查看: 1841|回复: 7
virmach JP 40号节点重启试试,不行话的重装系统
发表于 2022-4-10 19:12:31 来自手机 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Your service on TYOC040 will be rebooted as part of maintenance. We apologize for the lack of warning, but this has been causing the service to be slow over the last 2-3 days and we believe a reboot should resolve the problem. Please note, after a reboot, there will still be some overloading caused by CentOS 5.8 virtual servers. Please re-install your operating system if you still have it on this incorrect default operating system from earlier provisionings.
Thank you.
发表于 2022-4-10 19:16:12 | 只看该作者
突然发现我的头像有点应景
发表于 2022-4-10 20:01:58 | 只看该作者
重启试了试,有改善,但还是不行,一会儿重新装系统试试。
Speedtest.net    9.96 Mbit/s       16.77 Mbit/s        (*)710.32 ms
Fast.com         0.00 Mbit/s       6.2 Mbit/s          -
Nanjing 5G   CT  44.79 Mbit/s      3.19 Mbit/s         528.95 ms
Hefei 5G     CT  77.95 Mbit/s      70.70 Mbit/s        91.14 ms
Guangzhou 5G CT  0.60 Mbit/s       2.70 Mbit/s         251.20 ms
TianJin 5G   CU  16.99 Mbit/s      0.58 Mbit/s         221.94 ms
Shanghai 5G  CU  12.61 Mbit/s      0.60 Mbit/s         438.38 ms
Wuxi 5G      CM  30.82 Mbit/s      98.98 Mbit/s        182.71 ms
发表于 2022-4-10 20:03:43 | 只看该作者
不需要去重启,因为会自动重启,建议直接重装。
发表于 2022-4-10 20:27:28 | 只看该作者
Node Name        Upload Speed      Download ...
是母鸡重启
发表于 2022-4-10 20:40:46 | 只看该作者
重装了,有改善。
I/O Speed( 1.0GB )   : 783 MB/s
I/O Speed( 1.0GB )   : 1.2 GB/s
I/O Speed( 1.0GB )   : 1.1 GB/s
Average I/O Speed    : 1046.1 MB/s
Speedtest.net    137.94 Mbit/s     132.12 Mbit/s       3.45 ms
Fast.com         0.00 Mbit/s       153.8 Mbit/s        -
Nanjing 5G   CT  68.76 Mbit/s      265.31 Mbit/s       201.41 ms
Hefei 5G     CT  17.38 Mbit/s      69.91 Mbit/s        55.79 ms
Guangzhou 5G CT  0.50 Mbit/s       3.37 Mbit/s         165.84 ms
TianJin 5G   CU  6.41 Mbit/s       0.60 Mbit/s         253.34 ms
Shanghai 5G  CU  72.19 Mbit/s      0.95 Mbit/s         247.61 ms
Wuxi 5G      CM  132.76 Mbit/s     120.50 Mbit/s       79.04 ms
Nanjing 5G   CM  31.78 Mbit/s      36.60 Mbit/s        97.14 ms
Hefei 5G     CM  132.45 Mbit/s     208.01 Mbit/s       71.61 ms
发表于 2022-4-10 20:43:56 | 只看该作者
I'm beginning to suspend people booting into kernel panic on TYOC040. Suspension reason will be: "OS is causing overloading. Contact Priority Support."
Just make a ticket if you're one of these people, in the priority department, and I'll try to get it sorted with you ASAP.
有些人的系统会引起kernel panic,每次panic都会导致网络拥堵,老板好像暂时停了一些内核的启动,遇到上面的原因,直接发ticket就行
发表于 2022-4-10 20:52:10 | 只看该作者
madegehaol1 发表于 2022-4-10 20:43
I'm beginning to suspend people booting into kernel panic on TYOC040. Suspension reason will be: "OS ...
因为40一开始就有毛病,一堆centos5.8的系统,
GMT+8, 2026-4-16 02:12 , Processed in 0.071786 second(s), 11 queries , Gzip On, MemCache On.
