查看: 1412|回复: 7
[美国VPS] 有没有老哥按照NextAarry的要求迁移完数据的
发表于 2022-6-13 09:07:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
收到了NextAarray的迁移邮件,说要停掉现有的vps然后搬到云上。但是配置有没有变化也没说,点进去网站也没有说迁移方案是啥,甚至看不到一点有关迁移的提示信息。
Hello,
Greetings!! At Nextarray LLC., it has always been our top priority to provide the best possible hosting services on budget. We will like to inform you that we are retiring our legacy VPS products and moving all our existing VPS customers to our cloud environment. Please be assured that your current price will remain unchanged but we will need to terminate your current virtual machine and set up a new cloud VM for you.
We will shut down these legacy VPS products on 30th June 2022. Please make sure you move your services to the cloud before that to avoid downtime.
Our OpenStack Cloud Features
Compute Node
Our current environment has 376 physical cores and over 3TB of active RAM available. This allows us to provide large amounts of VPSs quickly.
Ceph Storage
Our Ceph environment was built for speed while focusing on not breaking the bank. We have over 60TB of active Storage available and allow for 150MB/s to 600MB/s across our ceph cluster.
Network
Our Ceph storage was built with a 40Gbps uplink across each storage node. We also, put dual 10Gbps ports on each of our compute nodes allowing us to maximize our entire environment.
Deployment / Expanding
One main reason we went with Ceph and Openstack was the ability for clients to expand as they needed and the ability to grow with your needs.
You can find more details here
https://nextarray.com/optimized-cloud-vps
Please do not hesitate to contact us if you have any questions.
发表于 2022-6-13 09:23:01 | 只看该作者
NextAarray家实力这么强悍啊 666
发表于 2022-6-13 09:37:25 来自手机 | 只看该作者
我的搬完了
 楼主| 发表于 2022-6-13 09:57:27 | 只看该作者
配置有没有变化,还有搬到哪,直接新开个云服务?
发表于 2022-6-13 10:14:26 | 只看该作者
打开一个票,他们会创建一个Cloud VPS
硬盘不够的,可以选择迁移到 N1.Tiny (我看到票是这样处理的,不代表实际消息)
 楼主| 发表于 2022-6-13 10:41:25 | 只看该作者
硬盘不够的,可以选择迁移到 N1.Tiny (我看到票是这样处理的,不代 ...
发工单开?配置会变吗
发表于 2022-6-13 13:54:04 | 只看该作者
https://loc.qiche.eu.org/thread-1031370-1-1.html
发表于 2022-6-13 14:15:44 | 只看该作者
机智的千层饼 发表于 2022-6-13 10:41
发工单开?配置会变吗
貌似默认直接给你个最低配?
  1. - 1 vCPU
  2. - 1GB RAM
  3. - 10GB Full SSD Storage
  4. - 1TB/mo. on 1Gbps Uplink
  5. - Control Panel
  6. - 24/7 Support
GMT+8, 2026-4-27 12:57 , Processed in 0.059481 second(s), 10 queries , Gzip On, MemCache On.
