查看: 6598|回复: 26
[疑问] 远离坛子,努力了半年,到了个网速极快的地方.
发表于 2012-3-17 04:45:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
远离了坛子快半年了,努力了下,到了个网速极快的地方.
真想干点事还是远离论坛花时间真正学点知识才对.
普通办公电脑,非服务器.
有好几位在一个多月前PM我要山寨google的ngnix代码和logo的朋友,我这回复下,同时也PM提醒了,希望能看到(在PM里贴长串代码会变乱).
使用方法就是把这些代码放到nginx的.conf配置文件里去.
  1. server
  2.         {
  3.                 listen       443;
  4.                 server_name  900913.net;
  5.                 ssl on;
  6.                 ssl_certificate /root/900913net/900913_net.crt;
  7.                 ssl_certificate_key /root/900913net/900913_net.pem;
  8.                 ssl_protocols SSLv3 TLSv1;
  9.                 ssl_ciphers ALL:-ADH:+HIGH:+MEDIUM:-LOW:-SSLv2:-EXP;
  10.
  11.                 location / {
  12.
  13.                 proxy_redirect off;
  14.                 proxy_set_header X-Real-IP $remote_addr;
  15.                 proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
  16.                 proxy_set_header X-Forwarded-Proto https;
  17.                 proxy_pass https://encrypted.google.com;
  18.                 }
  19.
  20.                 location ~ /images/logos/ssl_logo.png {
  21.                 rewrite ^/ https://www.900913.net/900913_logo.png;
  22.                 }
  23.
  24.                 location ~ /images/logos/ssl_logo_srp.png {
  25.                 rewrite ^/ https://www.900913.net/900913_logo_srp.png;
  26.                 }
  27.
  28.
  29.                 location ~ /intl/en_com/images/srpr/logo3w.png {
  30.                 rewrite ^/ https://www.900913.net/900913_logo.png;
  31.                 }
  32.                 location ~ /images/srpr/logo3w.png {
  33.                 rewrite ^/ https://www.900913.net/900913_logo.png;
  34.                 }
  35.                 location ~ /images/nav_logo86.png {
  36.                 rewrite ^/ https://www.900913.net/900913_logo_srp.png;
  37.                 }
  38.
  39.                 log_format  900913.net  '$remote_addr - $remote_user [$time_local] $request '
  40.                '$status $body_bytes_sent $http_referer '
  41.                '$http_user_agent $http_x_forwarded_for';
  42.                 access_log  /home/wwwlogs/900913.net.log  900913.net;
  43.         }
  44.
  45.         server
  46.         {
  47.                 listen       80;
  48.                 server_name  900913.net;
  49.                 rewrite ^(.*) https://900913.net/$1 permanent;
  50.         }
  51.
  52.         server
  53.         {
  54.                 listen       80;
  55.                 server_name  www.900913.net;
  56.                 rewrite ^(.*) https://900913.net/$1 permanent;
  57.         }
  58.
别攻击啊,我懒得隐藏域名了.
我这是便民服务,自己都没用的.
上次贴了下被d的vps商把我机器关了.
发表于 2012-3-17 04:56:01 | 只看该作者
不会用
发表于 2012-3-17 05:07:00 | 只看该作者
代码怎么用啊??
发表于 2012-3-17 05:30:02 | 只看该作者
楼主在roma?
 楼主| 发表于 2012-3-17 05:33:27 | 只看该作者
guaku 发表于 2012-3-17 05:30
楼主在roma?
恩,这几月应该都在,你也在?
发表于 2012-3-17 05:40:51 | 只看该作者
这网速简直就是威武
发表于 2012-3-17 05:41:12 | 只看该作者
znithy 发表于 2012-3-17 05:33
恩,这几月应该都在,你也在?
我离roma 2个小时车程,楼主在在做什么课题?看到Istituto Nazionale di Fisica Nucleare 。。。。。
发表于 2012-3-17 05:46:20 | 只看该作者
快乐居士 发表于 2012-3-17 05:40
这网速简直就是威武
看到提供商没。。。。
意大利 国家核物理研究所
 楼主| 发表于 2012-3-17 05:50:22 | 只看该作者
vagaa 发表于 2012-3-17 05:07
代码怎么用啊??
你知道nginx的nginx.conf文件吗?
把这些代码复制进去再重启下nginx就行.
复制的地方你看nginx.conf文件,里面有差不多server{}什么的,就复制到差不多的地方就行.
我的配置文件里有ssl证书的信息,如果你没证书的话需要自己伪造个,这个你自己搜索贴子学习下,要不然不能https连接.
 楼主| 发表于 2012-3-17 05:53:35 | 只看该作者
我在做高能天体物理相关的课题,偏理论的,才来了半个月.
你是在这儿读书还是工作?
GMT+8, 2026-4-14 10:53 , Processed in 0.118044 second(s), 12 queries , Gzip On, MemCache On.
