1 GB) copied, 14.5043 seconds, 74.0 MB/s
16384+0 records in
16384+0 records out
1073741824 bytes (1.1 GB) copied, 13.1953 seconds, 81.4 MB/s
WGET wget http://cachefly.cachefly.net/100mb.test 数据
[root@mfacdpft ~]# wget http://cachefly.cachefly.net/100mb.test
--2013-05-22 23:53:03--  http://cachefly.cachefly.net/100mb.test
Resolving cachefly.cachefly.net... 205.234.175.175
Connecting to cachefly.cachefly.net|205.234.175.175|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 104857600 (100M) [application/octet-stream]
Saving to: `100mb.test.1'
100%[======================================>] 104,857,600 28.5M/s   in 3.5s
2013-05-22 23:53:07 (28.4 MB/s) - `100mb.test.1' saved [104857600/104857600]
中午的单线程从vps上下载速度如图
注:我的是电信3M宽带
刚刚做的ping值,高峰期你懂得,目测这vps是他家纽约的数据中心
其他的就不做测试了,如果你需要知道其他什么性能的可以回帖,我来测试下
还要说明一下
中午的时候ping值比这次低点。还有那个时候dd测试有130mb,wget数值有50Mb/s
至于值不值这个价格,相信每个人心中都有自己的答案,我也没什么好说的
附上几张截图吧 最下面中午测试,后来截的,自己看图片名称就知道时间了
中午截图,整个屏幕了,这是现在从大图里截的小图
发表于 2013-5-23 00:13:21 | 只看该作者
话说。。。我不是针对谁。。只是实话实说。。。
文字编辑掉。。。。。。不影响楼主文章了。。。呵呵。。。
是的,我签名挂他家的,就像你的签名一样,还有我只是照实说,没有任何的作假  发表于 2013-5-23 00:20
发表于 2013-5-23 00:13:39 | 只看该作者
发表于 2013-5-23 00:17:44 | 只看该作者
ybs885 发表于 2013-5-23 00:13
额、第一次听到有人说BLUEVM好。
后来看到楼主签名。。。我瞬间又感觉。。。我不会再爱了、、、
123sys有换过机房?
发表于 2013-5-23 00:19:20 | 只看该作者
kwx 发表于 2013-5-23 00:17
123sys有换过机房?
我是说BLUE。。。
发表于 2013-5-23 00:20:38 | 只看该作者
强烈要求上洗澡的照片
看几把啊  发表于 2013-5-23 00:28
发表于 2013-5-23 00:21:29 | 只看该作者
ybs885 发表于 2013-5-23 00:19
我是说BLUE。。。
你的头像让我胡思乱想了
发表于 2013-5-23 00:22:50 | 只看该作者
注:我的是电信3M宽带  421K/S
电信3M Niubility , 秒杀我联通 4M .
不是吧?我记得当初刚升时候高峰有490左右,现在最多430到440  发表于 2013-5-23 00:27
 楼主| 发表于 2013-5-23 00:23:25 | 只看该作者
额、第一次听到有人说BLUEVM好。
是的,我签名挂他家的,就像你的签名一样,还有这些数据都是测试的结果,我只是照实说,没有任何的作假!!
至于说他们家换机房换ip,是的我也被换过俩次了,数据也丢了一个源码,到现在他们家已经俩三个月换机房了,未来我不清楚,你懂得
发表于 2013-5-23 00:27:17 | 只看该作者
誓誓 发表于 2013-5-23 00:23
是的,我签名挂他家的,就像你的签名一样,还有这些数据都是测试的结果,我只是照实说,没有任何的作假! ...
不好意思影响您的营销了。。我编辑掉了蚊子了。话说我的签名那个无所谓啦。哈哈你懂的。根本不可能拿到的推介。
GMT+8, 2026-4-15 15:15 , Processed in 0.209224 second(s), 14 queries , Gzip On, MemCache On.
