查看: 3011|回复: 20
buyvm坑爹?资源滥用?
发表于 2012-9-15 04:25:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
This ticket is notification that your service with us (209.141.47.99) is now suspended for the following TOS/AUP infractions:
- Resources Abuse/Excessive Loads
As this is your first offense, no further administrative action will be taken. Upon your reply to this ticket, the service will be reactivated and you will have 24 hours to resolve this issue. Please be aware that further abuse reports after this time frame will constitute a second offense, resulting in suspension and a TOS/AUP Violation Fine.
Logs of the abuse follow:
(12:33:25) node50:~ root: abusescan
[loadscan] 16658 is exceeding 5 loads (9)
(12:36:28) node50:~ root: vzlist 16658
CTID NPROC STATUS IP_ADDR HOSTNAME
16658 42 running 209.141.47.99 taorongfu
(12:50:07) node50:~ root: grep 16658 /var/log/abusescan.log
Aug 07 08:38:17 node50 [loadscan] 16658 is exceeding 5 loads (6)
Sep 03 18:00:08 node50 [loadscan] 16658 is exceeding 5 loads (7)
Sep 03 18:05:02 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 03 18:10:04 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 03 18:15:01 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 03 18:30:01 node50 [loadscan] 16658 is exceeding 5 loads (7)
Sep 03 18:35:01 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 03 18:40:01 node50 [loadscan] 16658 is exceeding 5 loads (7)
Sep 03 18:45:02 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 04 13:40:15 node50 [loadscan] 16658 is exceeding 5 loads (6)
Sep 04 13:45:02 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 04 13:50:02 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 04 13:55:01 node50 [loadscan] 16658 is exceeding 5 loads (7)
Sep 05 21:25:06 node50 [loadscan] 16658 is exceeding 5 loads (7)
Sep 05 21:30:07 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 05 21:35:01 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 05 21:40:05 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 05 21:45:01 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 05 21:50:01 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 05 21:55:01 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 06 15:45:01 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 06 15:50:01 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 06 15:55:01 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 06 16:00:01 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 06 16:05:01 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 06 16:10:01 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 06 16:15:01 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 06 16:20:01 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 06 16:25:01 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 06 16:30:01 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 06 16:35:01 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 06 16:40:01 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 06 16:45:01 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 09 11:05:02 node50 [loadscan] 16658 is exceeding 5 loads (6)
Sep 09 11:10:03 node50 [loadscan] 16658 is exceeding 5 loads (7)
Sep 09 11:15:01 node50 [loadscan] 16658 is exceeding 5 loads (6)
Sep 10 01:21:50 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 10 01:30:01 node50 [loadscan] 16658 is exceeding 5 loads (6)
Sep 10 06:55:01 node50 [loadscan] 16658 is exceeding 5 loads (7)
Sep 10 08:20:03 node50 [loadscan] 16658 is exceeding 5 loads (7)
Sep 10 08:25:02 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 10 08:30:04 node50 [loadscan] 16658 is exceeding 5 loads (6)
Sep 10 10:00:04 node50 [loadscan] 16658 is exceeding 5 loads (6)
Sep 10 11:55:01 node50 [loadscan] 16658 is exceeding 5 loads (6)
Sep 10 13:42:33 node50 [loadscan] 16658 is exceeding 5 loads (6)
Sep 10 18:05:03 node50 [loadscan] 16658 is exceeding 5 loads (6)
Sep 10 18:10:05 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 11 02:47:48 node50 [loadscan] 16658 is exceeding 5 loads (7)
Sep 11 02:51:37 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 11 06:40:10 node50 [loadscan] 16658 is exceeding 5 loads (6)
Sep 11 06:45:01 node50 [loadscan] 16658 is exceeding 5 loads (7)
Sep 11 06:50:02 node50 [loadscan] 16658 is exceeding 5 loads (7)
Sep 11 08:50:02 node50 [loadscan] 16658 is exceeding 5 loads (6)
Sep 11 09:15:01 node50 [loadscan] 16658 is exceeding 5 loads (6)
Sep 11 09:20:05 node50 [loadscan] 16658 is exceeding 5 loads (6)
Sep 11 09:55:01 node50 [loadscan] 16658 is exceeding 5 loads (6)
Sep 11 10:10:01 node50 [loadscan] 16658 is exceeding 5 loads (6)
Sep 11 11:50:03 node50 [loadscan] 16658 is exceeding 5 loads (6)
Sep 11 11:55:04 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 11 12:00:21 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 11 12:05:04 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 11 12:10:03 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 11 12:15:06 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 11 12:20:23 node50 [loadscan] 16658 is exceeding 5 loads (6)
Sep 11 12:25:03 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 11 12:30:13 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 11 12:35:04 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 11 16:10:01 node50 [loadscan] 16658 is exceeding 5 loads (6)
Sep 12 06:45:03 node50 [loadscan] 16658 is exceeding 5 loads (6)
Sep 12 06:50:03 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 12 11:10:01 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 12 12:15:06 node50 [loadscan] 16658 is exceeding 5 loads (6)
Sep 12 12:20:07 node50 [loadscan] 16658 is exceeding 5 loads (7)
Sep 12 12:25:03 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 12 13:40:07 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 12 13:45:02 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 12 13:50:02 node50 [loadscan] 16658 is exceeding 5 loads (7)
Sep 12 13:55:03 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 12 14:00:13 node50 [loadscan] 16658 is exceeding 5 loads (7)
Sep 12 14:05:03 node50 [loadscan] 16658 is exceeding 5 loads (6)
Sep 12 14:20:04 node50 [loadscan] 16658 is exceeding 5 loads (7)
Sep 12 14:25:02 node50 [loadscan] 16658 is exceeding 5 loads (7)
Sep 12 16:47:13 node50 [loadscan] 16658 is exceeding 5 loads (16)
Sep 12 16:45:37 node50 [loadscan] 16658 is exceeding 5 loads (11)
Sep 12 16:51:05 node50 [loadscan] 16658 is exceeding 5 loads (16)
Sep 12 17:00:21 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 12 17:05:03 node50 [loadscan] 16658 is exceeding 5 loads (7)
Sep 12 21:30:03 node50 [loadscan] 16658 is exceeding 5 loads (6)
Sep 13 02:50:05 node50 [loadscan] 16658 is exceeding 5 loads (6)
Sep 13 02:55:01 node50 [loadscan] 16658 is exceeding 5 loads (7)
Sep 13 03:00:03 node50 [loadscan] 16658 is exceeding 5 loads (7)
Sep 13 04:55:02 node50 [loadscan] 16658 is exceeding 5 loads (6)
Sep 13 06:10:02 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 13 06:15:03 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 13 06:20:10 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 13 06:25:06 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 13 06:30:02 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 13 06:35:05 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 13 06:40:04 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 13 06:45:02 node50 [loadscan] 16658 is exceeding 5 loads (10)
Sep 13 06:50:01 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 13 06:55:03 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 13 07:00:05 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 13 07:05:03 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 13 07:10:02 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 13 07:15:08 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 13 07:20:01 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 13 07:25:02 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 13 07:30:01 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 13 07:35:01 node50 [loadscan] 16658 is exceeding 5 loads (7)
Sep 13 07:40:04 node50 [loadscan] 16658 is exceeding 5 loads (7)
Sep 13 07:45:02 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 13 07:50:15 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 13 07:55:04 node50 [loadscan] 16658 is exceeding 5 loads (8)
Sep 13 08:00:29 node50 [loadscan] 16658 is exceeding 5 loads (9)
Sep 13 08:05:04 node50 [loadscan] 16658 is exceeding 5 loads (8)
(12:50:14) node50:~ root:
Anthony, Frantech Support
[IRC] irc.frantech.ca / #frantech
[Wiki] http://wiki.frantech.ca/
 楼主| 发表于 2012-9-15 04:27:25 | 只看该作者
209.141.47.99
这IP也不是我的,我的是209.141.53.101 ,为什么警告的是209.141.47.99而停我的209.141.53.101?
没天理啊。还有我仅仅是做了反向代理而已,又没运行什么东西,而且全部静态化了。
难道是被ddcc了?
发表于 2012-9-15 06:44:20 | 只看该作者
目测是国人,发个TK过去问问说明情况。
发表于 2012-9-15 09:00:57 | 只看该作者
发表于 2012-9-15 09:01:54 | 只看该作者
发表于 2012-9-15 09:03:14 | 只看该作者
发表于 2012-9-15 09:05:24 | 只看该作者
伤天理啊
发表于 2012-9-15 09:09:48 | 只看该作者
发表于 2012-9-15 09:13:15 | 只看该作者
反正我是没用过
 楼主| 发表于 2012-9-15 09:31:51 | 只看该作者
就一个反带,上面什么东西都没有。不过可惜了我的流量,还有6t没用掉(我升级了好多t)
还有一台也在buyvm,我用的他们的sql,该死的今天数据库offline了好久了还没恢复,这上面到有我很重要的资料。而且严重影响业务。
GMT+8, 2026-4-21 18:14 , Processed in 0.164938 second(s), 13 queries , Gzip On, MemCache On.
