查看: 2155|回复: 6
[Windows VPS] 安装的kloxo 网站后台备份数据出现这个错误 求解决
发表于 2012-5-9 16:33:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Error ERROR: This backup script seldom works when safe_mode is enabled or open_basedir restrictions are in effect.
If you get no errors doing a backup, check to see whether the file is less than 200kb. If so, then the backup is likely unreliable.
Error ERROR: Your server's "exec()" command has been disabled. This script cannot run. Ask your host if they are willing to re-enable PHP exec().
发表于 2012-5-9 16:50:27 | 只看该作者
kloxo彻底完蛋了 没得救了  不建议用
发表于 2012-5-9 16:59:56 | 只看该作者
PHP安全模式(safe_mode)改为不支持,取消exec()禁用,再试试看
发表于 2012-5-9 19:17:25 | 只看该作者
发表于 2012-5-9 19:19:47 | 只看该作者
cnx 发表于 2012-5-9 19:17
发表于 2012-5-9 18:33:29 | 只看该作者
发表于 2012-5-9 18:34:48 | 只看该作者
早不用它了
GMT+8, 2026-4-27 15:17 , Processed in 0.118849 second(s), 12 queries , Gzip On, MemCache On.
