查看: 11725|回复: 2
告别国内VPS无法访问的github
发表于 2022-3-17 19:42:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
修改本地host
既然上游服务器的域名地址被修改了,那我们直接在本地hosts文件了指定好域名对应的IP地址不就好了嘛
hosts 文件在每个系统的位置不一,详情如下:
• Windows 系统:C:\Windows\System32\drivers\etc\hosts
• Linux 系统:/etc/hosts
• Mac(苹果电脑)系统:/etc/hosts
• Android(安卓)系统:/system/etc/hosts
• iPhone(iOS)系统:/etc/hosts
然后将下面这些数据拷贝到自己电脑的hosts文件,再激活生效就可以了:
140.82.114.25                 alive.github.com
140.82.112.25                 live.github.com
185.199.108.154               github.githubassets.com
140.82.112.22                 central.github.com
185.199.108.133               desktop.githubusercontent.com
185.199.108.153               assets-cdn.github.com
185.199.108.133               camo.githubusercontent.com
185.199.108.133               github.map.fastly.net
199.232.69.194                github.global.ssl.fastly.net
140.82.112.4                  gist.github.com
185.199.108.153               github.io
140.82.114.4                  github.com
192.0.66.2                    github.blog
140.82.112.6                  api.github.com
185.199.108.133               raw.githubusercontent.com
185.199.108.133               user-images.githubusercontent.com
185.199.108.133               favicons.githubusercontent.com
185.199.108.133               avatars5.githubusercontent.com
185.199.108.133               avatars4.githubusercontent.com
185.199.108.133               avatars3.githubusercontent.com
185.199.108.133               avatars2.githubusercontent.com
185.199.108.133               avatars1.githubusercontent.com
185.199.108.133               avatars0.githubusercontent.com
185.199.108.133               avatars.githubusercontent.com
140.82.112.10                 codeload.github.com
52.217.223.17                 github-cloud.s3.amazonaws.com
52.217.199.41                 github-com.s3.amazonaws.com
52.217.93.164                 github-production-release-asset-2e65be.s3.amazonaws.com
52.217.174.129                github-production-user-asset-6210df.s3.amazonaws.com
52.217.129.153                github-production-repository-file-5c1aeb.s3.amazonaws.com
185.199.108.153               githubstatus.com
64.71.144.202                 github.community
23.100.27.125                 github.dev
185.199.108.133               media.githubusercontent.com
大部分情况下是直接生效,如未生效可尝试下面的办法,刷新 DNS:
• Windows:在 CMD 窗口输入:ipconfig /flushdns
• Linux 命令:sudo nscd restart,如报错则须安装:sudo apt install nscd 或 sudo /etc/init.d/nscd restart
• Mac 命令:sudo killall -HUP mDNSResponder
如果还没有生效的话,可以尝试重启一下电脑,毕竟这步操作可以解决 95 % 的电脑bug
发表于 2022-9-18 14:13:13 | 只看该作者
github还没有被dns污染,只是正常解析出的ip里有几个ip被墙,因此可以通过修改本地host强制访问可用的ip
发表于 2023-3-11 09:44:20 | 只看该作者
要是墙了 IP 就没办法了~ 还是要经常换 IP
GMT+8, 2026-4-18 10:34 , Processed in 0.061565 second(s), 11 queries , Gzip On, MemCache On.
