查看: 967|回复: 3
这小鸡怎样
发表于 2012-3-26 12:16:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. [root@st ~]# df -h
  2. Filesystem            Size  Used Avail Use% Mounted on
  3. /dev/simfs             50G  545M   50G   2% /
  4. none                  2.0G  4.0K  2.0G   1% /dev
  5. [root@st ~]# free -m
  6.              total       used       free     shared    buffers     cached
  7. Mem:          4096         22       4073          0          0          0
  8. -/+ buffers/cache:         22       4073
  9. Swap:            0          0          0
  10. [root@st ~]# dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
  11. 4096+0 records in
  12. 4096+0 records out
  13. 268435456 bytes (268 MB) copied, 10.3649 seconds, 25.9 MB/s
  14. [root@st ~]# dd if=/dev/zero of=test bs=64k count=16k conv=fdatasync
  15. 16384+0 records in
  16. 16384+0 records out
  17. 1073741824 bytes (1.1 GB) copied, 25.4241 seconds, 42.2 MB/s
  18. [root@st ~]# wget -O /dev/null http://cachefly.cachefly.net/100mb.test
  19. --2012-03-26 08:19:07--  http://cachefly.cachefly.net/100mb.test
  20. Resolving cachefly.cachefly.net... 205.234.175.175
  21. Connecting to cachefly.cachefly.net|205.234.175.175|:80... connected.
  22. HTTP request sent, awaiting response... 200 OK
  23. Length: 104857600 (100M) [application/octet-stream]
  24. Saving to: `/dev/null'
  25. 100%[=================================================================>] 104,857,600 11.2M/s   in 9.2s
  26. 2012-03-26 08:19:17 (10.9 MB/s) - `/dev/null' saved [104857600/104857600]
  27. [root@st ~]#
单盘 ,没raid啥的。。。
发表于 2012-3-26 12:16:46 | 只看该作者
帮顶
发表于 2012-3-26 12:16:48 | 只看该作者
好鸡
发表于 2012-3-26 12:17:26 | 只看该作者
人工置顶
GMT+8, 2026-4-21 00:17 , Processed in 0.184753 second(s), 12 queries , Gzip On, MemCache On.
