查看: 674|回复: 3
[dns.be #114371] domain name xxx.be
发表于 2012-2-2 20:49:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Dear .be registrant,
DNS.be is the official technical manager (also known as registry operator) for
all domain names with a .be extension.
You can find more information about our organization on our website: www.dns.be
You have received this message because DNS.be is currently carrying out an
investigation concerning the reliability of the contact data in our
registration system.
DNS.be kindly invites you to verify the contact data mentioned below. In case
your contact information appears to be incorrect, please contact your registrar
#naam registrar# urgently in order to set things straight.
If incorrect contact data are not rectified, your domain name(s) can be revoked
by DNS.be. You can always check your contact data through the WHOIS-search
function on our website: http://www.dns.be/en/home
Currently, our registration systems disposes of the following contact
information related to you and your .be domain name(s):
发表于 2012-2-2 20:52:15 | 只看该作者
发表于 2012-2-2 20:58:56 | 只看该作者
改的 看上去像真的呗........
发表于 2012-2-2 21:00:33 | 只看该作者
干嘛的
GMT+8, 2026-4-16 08:45 , Processed in 0.169183 second(s), 11 queries , Gzip On, MemCache On.
