查看: 4334|回复: 19
[美国VPS] 【测评】Github Codespaces 白女票 vps 测评
发表于 2023-11-15 11:36:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
经大佬建议,我用 yabs 脚本重新测了一下。测试数据已经贴在这里了。希望广大 mjj 们也去开几个来测测,最好是不同地区的,可以对比一下
开了一个 2h8g 的测了一下(你们也可以开一个玩玩,链接:https://github.com/codespaces。可以通过用不同的代理ip来开不同的地区,比如香港ip开新加坡,洛杉矶ip开凤凰城,等等)。本人测评小白,也不知道用什么脚本最好,就随便用了个 lemonbench。大佬可以推荐一下脚本,我之后再去测一测
  3. #                     v2023-09-06                    #
  6. Wed Nov 15 04:39:34 UTC 2023
  7. Basic System Information:
  9. Uptime     : 0 days, 2 hours, 19 minutes
  10. Processor  : AMD EPYC 7763 64-Core Processor
  11. CPU cores  : 2 @ 3243.014 MHz
  12. AES-NI     : ✔ Enabled
  13. VM-x/AMD-V : ✔ Enabled
  14. RAM        : 7.7 GiB
  15. Swap       : 0.0 KiB
  16. Disk       : 104.2 GiB
  17. Distro     : Ubuntu 20.04.6 LTS
  18. Kernel     : 6.2.0-1015-azure
  19. VM Type    : DOCKER
  20. IPv4/IPv6  : ✔ Online / ❌ Offline
  21. IPv4 Network Information:
  23. ISP        : Microsoft Corporation
  24. ASN        : AS8075 Microsoft Corporation
  25. Host       : Microsoft Azure Cloud (southeastasia)
  26. Location   : Singapore, Central Singapore (01)
  27. Country    : Singapore
  28. fio Disk Speed Tests (Mixed R/W 50/50):
  32. Read       | 1.40 MB/s      (351) | 81.78 MB/s    (1.2k)
  33. Write      | 1.43 MB/s      (358) | 82.21 MB/s    (1.2k)
  34. Total      | 2.83 MB/s      (709) | 163.99 MB/s   (2.5k)
  38. Read       | 221.47 MB/s    (432) | 249.70 MB/s    (243)
  39. Write      | 233.24 MB/s    (455) | 266.33 MB/s    (260)
  40. Total      | 454.71 MB/s    (887) | 516.03 MB/s    (503)
  45. Clouvider       | London, UK (10G)          | 957 Mbits/sec   | 917 Mbits/sec   | --
  46. Scaleway        | Paris, FR (10G)           | busy            | busy            | --
  47. NovoServe       | North Holland, NL (40G)   | 1.06 Gbits/sec  | 88.0 Mbits/sec  | --
  48. Uztelecom       | Tashkent, UZ (10G)        | 860 Mbits/sec   | 417 Mbits/sec   | --
  49. Clouvider       | NYC, NY, US (10G)         | 628 Mbits/sec   | 482 Mbits/sec   | --
  50. Clouvider       | Dallas, TX, US (10G)      | busy            | 291 Mbits/sec   | --
  51. Clouvider       | Los Angeles, CA, US (10G) | 280 Mbits/sec   | 545 Mbits/sec   | --
  52. Geekbench 6 Benchmark Test:
  53. ---------------------------------
  54. Test            | Value
  55.                 |
  56. Single Core     | 1447
  57. Multi Core      | 1764
  58. Full Test       | https://browser.geekbench.com/v6/cpu/3553696
  59. YABS completed in 15 min 45 sec
来自 13#
发表于 2023-11-15 13:38:21 | 只看该作者
mtdickens 发表于 2023-11-15 13:29
大佬,我好像在 template 里面没有看到 macos
https://github.com/Fangsongs/svactions
给你一点灵感
发表于 2023-11-15 11:41:23 来自手机 | 只看该作者
https://browser.geekbench.com/v6/cpu/2110241, https://browser.geekbench.com/user/Microcharon
发表于 2023-11-15 12:44:53 | 只看该作者
完了,要被MJJ撸爆了
 楼主| 发表于 2023-11-15 13:15:00 | 只看该作者
自顶,mjj 快来撸爆。反正 Github 背靠 Azure,财大气粗,不怕 mjj 瞎造
发表于 2023-11-15 13:15:38 来自手机 | 只看该作者
发表于 2023-11-15 13:17:00 | 只看该作者
可以女票多久的啊
发表于 2023-11-15 13:20:09 | 只看该作者
定时销毁,每月有上限,里边mac可以弄出来玩,意义不大
 楼主| 发表于 2023-11-15 13:21:28 | 只看该作者
a347194856 发表于 2023-11-15 13:17
可以女票多久的啊
链接:https://docs.github.com/zh/billing/managing-billing-for-github-codespaces/about-billing-for-github-codespaces
貌似最低只能开 2h8g 的,文档里的核活跃时间数是 120 小时,所以每月的实际活跃时间至多只有 60 小时。
 楼主| 发表于 2023-11-15 13:22:56 | 只看该作者
求问怎么开 mac,是需要自己装,还是默认就有
发表于 2023-11-15 13:23:33 | 只看该作者
默认就有,直接装上vnc,把vnc端口映射出来
GMT+8, 2026-4-19 14:32 , Processed in 0.090776 second(s), 14 queries , Gzip On, MemCache On.
