查看: 3424|回复: 4
[Windows VPS] JS混淆编码解密,求教育求方法送妹纸...
发表于 2012-11-5 00:32:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
主要是类似这些编码要怎么转换成为字符?求方法送妹纸...
\x50\x61\x72\x65\x6e\x74\x55\x72\x6c
  1. var $ = function(value) {
  2.     return document.getElementById(value)
  3. };
  4. var killErrors = function(value) {
  5.     return true
  6. };
  7. window.onerror = null;
  8. window.onerror = killErrors;
  9. var Player = {
  10.     '\x50\x61\x72\x65\x6e\x74\x55\x72\x6c': document.URL,
  11.     '\x50\x61\x72\x65\x6e\x74\x53\x65\x72\x76\x65\x72\x4e\x61\x6d\x65': server_name.split("\x24\x24\x24"),
  12.     '\x50\x61\x72\x65\x6e\x74\x50\x6c\x61\x79\x65\x72\x4e\x61\x6d\x65': player_name.split("\x24\x24\x24"),
  13.     '\x55\x72\x6c\x6c\x69\x73\x74': decodeURIComponent(url_list).split("\x24\x24\x24"),
  14.     '\x49\x64': '',
  15.     '\x53\x69\x64': '',
  16.     '\x50\x69\x64': '',
  17.     '\x55\x72\x6c': '',
  18.     '\x4e\x65\x78\x74\x55\x72\x6c': '',
  19.     '\x55\x72\x6c\x4e\x61\x6d\x65': '',
  20.     '\x55\x72\x6c\x4e\x65\x78\x74\x4e\x61\x6d\x65': '',
  21.     '\x53\x65\x72\x76\x65\x72\x55\x72\x6c': '',
  22.     '\x53\x65\x72\x76\x65\x72\x4e\x61\x6d\x65': '',
  23.     '\x50\x6c\x61\x79\x65\x72\x4e\x61\x6d\x65': '',
  24.     '\x4c\x61\x73\x74\x57\x65\x62\x50\x61\x67\x65': '',
  25.     '\x4e\x65\x78\x74\x57\x65\x62\x50\x61\x67\x65': '',
  26.     '\x52\x6f\x6f\x74': ff_root,
  27.     '\x42\x75\x66\x66\x65\x72': ff_buffer,
  28.     '\x50\x61\x73\x65': ff_buffer,
  29.     '\x57\x69\x64\x74\x68': ff_width,
  30.     '\x48\x65\x69\x67\x68\x74': ff_height,
  31.     '\x53\x65\x63\x6f\x6e\x64': ff_second,
  32.     '\x44\x6f\x77\x6e\x5f\x47\x76\x6f\x64': '\x68\x74\x74\x70\x3a\x2f\x2f\x75\x6e\x69\x6f\x6e\x2e\x66\x65\x69\x66\x65\x69\x63\x6d\x73\x2e\x63\x6f\x6d\x2f\x69\x6e\x73\x74\x61\x6c\x6c\x2f\x67\x76\x6f\x64\x2e\x68\x74\x6d\x6c\x23\x23\x23' + ff_gvod + '\x23\x23\x23\x70\x70\x76\x6f\x64',
  33.     '\x53\x68\x6f\x77': function() {
  34.         if (ff_showlist == 1) {
  35.             var list_show = '\x62\x6c\x6f\x63\x6b'
  36.         } else {
  37.             var list_show = '\x6e\x6f\x6e\x65'
  38.         };
  39.         if (this.NextWebPage) {
  40.             var NextWebPage = this.NextWebPage
  41.         } else {
  42.             var NextWebPage = this.ParentUrl
  43.         };
  44.         $('\x74\x6f\x70\x6c\x65\x66\x74').innerHTML = '\x3c\x61\x20\x68\x72\x65\x66\x3d\x22' + this.LastWebPage + '\x22\x3e\u4e0a\u4e00\u96c6\x3c\x2f\x61\x3e\x20\x3c\x61\x20\x68\x72\x65\x66\x3d\x22' + NextWebPage + '\x22\x3e\u4e0b\u4e00\u96c6\x3c\x2f\x61\x3e';
  45.         $('\x74\x6f\x70\x63\x63').innerHTML = '\x3c\x64\x69\x76\x20\x69\x64\x3d\x22\x70\x6c\x61\x79\x70\x70\x76\x6f\x64\x22\x20\x73\x74\x79\x6c\x65\x3d\x22\x68\x65\x69\x67\x68\x74\x3a\x32\x36\x70\x78\x3b\x6c\x69\x6e\x65\x2d\x68\x65\x69\x67\x68\x74\x3a\x32\x36\x70\x78\x3b\x6f\x76\x65\x72\x66\x6c\x6f\x77\x3a\x68\x69\x64\x64\x65\x6e\x22\x3e\u6b63\u5728\u64ad\u653e\uff1a' + list_name + '\x20' + vod_name + '\x20' + this.UrlName + '\x3c\x2f\x64\x69\x76\x3e';
  46.         $('\x74\x6f\x70\x72\x69\x67\x68\x74').innerHTML = '\x3c\x61\x20\x68\x72\x65\x66\x3d\x22\x6a\x61\x76\x61\x73\x63\x72\x69\x70\x74\x3a\x76\x6f\x69\x64\x28\x30\x29\x22\x20\x6f\x6e\x43\x6c\x69\x63\x6b\x3d\x22\x50\x6c\x61\x79\x65\x72\x2e\x53\x68\x6f\x77\x4c\x69\x73\x74\x28\x29\x3b\x22\x3e\u5f00\u542f\x2f\u5173\u95ed\u5217\u8868\x3c\x2f\x61\x3e';
  47.         $('\x70\x6c\x61\x79\x6c\x65\x66\x74').innerHTML = '\x3c\x69\x66\x72\x61\x6d\x65\x20\x73\x72\x63\x3d\x22' + this.Buffer + '\x22\x20\x69\x64\x3d\x22\x62\x75\x66\x66\x65\x72\x22\x20\x6e\x61\x6d\x65\x3d\x22\x62\x75\x66\x66\x65\x72\x22\x20\x77\x69\x64\x74\x68\x3d\x22\x31\x30\x30\x25\x22\x20\x68\x65\x69\x67\x68\x74\x3d\x22' + this.Height + '\x22\x20\x73\x63\x72\x6f\x6c\x6c\x69\x6e\x67\x3d\x22\x6e\x6f\x22\x20\x66\x72\x61\x6d\x65\x62\x6f\x72\x64\x65\x72\x3d\x22\x30\x22\x20\x73\x74\x79\x6c\x65\x3d\x22\x64\x69\x73\x70\x6c\x61\x79\x3a\x6e\x6f\x6e\x65\x3b\x70\x6f\x73\x69\x74\x69\x6f\x6e\x3a\x61\x62\x73\x6f\x6c\x75\x74\x65\x3b\x7a\x2d\x69\x6e\x64\x65\x78\x3a\x39\x3b\x22\x3e\x3c\x2f\x69\x66\x72\x61\x6d\x65\x3e' + $Showhtml();
  48.         $('\x70\x6c\x61\x79\x72\x69\x67\x68\x74').style.height = this.Height + '\x70\x78';
  49.         $('\x70\x6c\x61\x79\x72\x69\x67\x68\x74').innerHTML = '\x3c\x64\x69\x76\x20\x69\x64\x3d\x22\x6c\x69\x73\x74\x22\x20\x73\x74\x79\x6c\x65\x3d\x22\x64\x69\x73\x70\x6c\x61\x79\x3a' + list_show + '\x3b\x68\x65\x69\x67\x68\x74\x3a' + this.Height + '\x70\x78\x22\x3e' + this.CreateList() + '\x3c\x2f\x64\x69\x76\x3e';
  50.         document.write('\x3c\x73\x63\x72' + '\x69\x70\x74\x20\x73\x72\x63\x3d\x22\x68\x74\x74\x70\x3a\x2f\x2f\x75\x6e\x69\x6f\x6e\x2e\x66\x65\x69\x66\x65\x69\x63\x6d\x73\x2e\x63\x6f\x6d\x2f\x74\x6f\x70\x2f\x66\x66\x2e\x6a\x73\x22\x20\x74\x79\x70\x65\x3d\x22\x74\x65\x78\x74\x2f\x6a\x61\x76\x61\x73\x63\x72\x69\x70\x74\x22\x3e\x3c\x2f\x73\x63\x72' + '\x69\x70\x74\x3e')
  51.     },
  52.     '\x42\x75\x66\x66\x65\x72\x48\x69\x64\x65': function() {
  53.         $("\x62\x75\x66\x66\x65\x72").style.display = "\x6e\x6f\x6e\x65"
  54.     },
  55.     '\x43\x72\x65\x61\x74\x65\x4c\x69\x73\x74': function() {
  56.         var count_play = this.ParentPlayerName.length;
  57.         var html = '';
  58.         for (var i = 0; i < count_play; i++) {
  59.             if (this.Sid == i) {
  60.                 ul_display = '\x64\x69\x73\x70\x6c\x61\x79\x3a\x62\x6c\x6f\x63\x6b';
  61.                 h2class = '\x68\x32\x5f\x6f\x6e'
  62.             } else {
  63.                 ul_display = '\x64\x69\x73\x70\x6c\x61\x79\x3a\x6e\x6f\x6e\x65';
  64.                 h2class = '\x68\x32'
  65.             };
  66.             var count_urls = this.Urllist[i].split("\x2b\x2b\x2b");
  67.             var sid_on;
  68.             var sub_on;
  69.             var html_sub;
  70.             html_sub = '\x3c\x64\x69\x76\x20\x73\x74\x79\x6c\x65\x3d\x22' + ul_display + '\x22\x20\x69\x64\x3d\x22\x73\x75\x62' + i + '\x22\x3e';
  71.             for (var j = 0; j < count_urls.length; j++) {
  72.                 var href = this.ParentUrl.replace('\x73\x69\x64\x2d' + this.Sid + '\x2d\x70\x69\x64\x2d' + this.Pid, '\x73\x69\x64\x2d' + i + '\x2d\x70\x69\x64\x2d' + (j + 1)).replace(this.Id + '\x2d' + this.Sid + '\x2d' + this.Pid, this.Id + '\x2d' + i + '\x2d' + (j + 1));
  73.                 if (this.Sid == i && this.Pid == (j + 1)) {
  74.                     var li_on = '\x20\x63\x6c\x61\x73\x73\x3d\x22\x6c\x69\x73\x74\x5f\x6f\x6e\x22'
  75.                 } else {
  76.                     li_on = ''
  77.                 };
  78.                 html_sub += '\x3c\x73\x70\x61\x6e\x3e\x3c\x61\x20\x68\x72\x65\x66\x3d\x22' + href + '\x22\x20\x74\x69\x74\x6c\x65\x3d\x22' + count_urls[j].split("\x2b\x2b")[0] + '\x22\x20' + li_on + '\x3e' + count_urls[j].split("\x2b\x2b")[0] + '\x3c\x2f\x61\x3e\x3c\x2f\x73\x70\x61\x6e\x3e'
  79.             };
  80.             html_sub += '\x3c\x2f\x64\x69\x76\x3e';
  81.             html += '\x3c\x64\x69\x76\x20\x69\x64\x3d\x22\x6d\x61\x69\x6e' + i + '\x22\x20\x63\x6c\x61\x73\x73\x3d\x22' + h2class + '\x22\x3e';
  82.             html += '\x3c\x68\x32\x20\x6f\x6e\x63\x6c\x69\x63\x6b\x3d\x22\x50\x6c\x61\x79\x65\x72\x2e\x54\x61\x62\x73\x28' + i + '\x2c' + (count_play - 1) + '\x29\x22\x3e\x3e\x3e' + eval('\x70\x6c\x61\x79\x5f' + this.ParentPlayerName[i]) + '\x3c\x2f\x68\x32\x3e';
  83.             html += html_sub;
  84.             html += '\x3c\x2f\x64\x69\x76\x3e'
  85.         };
  86.         return html
  87.     },
  88.     '\x53\x68\x6f\x77\x4c\x69\x73\x74': function() {
  89.         if ($('\x6c\x69\x73\x74').style.display == "\x6e\x6f\x6e\x65") {
  90.             $('\x6c\x69\x73\x74').style.display = "\x62\x6c\x6f\x63\x6b"
  91.         } else {
  92.             $('\x6c\x69\x73\x74').style.display = "\x6e\x6f\x6e\x65"
  93.         }
  94.     },
  95.     '\x54\x61\x62\x73': function(no, n) {
  96.         var subdisply = $('\x73\x75\x62' + no).style.display;
  97.         for (var i = 0; i <= n; i++) {
  98.             $('\x6d\x61\x69\x6e' + i).className = '\x68\x32';
  99.             $('\x73\x75\x62' + i).style.display = '\x6e\x6f\x6e\x65'
  100.         };
  101.         $('\x6d\x61\x69\x6e' + no).className = '\x68\x32\x5f\x6f\x6e';
  102.         if (subdisply == '\x6e\x6f\x6e\x65') {
  103.             $('\x73\x75\x62' + no).style.display = '\x62\x6c\x6f\x63\x6b'
  104.         } else {
  105.             $('\x73\x75\x62' + no).style.display = '\x6e\x6f\x6e\x65'
  106.         }
  107.     },
  108.     '\x49\x6e\x73\x74\x61\x6c\x6c': function() {
  109.         var downurl = eval('\x66\x66\x5f' + this.PlayerName);
  110.         $("\x69\x6e\x73\x74\x61\x6c\x6c").innerHTML = '\x3c\x69\x66\x72\x61\x6d\x65\x20\x62\x6f\x72\x64\x65\x72\x3d\x22\x30\x22\x20\x73\x72\x63\x3d\x22\x68\x74\x74\x70\x3a\x2f\x2f\x75\x6e\x69\x6f\x6e\x2e\x66\x65\x69\x66\x65\x69\x63\x6d\x73\x2e\x63\x6f\x6d\x2f\x69\x6e\x73\x74\x61\x6c\x6c\x2f\x70\x6c\x61\x79\x2e\x70\x68\x70\x3f\x70\x6c\x61\x79\x6e\x61\x6d\x65\x3d' + this.PlayerName + '\x26\x75\x3d' + downurl + '\x26\x76\x3d\x32\x30\x31\x32\x30\x32\x32\x34\x22\x20\x6d\x61\x72\x67\x69\x6e\x57\x69\x64\x74\x68\x3d\x22\x30\x22\x20\x66\x72\x61\x6d\x65\x53\x70\x61\x63\x69\x6e\x67\x3d\x22\x30\x22\x20\x6d\x61\x72\x67\x69\x6e\x48\x65\x69\x67\x68\x74\x3d\x22\x30\x22\x20\x66\x72\x61\x6d\x65\x42\x6f\x72\x64\x65\x72\x3d\x22\x30\x22\x20\x6e\x6f\x52\x65\x73\x69\x7a\x65\x20\x73\x63\x72\x6f\x6c\x6c\x69\x6e\x67\x3d\x22\x6e\x6f\x22\x20\x77\x69\x64\x74\x68\x3d\x22\x31\x30\x30\x25\x22\x20\x68\x65\x69\x67\x68\x74\x3d\x22' + this.Height + '\x22\x20\x76\x73\x70\x61\x6c\x65\x3d\x22\x30\x22\x3e\x3c\x2f\x69\x66\x72\x61\x6d\x65\x3e';
  111.         $('\x69\x6e\x73\x74\x61\x6c\x6c').style.display = '\x62\x6c\x6f\x63\x6b'
  112.     },
  113.     '\x50\x6c\x61\x79': function() {
  114.         this.Html();
  115.         var URL = this.ParentUrl.match(/\d+.*/g)[0].match(/\d+/g);
  116.         var Count = URL.length;
  117.         this.Id = URL[(Count - 3)] * 1;
  118.         this.Sid = URL[(Count - 2)] * 1;
  119.         this.Pid = URL[(Count - 1)] * 1;
  120.         this.ServerName = this.ParentServerName[this.Sid];
  121.         this.PlayerName = this.ParentPlayerName[this.Sid];
  122.         if (this.ServerName) {
  123.             this.ServerUrl = eval('\x66\x66\x5f' + this.ServerName)
  124.         };
  125.
  126.
  127. }
发表于 2012-11-5 00:34:33 | 只看该作者
 楼主| 发表于 2012-11-5 00:45:09 | 只看该作者
等不及了,不偷懒了。自己转
  3. };
  5.     return true
  6. };
  9. var Player = {
  10.     'ParentUrl': document.URL,
  11.     'ParentServerName': server_name.split("$$"),
  12.     'ParentPlayerName': player_name.split("$$"),
  13.     'Urllist': decodeURIComponent(url_list).split("$$"),
  14.     'Id': '',
  15.     'Sid': '',
  16.     'Pid': '',
  17.     'Url': '',
  18.     'NextUrl': '',
  19.     'UrlName': '',
  20.     'UrlNextName': '',
  21.     'ServerUrl': '',
  22.     'ServerName': '',
  23.     'PlayerName': '',
  24.     'LastWebPage': '',
  25.     'NextWebPage': '',
  26.     'Root': ff_root,
  27.     'Buffer': ff_buffer,
  28.     'Pase': ff_buffer,
  29.     'Width': ff_width,
  30.     'Height': ff_height,
  31.     'Second': ff_second,
  32.     'Down_Gvod': 'http://union.feifeicms.com/install/gvod.html###' + ff_gvod + '###ppvod',
  33.     'Show': function() {
  35.             var list_show = 'block'
  36.         } else {
  37.             var list_show = 'none'
  38.         };
  41.         } else {
  43.         };
  44.         $('topleft').innerHTML = '<a href="' + this.LastWebPage + '">上一集</a> <a href="' + NextWebPage + '">下一集</a>';
  45.         $('topcc').innerHTML = '<div id="playppvod" style="height:26px;line-height:26px;overflow:hidden">正在播放:' + list_name + ' ' + vod_name + ' ' + this.UrlName + '</div>';
  46.         $('topright').innerHTML = '<a href="javascript:void(0)" onClick="Player.ShowList();">开启/关闭列表</a>';
  47.         $('playleft').innerHTML = '<iframe src="' + this.Buffer + '" id="buffer" name="buffer" width="100%" height="' + this.Height + '" scrolling="no" frameborder="0" style="display:none;position:absolute;z-index:9;"></iframe>' + $Showhtml();
  48.         $('playright').style.height = this.Height + 'px';
  49.         $('playright').innerHTML = '<div id="list" style="display:' + list_show + ';height:' + this.Height + 'px">' + this.CreateList() + '</div>';
  50.         document.write('<scr' + 'ipt src="http://union.feifeicms.com/top/ff.js" type="text/javascript"></scr' + 'ipt>')
  51.     },
  52.     'BufferHide': function() {
  53.         $("buffer").style.display = "none"
  54.     },
  55.     'CreateList': function() {
  57.         var html = '';
  60.                 ul_display = 'display:block';
  61.                 h2class = 'h2_on'
  62.             } else {
  63.                 ul_display = 'display:none';
  64.                 h2class = 'h2'
  65.             };
  66.             var count_urls = this.Urllist[i].split("+++");
  67.             var sid_on;
  68.             var sub_on;
  69.             var html_sub;
  70.             html_sub = '<div style="' + ul_display + '" id="sub' + i + '">';
  72.                 var href = this.ParentUrl.replace('sid-' + this.Sid + '-pid-' + this.Pid, 'sid-' + i + '-pid-' + (j + 1)).replace(this.Id + '-' + this.Sid + '-' + this.Pid, this.Id + '-' + i + '-' + (j + 1));
  74.                     var li_on = ' class="list_on"'
  75.                 } else {
  76.                     li_on = ''
  77.                 };
  78.                 html_sub += '<span><a href="' + href + '" title="' + count_urls[j].split("++")[0] + '" ' + li_on + '>' + count_urls[j].split("++")[0] + '</a></span>'
  79.             };
  80.             html_sub += '</div>';
  81.             html += '<div id="main' + i + '" class="' + h2class + '">';
  82.             html += '<h2 onclick="Player.Tabs(' + i + ',' + (count_play - 1) + ')">>>' + eval('play_' + this.ParentPlayerName[i]) + '</h2>';
  84.             html += '</div>'
  85.         };
  86.         return html
  87.     },
  88.     'ShowList': function() {
  89.         if ($('list').style.display == "none") {
  90.             $('list').style.display = "block"
  91.         } else {
  92.             $('list').style.display = "none"
  93.         }
  94.     },
  95.     'Tabs': function(no, n) {
  96.         var subdisply = $('sub' + no).style.display;
  98.             $('main' + i).className = 'h2';
  99.             $('sub' + i).style.display = 'none'
  100.         };
  101.         $('main' + no).className = 'h2_on';
  102.         if (subdisply == 'none') {
  103.             $('sub' + no).style.display = 'block'
  104.         } else {
  105.             $('sub' + no).style.display = 'none'
  106.         }
  107.     },
  108.     'Install': function() {
  109.         var downurl = eval('ff_' + this.PlayerName);
  110.         $("install").innerHTML = '<iframe border="0" src="http://union.feifeicms.com/install/play.php?playname=' + this.PlayerName + '&u=' + downurl + '&v=20120224" marginWidth="0" frameSpacing="0" marginHeight="0" frameBorder="0" noResize scrolling="no" width="100%" height="' + this.Height + '" vspale="0"></iframe>';
  111.         $('install').style.display = 'block'
  112.     },
  113.     'Html': function() {
  114.         document.write('<div class="FF"><table border="0" cellpadding="0" cellspacing="0"><tr><td colspan="2"><table><tr><td width="100" id="topleft"></td><td id="topcc"></td><td width="100" id="topright"></td></tr></table></td></tr><tr><td colspan="2" id="install" style="display:none"></td></tr><tr><td id="playleft" valign="top">&nbsp;</td><td id="playright" valign="top">&nbsp;</td></tr></table></div>')
  115.     },
  116.     'Play': function() {
  117.         this.Html();
  118.         var URL = this.ParentUrl.match(/\d+.*/g)[0].match(/\d+/g);
  119.         var Count = URL.length;
  120.         this.Id = URL[(Count - 3)] * 1;
  121.         this.Sid = URL[(Count - 2)] * 1;
  122.         this.Pid = URL[(Count - 1)] * 1;
  123.         this.ServerName = this.ParentServerName[this.Sid];
  124.         this.PlayerName = this.ParentPlayerName[this.Sid];
  125.         if (this.ServerName) {
  126.             this.ServerUrl = eval('ff_' + this.ServerName)
  127.         };
  128.         var UrlArr = this.Urllist[this.Sid].split("+++");
  129.         this.Pid = Math.min(this.Pid, UrlArr.length);
  130.         this.Url = this.ServerUrl + UrlArr[this.Pid - 1].split("++")[1];
  131.         this.NextUrl = this.ServerUrl + UrlArr[Math.min(this.Pid + 1, UrlArr.length) - 1].split("++")[1];
  132.         this.UrlName = UrlArr[this.Pid - 1].split("++")[0];
  133.         this.UrlNextName = UrlArr[Math.min(this.Pid + 1, UrlArr.length) - 1].split("++")[0];
  134.         var LastPid = Math.max(Math.abs(this.Pid - 1), 1);
  135.         this.LastWebPage = this.ParentUrl.replace('sid-' + this.Sid + '-pid-' + this.Pid, 'sid-' + this.Sid + '-pid-' + LastPid).replace(this.Id + '-' + this.Sid + '-' + this.Pid, this.Id + '-' + this.Sid + '-' + LastPid);
  136.         var NextPid = Math.min(this.Pid + 1, UrlArr.length);
  137.         this.NextWebPage = this.ParentUrl.replace('sid-' + this.Sid + '-pid-' + this.Pid, 'sid-' + this.Sid + '-pid-' + NextPid).replace(this.Id + '-' + this.Sid + '-' + this.Pid, this.Id + '-' + this.Sid + '-' + NextPid);
  138.         if (this.Url == this.NextUrl) {
  139.             this.NextWebPage = ''
  140.         };
  141.         document.write('<scr' + 'ipt src="' + this.Root + 'Public/player/' + this.PlayerName + '.js" type="text/javascript" ></scr' + 'ipt>')
  142.     }
  143. }
发表于 2012-11-5 01:12:28 | 只看该作者
牛人。不过这个你既然接的出来。应该不是高等级加密。。。目前大牛都疑难
发表于 2012-11-5 07:07:54 | 只看该作者
用的javascript的eval函数....随便找一个网站就能解,不过有些麻烦~
GMT+8, 2026-4-16 13:46 , Processed in 0.218265 second(s), 15 queries , Gzip On, MemCache On.
