查看: 1611|回复: 12
nextarray的VPS迁移。
发表于 2022-6-11 19:40:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
迁移后价格不变,但配置有变化
原来的1刀机器2核/1G/25G/100M,
新机器1核/1G/10G/G口
下面的测试图的新机器实际为PY来的n1.tiny package,和最低配的n1.micro package区别就一个硬盘10G,一个是25G。
https://portal.nextarray.com/aff.php?aff=68
Hello,
Greetings!! At Nextarray LLC., it has always been our top priority to provide the best possible hosting services on budget. We will like to inform you that we are retiring our legacy VPS products and moving all our existing VPS customers to our cloud environment. Please be assured that your current price will remain unchanged but we will need to terminate your current virtual machine and set up a new cloud VM for you.
We will shut down these legacy VPS products on 30th June 2022. Please make sure you move your services to the cloud before that to avoid downtime.
Our OpenStack Cloud Features
Compute Node
Our current environment has 376 physical cores and over 3TB of active RAM available. This allows us to provide large amounts of VPSs quickly.
Ceph Storage
Our Ceph environment was built for speed while focusing on not breaking the bank. We have over 60TB of active Storage available and allow for 150MB/s to 600MB/s across our ceph cluster.
Network
Our Ceph storage was built with a 40Gbps uplink across each storage node. We also, put dual 10Gbps ports on each of our compute nodes allowing us to maximize our entire environment.
Deployment / Expanding
One main reason we went with Ceph and Openstack was the ability for clients to expand as they needed and the ability to grow with your needs.
You can find more details here
https://nextarray.com/optimized-cloud-vps
Please do not hesitate to contact us if you have any questions.
NextArray LLC.
http://portal.nextarray.com
旧1刀机:
新1刀机:
发表于 2022-6-11 20:39:50 | 只看该作者
商家信用问题
发表于 2022-6-11 19:47:04 | 只看该作者
原来可是不限流量,现在的1T吧,就很垃圾了
 楼主| 发表于 2022-6-11 19:58:27 | 只看该作者
哈哈,对流量用量大的确实,我是拿来做魔方云主控用的还好,一个月100G都用不到。
发表于 2022-6-11 20:01:38 | 只看该作者
迁移还会改配置吗?
那就感觉没意思了
发表于 2022-6-11 20:04:37 | 只看该作者
砍掉1核  减掉了n-1T流量
发表于 2022-6-11 20:05:38 来自手机 | 只看该作者
迁移是被强制迁移还是自己发工单迁
发表于 2022-6-11 20:08:06 来自手机 | 只看该作者
本以为是传家宝
 楼主| 发表于 2022-6-11 20:14:11 | 只看该作者
server0608 发表于 2022-6-11 20:05
迁移是被强制迁移还是自己发工单迁
发表于 2022-6-11 20:25:55 | 只看该作者
突然觉得我的1.5$不香了。
发表于 2022-6-11 20:27:08 | 只看该作者
tomcb 发表于 2022-6-11 20:14
We will shut down these legacy VPS products on 30th June 2022. Please make sure you move your serv ...
呜呜呜
GMT+8, 2026-4-27 16:04 , Processed in 0.070299 second(s), 11 queries , Gzip On, MemCache On.
