查看: 2122|回复: 21
哦也 爱情还是可以相信的
发表于 2011-12-30 22:29:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Burst回复了 并且重新给我创建了新的VPS
  1. Hi,
  2. Again, I apologize for the lengthy delay and numerous issue you've had with this VPS.
  3. At this time I've migrated your account to a new VPS node and reinstalled a fresh VPS. The new welcome details (IPs are primarily the only thing that has changed) have been re-sent to your email address on record.
  4. Current I see that you have a pending cancellation for this VPS. Please let me know if you're able to access and use this VPS at this time and wish to keep this VPS and I'll have our customer service department reverse this cancellation for you. Also, given the issues you've had I don't see a problem with them being able to credit some days to your account as well, but I would need to discuss that with them.
  5. Please let me know either way so I can proceed accordingly.
  6. Thank you!
人家这么有礼貌 我们当然也要拍拍马屁
  1. Thank you for your help, Burst with your presence will become better, I would like to suggest Burst increase xen Linux VPS, so Burst can get a larger market.
不知道这位Andrew R 内流满面了没有
发表于 2011-12-30 22:30:05 | 只看该作者
 楼主| 发表于 2011-12-30 22:31:02 | 只看该作者
funkys 发表于 2011-12-30 22:30
瑶瑶
发表于 2011-12-30 22:33:44 | 只看该作者
好像。。。英语水平。。。
 楼主| 发表于 2011-12-30 22:34:17 | 只看该作者
testisitok 发表于 2011-12-30 22:33
好像。。。英语水平。。。
我根本就不会 谷歌翻译
 楼主| 发表于 2011-12-30 22:37:12 | 只看该作者
好像。。。英语水平。。。
学了半年 只会了一个OKay
发表于 2011-12-30 22:38:55 | 只看该作者
发表于 2011-12-30 22:46:12 | 只看该作者
busrt哭了。
发表于 2011-12-30 22:47:59 | 只看该作者
要裸照
发表于 2011-12-31 00:10:31 | 只看该作者
看不懂,压力大
GMT+8, 2026-4-27 15:11 , Processed in 0.066244 second(s), 13 queries , Gzip On, MemCache On.
