查看: 1892|回复: 5
域名被强行锁定,投诉ICANN无果
发表于 2012-11-26 17:50:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
被注册商以非法注册占据域名,ICANN投诉几次无果,求大神帮助,或者有偿寻找可以帮助的大神
Dear Sir
ICANN was advised by the registrar that they had contacted you to assist with your query regarding domain name XXX.com.
You are being requested to provide ID verification that you are the registrant. If the registrar does not receive this information they are unable to provide you with the auth code to enable the transfer. As per ICANN guidelines, a Registrar can only provide the auth code to the registrant of a domain name. Please therefore contact your registrar. For WHOIS details please refer to http://www.internic.net/whois.html.
We have therefore closed this complaint ticket.
Sincerely,
ICANN Contractual Compliance
Ticket Details
Ticket ID: DYV-80752X
Department: Transfer Problems
Priority: High
Status: Closed
发表于 2012-11-26 17:53:36 | 只看该作者
发表于 2012-11-26 17:54:25 | 只看该作者
发表于 2012-11-26 17:56:34 | 只看该作者
发表于 2012-11-26 17:59:33 | 只看该作者
是不是注册人信息不对?
发表于 2012-11-26 18:12:21 | 只看该作者
悲剧了
GMT+8, 2026-4-29 23:20 , Processed in 0.061319 second(s), 9 queries , Gzip On, MemCache On.
