查看: 5451|回复: 31
dedipath杜甫测评
发表于 2023-5-27 20:48:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Intel Xeon E3-1240v2
Los Angeles Dedicated Servers
Intel Xeon E3-1240v2$45.00 USD
» Location: First Available$0.00 USD
» Hard Drive: 2TB Enterprise Hard Drive$0.00 USD
» Secondary Hard Drive: None$0.00 USD
» Memory: 16GB DDR3 RAM$0.00 USD
» IP Addresses: /29 IPv4 (5 Usable IPs)$0.00 USD
» DDoS Protection: 10Tbps On Demand Network Level Protection$0.00 USD
» Operating System: IPMI$0.00 USD
» Bandwidth: 1Gbps Unmetered$0.00 USD
Setup Fees0.00 USD
Monthly45.00 USD
  1. Basic System Information:
  3. Uptime     : 0 days, 0 hours, 19 minutes
  4. Processor  : Intel(R) Xeon(R) CPU E3-1240 V2 @ 3.40GHz
  5. CPU cores  : 8 @ 1600.163 MHz
  6. AES-NI     : ✔ Enabled
  7. VM-x/AMD-V : ✔ Enabled
  8. RAM        : 31.3 GiB
  9. Swap       : 980.0 MiB
  10. Disk       : 227.3 GiB
  11. Distro     : Ubuntu 20.04 LTS
  12. Kernel     : 5.4.0-26-generic
  13. VM Type    : NONE
  14. IPv4/IPv6  : ✔ Online / ❌ Offline
  15. IPv4 Network Information:
  16. ---------------------------------
  17. ISP        : DediPath
  18. ASN        : AS35913 DediPath
  19. Host       : DediPath
  20. Location   : Los Angeles, California (CA)
  21. Country    : United States
  22. fio Disk Speed Tests (Mixed R/W 50/50):
  23. ---------------------------------
  24. Block Size | 4k            (IOPS) | 64k           (IOPS)
  25.   ------   | ---            ----  | ----           ----
  26. Read       | 144.34 MB/s  (36.0k) | 169.85 MB/s   (2.6k)
  27. Write      | 144.72 MB/s  (36.1k) | 170.75 MB/s   (2.6k)
  28. Total      | 289.06 MB/s  (72.2k) | 340.61 MB/s   (5.3k)
  29.            |                      |
  30. Block Size | 512k          (IOPS) | 1m            (IOPS)
  32. Read       | 222.56 MB/s    (434) | 240.15 MB/s    (234)
  33. Write      | 234.38 MB/s    (457) | 256.15 MB/s    (250)
  34. Total      | 456.94 MB/s    (891) | 496.30 MB/s    (484)
  35. iperf3 Network Speed Tests (IPv4):
  36. ---------------------------------
  37. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  38. -----           | -----                     | ----            | ----            | ----
  39. Clouvider       | London, UK (10G)          | busy            | 188 Mbits/sec   | 136 ms
  40. Scaleway        | Paris, FR (10G)           | busy            | 141 Mbits/sec   | 140 ms
  41. NovoServe       | North Holland, NL (40G)   | busy            | 543 Mbits/sec   | 142 ms
  42. Uztelecom       | Tashkent, UZ (10G)        | 736 Mbits/sec   | 69.2 Mbits/sec  | 235 ms
  43. Clouvider       | NYC, NY, US (10G)         | 889 Mbits/sec   | 92.8 Mbits/sec  | 72.4 ms
  44. Clouvider       | Dallas, TX, US (10G)      | 920 Mbits/sec   | 837 Mbits/sec   | 31.9 ms
  45. Clouvider       | Los Angeles, CA, US (10G) | 941 Mbits/sec   | 942 Mbits/sec   | 0.888 ms
  46. Geekbench 6 Benchmark Test:
  47. ---------------------------------
  48. Test            | Value
  49.                 |
  50. Single Core     | 319
  51. Multi Core      | 1218
  52. Full Test       | https://browser.geekbench.com/v6/cpu/1393799
  53. YABS completed in 20 min 5 sec
这数据,还真不如30刀的VPS。。。还好只买了一个月。
重启了下,竟然连不上SSH了。发了ticket才解决。
这价位,大容量的杜甫有啥推荐的吗?
发表于 2023-5-27 21:18:01 来自手机 | 只看该作者
我是c罗 发表于 2023-5-27 21:11
不太懂,第一次买杜甫。能说说啥问题吗
标配内存16,你的32,偷着乐吧
发表于 2023-5-27 20:51:40 | 只看该作者
好垃圾呀,为啥不买HZ的机器。
发表于 2023-5-27 20:52:42 来自手机 | 只看该作者
你竟然没发现你内存中奖了???
发表于 2023-5-27 20:52:55 | 只看该作者
E3 分这么低不正常,看频率很低,不会散热风扇坏了吧
 楼主| 发表于 2023-5-27 20:53:29 | 只看该作者
v2w3.com 发表于 2023-5-27 20:51
好垃圾呀,为啥不买HZ的机器。
之前买了他们家VPS,刚好账号里还有钱。。太垃了。。。。
发表于 2023-5-27 21:07:52 | 只看该作者
8核1218分,还没人家单核高
 楼主| 发表于 2023-5-27 21:11:27 | 只看该作者
xiaosong 发表于 2023-5-27 20:52
你竟然没发现你内存中奖了???
不太懂,第一次买杜甫。能说说啥问题吗
发表于 2023-5-27 21:15:44 | 只看该作者
交付的有点意思,内存翻倍了,但是给的是250GSSD。
 楼主| 发表于 2023-5-27 21:17:59 | 只看该作者
卧槽,好像是。。。咋会这样
GMT+8, 2026-4-22 07:54 , Processed in 0.068111 second(s), 11 queries , Gzip On, MemCache On.
