查看: 5997|回复: 8
[Windows VPS] nginx 重定向错误
发表于 2013-1-15 22:37:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. server
  2.         {
  3.                 listen       80;
  4.                 server_name www.loc16.com loc16.com;
  5. server {
  6. server_name www.loc16.com loc16.com;
  7. rewrite ^/(.*) http://www.loc16.com/$1 permanent;
  8. }
  9.                 index index.html index.htm index.php default.html default.htm default.php;
  10.                 root  /data/loc16.com;
  11.                 include none.conf;
  12.                 location ~ .*\.(php|php5)?$
  13.                         {
  14.                                 try_files $uri =404;
  15.                                 fastcgi_pass  unix:/tmp/php-cgi.sock;
  16.                                 fastcgi_index index.php;
  17.                                 include fcgi.conf;
  18.                         }
  19.                 location ~ .*\.(gif|jpg|jpeg|png|bmp|swf)$
  20.                         {
  21.                                 expires      30d;
  22.                         }
  23.                 location ~ .*\.(js|css)?$
  24.                         {
  25.                                 expires      12h;
  26.                         }
  27.                 access_log off;
  28.         }
  29. ~
想把loc16.com www.loc16.com 重定向成 http://www.loc16.com
用上面的命令是成功了。但是重启lnmp的时候有错误。 怎么样才不出错误。
Reload LNMP...
Reload Nginx configure...
nginx: [emerg] "server" directive is not allowed here in /usr/local/nginx/conf/vhost/www.loc16.com.conf:6
nginx: configuration file /usr/local/nginx/conf/nginx.conf test failed
Nginx program is reloding!
SUCCESS! Reloading service MySQL
Reload service php-fpm  done
发表于 2013-1-15 22:39:09 | 只看该作者
替换?  发表于 2013-1-15 22:40
发表于 2013-1-15 22:40:48 | 只看该作者
发表于 2013-1-15 22:40:56 | 只看该作者
  1. server
  2.         {
  3.                 listen       80;
  5. rewrite ^/(.*) http://www.loc16.com/$1 permanent;
  6.                 index index.html index.htm index.php default.html default.htm default.php;
  7.                 root  /data/loc16.com;
  8.                 include none.conf;
  9.                 location ~ .*\.(php|php5)?$
  10.                         {
  11.                                 try_files $uri =404;
  12.                                 fastcgi_pass  unix:/tmp/php-cgi.sock;
  13.                                 fastcgi_index index.php;
  14.                                 include fcgi.conf;
  15.                         }
  16.                 location ~ .*\.(gif|jpg|jpeg|png|bmp|swf)$
  17.                         {
  18.                                 expires      30d;
  19.                         }
  20.                 location ~ .*\.(js|css)?$
  21.                         {
  22.                                 expires      12h;
  23.                         }
  24.                 access_log off;
  25.         }
参与人数 1威望 +5 收起 理由
polar + 5 很给力!
发表于 2013-1-15 22:41:42 | 只看该作者
你绑定也重复了
两个server_name www.loc16.com loc16.com;
  1. server
  2.         {
  3.                 listen       80;
  4.                 server_name loc16.com;}
  5. server {
  6. server_name www.loc16.com;
参与人数 1威望 +5 收起 理由
polar + 5 很给力!
发表于 2013-1-15 22:43:04 | 只看该作者
顶楼上的
发表于 2013-1-15 22:43:52 | 只看该作者
大胡子V5
发表于 2013-1-15 22:45:49 | 只看该作者
@楼主 :server插server,厉害啊
@4,5,6 :rewrite死循环了
参与人数 1威望 +10 收起 理由
大胡子 + 10 赞一个!
发表于 2013-1-15 22:59:19 | 只看该作者
GMT+8, 2026-4-27 14:21 , Processed in 0.132305 second(s), 15 queries , Gzip On, MemCache On.
