查看: 2726|回复: 3
[Windows VPS] 帮忙看看,godaddy发给我的关于域名的重要通知是干什么的
发表于 2012-6-8 14:49:47 | 只看该作者
验证你的域名联系人信息是否正确,正确就不用理会。
发表于 2012-6-8 14:48:49 | 只看该作者
 楼主| 发表于 2012-6-8 14:42:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我需要做什么动作
Dear XX,
Several months ago, you received a notice to review and update the contact information for your domain name(s). This is a follow-up to that email.
According to our records, you are the ADMINISTRATIVE CONTACT for the following domain names registered at GoDaddy.com (as of 6/7/2012):
XXX.COM
XXX.COM
XXXX.COM
To review/update your contact data:
        1.        You will need a copy of your Domain Information Key:
        xxx-XXXX-XXXX-XXXX-XXXX
         2.        Go to http://www.godaddy.com/icann/domain_search.aspx?prog_id=GoDaddy&isc=BBCNFAC
        3.        Input your Domain Information Key and review your contact information.
If you find that your domain contact data is current and accurate, there's no need to take action. If, however, your domain contact information is inaccurate, you must correct it. (Under ICANN rules and the terms of your registration agreement, PROVIDING FALSE CONTACT INFORMATION CAN BE GROUNDS FOR DOMAIN NAME CANCELLATION.) Review the ICANN policy.
发表于 2012-6-8 14:56:26 | 只看该作者
验证一下即可...
GMT+8, 2026-4-14 19:16 , Processed in 0.124267 second(s), 13 queries , Gzip On, MemCache On.
