查看: 2673|回复: 12
dreamobjects 免费2月。。。
发表于 2012-9-13 16:23:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
DreamObjects is a cost-effective, public cloud storage service. You can access it through our Panel, programmatically via API, or a third-party app. It’s compatible with the APIs of Amazon S3 and Swift-based object storage services like Rackspace Cloud Files. DreamObjects is perfect for developers who need a scalable storage solution for their web apps and software projects. Tech-savvy individuals can also use DreamObjects to back up files, and inexpensively store terabytes of photos, music, and videos.
http://dreamhost.com/cloud/dreamobjects/
Storage plans lower your effective price per GB for storage below the 7¢/GB rate. If you exceed your plan’s included storage, then it’s just 7¢/GB for additional storage.
There are several storage plans available to best match your needs. After selecting a plan, you’ll prepay the plan price each month. If you change your mind, you can upgrade the plan at anytime, or downgrade the plan effective your next billing cycle.
The DreamObjects free trial is limited to two months and commences on your sign-up date. You may cancel the trial at any time before it concludes, at which point your data will be deleted within 48 hours.
During the free trial, you won’t incur any charges provided that you stay within the monthly allowances of 10GB of storage and 20GB of transfer out bandwidth. If you go over the free trial allowances, you will only be billed for the overage at the Usage-Based Billing rates of 7¢/GB per month for storage and 7¢/GB per month for transfer out bandwidth.
If you choose to continue using DreamObjects after the trial ends, then no action is required and you’ll be automatically billed for all usage at the Usage-Based Billing rates. If you wish to sign up for a pre-paid monthly storage plan, you may do so at any time.
发表于 2012-9-13 16:24:27 | 只看该作者
不需要了 亲
发表于 2012-9-13 16:24:37 | 只看该作者
全是鸟文啊。。
发表于 2012-9-13 16:25:54 | 只看该作者
10GB of storage and 20GB of transfer out bandwidth ...
发表于 2012-9-13 16:27:59 | 只看该作者
还没开始公测?
发表于 2012-9-13 16:30:38 | 只看该作者
这个没什么兴趣
发表于 2012-9-13 16:34:46 | 只看该作者
不感冒
发表于 2012-9-13 16:59:26 | 只看该作者
太小气了吧
发表于 2012-9-13 17:12:25 | 只看该作者
全是鸟文啊。。不懂啊
发表于 2012-9-13 18:14:14 | 只看该作者
鸟文,看不懂
GMT+8, 2026-4-14 22:26 , Processed in 0.146751 second(s), 13 queries , Gzip On, MemCache On.
