查看: 3262|回复: 1
cannot execute binary file: Exec format error
发表于 2016-2-24 21:03:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/serverspeeder/bin/serverSpeeder.sh: line 1348: /serverspeeder/bin/acce-3.11.20.4-[Ubuntu_14.04_3.13.0-74-generic]: cannot execute binary file: Exec format error
Load ServerSpeeder failed!
谁知道啥问题???
root@ubuntu-512mb-sfo1-01:/var/rs# ./install.sh
Installation done!
You are about to be asked to enter information that will be used by ServerSpeeder,
there are several fields and you can leave them blank,
for all fields there will be a default value.
Enter your accelerated interface(s) [eth0]:
Enter your outbound bandwidth [1000000 kbps]:
Enter your inbound bandwidth [1000000 kbps]:
Notice:After set shorttRtt-bypass value larger than 0,
it will bypass(not accelerate) all first flow from same 24-bit
network segment and the flows with RTT lower than the shortRtt-bypass value
Configure shortRtt-bypass [0 ms]:
Auto load ServerSpeeder on linux start-up? [n]:y
Run ServerSpeeder now? [y]:y
发表于 2016-2-24 21:54:53 | 只看该作者
看起来 你脚本都报错了...
GMT+8, 2026-4-27 00:34 , Processed in 0.127410 second(s), 12 queries , Gzip On, MemCache On.
