查看: 2945|回复: 25
Burst的客服把我弄哭了
发表于 2011-12-30 13:12:15 | 只看该作者
大胡子在哪里
 楼主| 发表于 2011-12-30 12:59:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. Hi,
  2. I apologize for the extended delay again. I'm currently looking at getting a few additional SolusVM nodes online and would like to place your VPS on one of those (on a more or less empty node). Unfortunately this will probably take about 24 hours to complete since I'm working with our LA technicians to get these nodes online.
  3. If this is not acceptable and you need your VPS back online ASAP, let me know and I'll try to find an existing node that I can place this VPS on. Otherwise, I'll have this VPS re-created on a new node within this time frame. In either case I'll forward this to our customer service department once we have your VPS back online and see if they can do anything about your credit for this specific downtime.
  4. Thank you!
装啊装 一天装十几遍系统 终于把硬盘格式化坏了   给我换节点
  1. You have the final say.
丢了一句话我就跑路了    随便客服折腾去吧  工作人员太辛苦了
经过多天的交流 发现客服Justin C. 很拽  投诉后给我换了个Andrew R 服务态度改善了不少
参与人数 2威望 +14 收起 理由
xuyanjian + 7 justing C 确实拽,强制给重装系统了,还说.
jil + 7 投诉!投诉!投诉!投诉!投诉!投诉!投诉.
发表于 2011-12-30 12:59:54 | 只看该作者
哈哈  折腾死你
 楼主| 发表于 2011-12-30 13:00:29 | 只看该作者
cnweb 发表于 2011-12-30 12:59
哈哈  折腾死你
你太坏了
发表于 2011-12-30 13:01:01 | 只看该作者
kvm,虎虎,水王,再不快点,你们的J友要被84拐跑了
 楼主| 发表于 2011-12-30 13:01:28 | 只看该作者
好圈圈
发表于 2011-12-30 13:02:18 | 只看该作者
哈哈  折腾死你
此人很蛋疼
 楼主| 发表于 2011-12-30 13:03:33 | 只看该作者
kwx 发表于 2011-12-30 13:02
此人很蛋疼
你蛋都碎了
你都投诉了 另一个肯定改善了...腰部有被你投诉啊...
 楼主| 发表于 2011-12-30 13:05:24 | 只看该作者
昨天发现你家优惠码过期了
GMT+8, 2026-4-15 23:03 , Processed in 0.076312 second(s), 14 queries , Gzip On, MemCache On.
