查看: 3205|回复: 8
WHMCS Security Alert
发表于 2012-10-6 05:47:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
www.whmcs.com
We have become aware of a security issue that exists in the third party Boleto
module included in WHMCS releases. This can potentially be used to exploit a
WHMCS installation.
If you do not use the Boleto module, then the quickest and easiest solution is
to simply delete the /modules/gateways/boleto/ folder entirely after which you
will not be at risk.
Alternatively if you do use the module, you can download and apply the patch to
your installation here: http://www.whmcs.com/members/dl.php?type=d&id=138
This issue affects all WHMCS versions.
If you have any questions or need any assistance, please do not hesitate to
contact us. We apologize for the inconvenience.
Kind Regards,
The WHMCS Team
www.whmcs.com
View the announcement on our website here to confirm authenticity:
http://forum.whmcs.com/showthread.php?60646-WHMCS-Security-Alert
Copyright (c) 2012 WHMCS Limited, All rights reserved.
Suite 17 Linford Forum
Rockingham Drive
Milton Keynes
MK14 6LY
发表于 2012-10-6 05:52:56 | 只看该作者
不睡了?
发表于 2012-10-6 06:22:26 | 只看该作者
因为某whmcs插件引起的问题,最快速的方法就是删除之。
发表于 2012-10-6 10:02:29 | 只看该作者
没有用不知道是什么 直接删除了
发表于 2012-10-6 11:21:57 来自手机 | 只看该作者
这个插件是做什么的?  直接删掉
发表于 2012-10-6 11:30:06 | 只看该作者
安装WHMCS后,首先把不认识的插件一一排除删掉
发表于 2012-10-6 11:39:32 | 只看该作者
不认识,X
发表于 2012-10-6 11:41:58 | 只看该作者
就没安装插件
发表于 2012-10-6 12:00:18 | 只看该作者
我不用那个东西
GMT+8, 2026-4-15 10:46 , Processed in 0.147166 second(s), 12 queries , Gzip On, MemCache On.
