查看: 7241|回复: 41
100Gbps无限流量+980Gbps防御老商家
发表于 2022-3-27 18:12:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
BlazingFast荷兰vps,全部100Gbps带宽无限流量,第一款用超过5TB流量、第二款用超过7TB流量后,会限制为100Mbps带宽,除Linux系统外,还可选Windows VPS操作系统。
  1. 1核        1G        30GB NVME        无限流量        100Gbps        1个        4欧元/月
  2. 2核        2G        60GB NVME        无限流量        100Gbps        1个        8欧元/月
  3. 2核        4G        100GB NVME        无限流量        100Gbps        1个        16欧元/月
  1. Looking Glass: https://lg.nl.blazingfast.io
  2. TOS: https://blazingfast.io/legal#tos
优惠码LET10                       9折优惠,可循环使用
优惠码BLAZINGAMAZING      8折优惠,仅首月可用
  1. Basic System Information:
  3. Processor  : AMD EPYC 7702P 64-Core Processor
  4. CPU cores  : 1 [url=home.php?mod=space&uid=175]@[/url] 1996.249 MHz
  5. AES-NI     :  Enabled
  6. VM-x/AMD-V :  Enabled
  7. RAM        : 971.8 MiB
  8. Swap       : 1024.0 MiB
  9. Disk       : 29.0 GiB
  10. fio Disk Speed Tests (Mixed R/W 50/50):
  11. ---------------------------------
  12. Block Size | 4k            (IOPS) | 64k           (IOPS)
  13.   ------   | ---            ----  | ----           ----
  14. Read       | 275.57 MB/s  (68.8k) | 1.19 GB/s    (18.6k)
  15. Write      | 276.30 MB/s  (69.0k) | 1.19 GB/s    (18.6k)
  16. Total      | 551.88 MB/s (137.9k) | 2.38 GB/s    (37.2k)
  17.            |                      |
  18. Block Size | 512k          (IOPS) | 1m            (IOPS)
  19.   ------   | ---            ----  | ----           ----
  20. Read       | 1.08 GB/s     (2.1k) | 1.13 GB/s     (1.1k)
  21. Write      | 1.14 GB/s     (2.2k) | 1.20 GB/s     (1.1k)
  22. Total      | 2.22 GB/s     (4.3k) | 2.34 GB/s     (2.2k)
  23. iperf3 Network Speed Tests (IPv4):
  25. Provider        | Location (Link)           | Send Speed      | Recv Speed
  26.                 |                           |                 |
  27. Clouvider       | London, UK (10G)          | 3.72 Gbits/sec  | 8.14 Gbits/sec
  28. Online.net      | Paris, FR (10G)           | 6.24 Gbits/sec  | 4.35 Gbits/sec
  29. WorldStream     | The Netherlands (10G)     | 6.29 Gbits/sec  | 16.1 Gbits/sec
  30. WebHorizon      | Singapore (400M)          | 646 Mbits/sec   | 158 Mbits/sec
  31. Clouvider       | NYC, NY, US (10G)         | 686 Mbits/sec   | 1.69 Gbits/sec
  32. Velocity Online | Tallahassee, FL, US (10G) | 388 Mbits/sec   | 637 Mbits/sec
  33. Clouvider       | Los Angeles, CA, US (10G) | 309 Mbits/sec   | 1.14 Gbits/sec
  34. Iveloz Telecom  | Sao Paulo, BR (2G)        | 146 Mbits/sec   | 811 Mbits/sec
  35. Geekbench 5 Benchmark Test:
  36. ---------------------------------
  37. Test            | Value
  38.                 |
  39. Single Core     | 951
  40. Multi Core      | 944
测试来源网络,可考证的确实为老商家。商家自称为《我的世界》、《FiveM》等游戏服务器提供了良好的DDoS保护,应该还是有点实力的,需要防御的大宽带的可以尝尝鲜。
不带AFFhttps://my.blazingfast.io/
带AFFhttps://my.blazingfast.io/?affid=2733
来自 23#
 楼主| 发表于 2022-3-27 18:51:39 | 只看该作者
螃蟹就得走直线 发表于 2022-3-27 18:42
你去官网下面好好看看,你发出来的机型都只是10G的口子不限流量而已,也不是绝对不限肯定超过阀值降速, ...
。。。。YABS测试点是10G口,咋测出100G?
老板亲口说的100Gbps。。。
我认为BlazingFast是少数几家以5欧元的100Gbps VPS的供应商之一。我们所有的客户都对此感到非常高兴,并喜欢拥有所有可用的带宽。ToS和AUP政策的存在是为了确保有可能提供满足99.99%客户需求的服务,并且0.01%需要不同东西的客户自己支付定制解决方案的费用,而不是增加其他99.99%的成本来滥用他们的滥用。话虽如此,我们从来不需要根据客户的资源使用情况对他们施加任何暂停或限制。
发表于 2022-3-27 18:49:58 | 只看该作者
补个官方测速:
另外LET原帖可以参考:
  1. https://lowendtalk.com/discussion/178154/blazingfast-io-netherlands-vps-epyc-7702p-nvme-gen4-10-off-giveaway#latest
发表于 2022-3-27 18:20:16 | 只看该作者
花里胡哨的,说是不限流量100Gpbs,说到底也就是100M罢了,奔着无限流量来的都是流量大户,7TB只够塞牙缝吧
 楼主| 发表于 2022-3-28 01:40:24 | 只看该作者
laoniu0711 发表于 2022-3-28 00:42
自己都不上的灵车也好意思让别人上?
灵你妈呢?老商家,自己好好做做功课好吧。自己见识太短,自己没听过,就是警车。我没需求,上鸡毛?
发表于 2022-3-28 00:42:10 | 只看该作者
自己都不上的灵车也好意思让别人上?
发表于 2022-3-27 18:54:50 | 只看该作者
傻哔。自己都没有测速过,还发aff? 别bb了
发表于 2022-3-27 18:44:56 | 只看该作者
MMMM 发表于 2022-3-27 18:41
http://www.vpsxxs.com/blazingfast20220327/
其他网友提供的BlazingFast测试
评测站果然都是满嘴跑火车,连自己买一个都不舍得,这是复制的老板在LET自己发的评测
发表于 2022-3-27 18:42:56 | 只看该作者
你去官网下面好好看看,你发出来的机型都只是10G的口子不限流量而已,也不是绝对不限肯定超过阀值降速,哪来的云主机给你100G的口子,杜甫才是100G的口子。
我发给你的图片官网截的,新鲜热乎的。做AFF起码也得说实话吧。
发表于 2022-3-27 18:40:47 | 只看该作者
qq53988545 发表于 2022-3-27 18:38
他家的独服也只有1gbps,10gpbs都要多花850€,又从哪看到的不靠谱测评
老板自己贴的,没保证,请以实物为准
发表于 2022-3-27 18:37:30 | 只看该作者
建议楼主把眼睛捐给有需要的人吧。
发表于 2022-3-27 18:14:13 | 只看该作者
这么牛逼,能超过OVH吗
 楼主| 发表于 2022-3-27 18:28:50 | 只看该作者
2life.top 发表于 2022-3-27 18:20
花里胡哨的,说是不限流量100Gpbs,说到底也就是100M罢了,奔着无限流量来的都是流量大户,7TB只够塞牙缝吧 ...
主要是没见过100Gbps VPS,就拿来分享下。
 楼主| 发表于 2022-3-27 18:30:14 | 只看该作者
MSN 发表于 2022-3-27 18:20
这么牛逼,能超过OVH吗
没用过不知道呀,不过可以测试下他家官网,线路一样。
发表于 2022-3-27 18:31:39 | 只看该作者
不行 界面说明了只有1Gbps没写有100Gbps
发表于 2022-3-27 18:33:29 | 只看该作者
服务器现在能接 100G的网卡?
 楼主| 发表于 2022-3-27 18:34:15 | 只看该作者
你可以买下试试,应该是100Gbps,我从外面偷的测评,应该没问题。
GMT+8, 2026-4-28 13:47 , Processed in 0.069318 second(s), 13 queries , Gzip On, MemCache On.
