查看: 967|回复: 1
[疑问] Linode的Dedicated CPU Plans与Shared CPU Plans有多大区别?
发表于 2022-3-15 21:17:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Linode的Dedicate CPU:
2H4GB 30刀
shared plan:
2H4GB 20刀
这用起来会有多大的差别? 虚拟以后,CPU会多个人共享,但是内存不会多人共享吧,Share Plan里显示的4GB内存就是物理上的4GB内存吧。
主要还是想搞明白,用VPS的时候4H8GB可以放10个网站的话,那么用Dedicate Server的话需要用几H几GB的?
 楼主| 发表于 2022-3-15 23:06:33 | 只看该作者
Linode Dedicated vs Shared CPU:
https://www.linode.com/docs/guides/dedicated-cpu-use-cases/
https://www.linode.com/community/questions/19437/does-a-dedicated-cpu-or-high-memory-plan-improve-disk-io-performance
https://www.有图比.com/watch?v=yQPAyyjKM_M
https://www.有图比.com/watch?v=6E8h-T8fk9U
https://www.有图比.com/watch?v=g1B00lxZxd0
GMT+8, 2026-4-25 07:29 , Processed in 0.058452 second(s), 9 queries , Gzip On, MemCache On.
