查看: 2187|回复: 9
[Windows VPS] The page cannot be displayed
发表于 2012-2-18 10:02:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings.
Please try the following:
Click the  Refresh button, or try again later.
If you typed the page address in the Address bar, make sure that it is spelled correctly.
To check your connection settings, click the Tools menu, and then click Internet Options. On the Connections tab, click Settings. The settings should match those provided by your local area network (LAN) administrator or Internet service provider (ISP).
See if your Internet connection settings are being detected. You can set Microsoft Windows to examine your network and automatically discover network connection settings (if your network administrator has enabled this setting).
Click the Tools menu, and then click Internet Options.
On the Connections tab, click LAN Settings.
Select Automatically detect settings, and then click OK.
Some sites require 128-bit connection security. Click the Help menu and then click About Internet Explorer to determine what strength security you have installed.
If you are trying to reach a secure site, make sure your Security settings can support it. Click the Tools menu, and then click Internet Options. On the Advanced tab, scroll to the Security section and check settings for SSL 2.0, SSL 3.0, TLS 1.0, PCT 1.0.
Click the  Back button to try another link.
Cannot find server or DNS Error
Internet Explorer
网站经常性的刷不出首页来,再刷新一下首页就是正常,排除本地上网原因。到底是DNS缘故还网站的原因。
我的域名是在name.com的,Dns也是用name.com的。网站服务器是在国内。始终找不到问题原因在哪里?
发表于 2012-2-18 10:03:00 | 只看该作者
都看看,先换he的dns试试,之后不行的话就是服务器问题了
发表于 2012-2-18 10:03:37 | 只看该作者
你的电脑问题
发表于 2012-2-18 10:04:53 | 只看该作者
墙的关系,我的最近也常这样, DNS莫名其妙被重置的老IP上
 楼主| 发表于 2012-2-18 10:08:57 | 只看该作者
Qpuer 发表于 2012-2-18 10:03
你的电脑问题
这个可以排除,我在不同地点的电脑打开,都有刷不出来的情况。
发表于 2012-2-18 10:57:49 | 只看该作者
可能DNS坏了
 楼主| 发表于 2012-2-18 11:03:43 | 只看该作者
勾选了集成windows验证,目前没遇到刷不出首页的情况。
继续观察。
 楼主| 发表于 2012-2-18 16:29:53 | 只看该作者
还是不行。什么办法都试了。
发表于 2012-2-18 16:41:07 | 只看该作者
 楼主| 发表于 2012-2-19 12:06:44 | 只看该作者
ip能ping通,但网页无法显示。
GMT+8, 2026-4-29 09:17 , Processed in 0.066983 second(s), 12 queries , Gzip On, MemCache On.
