查看: 771|回复: 4
[特价VPS] 出Hetzner的芬兰AX161
发表于 2022-3-29 21:48:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
出Hetzner的芬兰AX161
具体配置:
https://www.hetzner.com/dedicated-rootserver/ax161/configurator#/
AMD EPYC 7502P 32 Cores "Rome"
4 x 32 GB DDR4 ECC
960 GB NVMe SSD Datacenter Edition
Primary IPv4
=== START OF INFORMATION SECTION ===
Model Number:                       SAMSUNG MZQL2960HCJR-00A07
Serial Number:                      S64FNE0R901311
Firmware Version:                   GDC5302Q
PCI Vendor/Subsystem ID:            0x144d
IEEE OUI Identifier:                0x002538
Total NVM Capacity:                 960,197,124,096 [960 GB]
Unallocated NVM Capacity:           0
Controller ID:                      6
NVMe Version:                       1.4
Number of Namespaces:               32
Local Time is:                      Tue Mar 29 21:38:29 2022 CST
Firmware Updates (0x17):            3 Slots, Slot 1 R/O, no Reset required
Optional Admin Commands (0x005f):   Security Format Frmw_DL NS_Mngmt Self_Test MI_Snd/Rec
Optional NVM Commands (0x005f):     Comp Wr_Unc DS_Mngmt Wr_Zero Sav/Sel_Feat Timestmp
Log Page Attributes (0x0e):         Cmd_Eff_Lg Ext_Get_Lg Telmtry_Lg
Maximum Data Transfer Size:         512 Pages
Warning  Comp. Temp. Threshold:     80 Celsius
Critical Comp. Temp. Threshold:     83 Celsius
Supported Power States
St Op     Max   Active     Idle   RL RT WL WT  Ent_Lat  Ex_Lat
0 +    25.00W   14.00W       -    0  0  0  0       70      70
1 +     8.00W  0.0800W       -    1  1  1  1       70      70
=== START OF SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART/Health Information (NVMe Log 0x02)
Critical Warning:                   0x00
Temperature:                        36 Celsius
Available Spare:                    100%
Available Spare Threshold:          10%
Percentage Used:                    0%
Data Units Read:                    998 [510 MB]
Data Units Written:                 1,136,664 [581 GB]
Host Read Commands:                 17,298
Host Write Commands:                16,449,277
Controller Busy Time:               6
Power Cycles:                       3
Power On Hours:                     986
Unsafe Shutdowns:                   0
Media and Data Integrity Errors:    0
Error Information Log Entries:      0
Warning  Comp. Temperature Time:    0
Critical Comp. Temperature Time:    0
Temperature Sensor 1:               36 Celsius
Temperature Sensor 2:               45 Celsius
Error Information (NVMe Log 0x01, 16 of 64 entries)
No Errors Logged
月租:122.5欧元
交易注意事项:
1、只出,不租。仅一台。
2、剩余价值+500元作为转让费。
3、不接受一切形式的讲价。欧元汇率统一用7 CNY/EUR来算账。其他货币另谈。
请联系我之前务必认真阅读上面的“交易注意事项”。节约你我时间,也是尊重你我。
有意者请企鹅联系:153042130
谢谢大家!
发表于 2022-3-29 21:49:43 | 只看该作者
太高端了,用不起,帮顶
发表于 2022-3-29 22:56:14 来自手机 | 只看该作者
AX41都用不起的绑定
发表于 2022-3-29 22:58:11 | 只看该作者
绑定
这个太贵了太贵了
GMT+8, 2026-1-15 18:44 , Processed in 0.069675 second(s), 10 queries , Gzip On, MemCache On.
