查看: 2599|回复: 13
[已出]明盘160元push出绿云东京年付24刀
发表于 2022-3-3 23:27:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. -------------------- A Bench.sh Script By Teddysun -------------------
  2. Version            : v2022-02-22
  3. Usage              : wget -qO- bench.sh | bash
  4. ----------------------------------------------------------------------
  5. CPU Model          : AMD Ryzen 9 5950X 16-Core Processor
  6. CPU Cores          : 1 [url=home.php?mod=space&uid=175]@[/url] 3393.548 MHz
  7. CPU Cache          : 512 KB
  8. AES-NI             : Enabled
  9. VM-x/AMD-V         : Enabled
  10. Total Disk         : 13.7 GB (2.7 GB Used)
  11. Total Mem          : 991.7 MB (202.5 MB Used)
  12. Total Swap         : 1024.0 MB (264.0 KB Used)
  13. System uptime      : 3 days, 18 hour 6 min
  14. Load average       : 0.00, 0.01, 0.00
  15. OS                 : CentOS Linux release 7.9.2009 (Core)
  16. Arch               : x86_64 (64 Bit)
  17. Kernel             : 4.11.8-1.el7.elrepo.x86_64
  18. TCP CC             : tsunami
  19. Virtualization     : KVM
  20. Organization       : AS23959 Owl Limited
  21. Location           : Osaka / JP
  22. Region             : Ōsaka
  23. ----------------------------------------------------------------------
  24. I/O Speed(1st run) : 1.3 GB/s
  25. I/O Speed(2nd run) : 1.7 GB/s
  26. I/O Speed(3rd run) : 1.9 GB/s
  27. I/O Speed(average) : 1672.5 MB/s
  28. ----------------------------------------------------------------------
  29. Node Name        Upload Speed      Download Speed      Latency
  30. Speedtest.net    792.58 Mbps       790.00 Mbps         0.69 ms
  31. Los Angeles, US  712.54 Mbps       625.00 Mbps         117.57 ms
  32. Dallas, US       563.45 Mbps       618.26 Mbps         146.92 ms
  33. Montreal, CA     493.68 Mbps       695.56 Mbps         158.60 ms
  34. Paris, FR        335.95 Mbps       2675.63 Mbps        235.57 ms
  35. Amsterdam, NL    279.60 Mbps       90.09 Mbps          258.57 ms
  36. Shanghai, CN     606.81 Mbps       803.96 Mbps         231.06 ms
  37. Nanjing, CN      747.78 Mbps       786.98 Mbps         50.81 ms
  38. Guangzhou, CN    2.51 Mbps         343.04 Mbps         86.35 ms
  39. Hongkong, CN     637.34 Mbps       795.65 Mbps         81.46 ms
  40. Seoul, KR        727.39 Mbps       569.78 Mbps         67.52 ms
  41. ----------------------------------------------------------------------
  42. Finished in        : 5 min 40 sec
  43. Timestamp          : 2022-03-03 10:26:08 EST
流媒体解锁
  1. ** 正在测试IPv4解锁情况
  2. --------------------------------
  3. ** 您的网络为: Owl Limited (43.239.*.*)
  4. ============[ Multination ]============
  5. Dazn:                                  No
  6. HotStar:                               No
  7. Disney+:                               Yes (Region: US)
  8. Netflix:                               Yes (Region: JP)
  9. 有图比 Premium:                       No  (Region: US)
  10. Amazon Prime Video:                    Yes (Region: JP)
  11. TVBAnywhere+:                          Yes
  12. Tiktok Region:                         JP (Possible IDC IP)
  13. iQyi Oversea Region:                   JP
  14. Viu.com:                               No
  15. 有图比 CDN:                           Tokyo
  16. Netflix Preferred CDN:                 Tokyo
  17. Steam Currency:                        JPY
  18. =======================================
  19. ** 正在测试IPv6解锁情况
  20. --------------------------------
  21. ** 您的网络为: Owl Limited (2403:71c0:2000:*:*)
  22. ============[ Multination ]============
  23. Dazn:                                  Failed (Network Connection)
  24. HotStar:                               No
  25. Disney+:                               No
  26. Netflix:                               Originals Only
  27. 有图比 Premium:                       No  (Region: CN)
  28. Amazon Prime Video:                    Unsupported
  29. TVBAnywhere+:                          Failed (Network Connection)
  30. Tiktok Region:                         ->
  31. gzip: stdin: unexpected end of file
  32. Tiktok Region:                         Failed
  33. iQyi Oversea Region:                   Failed
  34. Viu.com:                               Failed
  35. 有图比 CDN:                           Tokyo
  36. Netflix Preferred CDN:                 Tokyo
  37. Steam Currency:                        Failed (Network Connection)
  38. =======================================
  39. 本次测试已结束,感谢使用此脚本
  40. 检测脚本当天运行次数:19767; 共计运行次数:2408810
发表于 2022-3-3 23:32:04 | 只看该作者
你这是osaka大阪啊
 楼主| 发表于 2022-3-3 23:35:26 | 只看该作者
ved2loc 发表于 2022-3-3 23:32
你这是osaka大阪啊
显示错误吧,我这是东京的啊
 楼主| 发表于 2022-3-3 23:37:05 | 只看该作者
** 正在测试IPv4解锁情况
Dazn:                                  No
HotStar:                               No
Viu.com:                               No
有图比 CDN:                           Tokyo
Steam Currency:                        JPY
** 正在测试IPv6解锁情况
HotStar:                               No
Disney+:                               No
Tiktok Region:                         ->
Viu.com:                               Failed
有图比 CDN:                           Tokyo
本次测试已结束,感谢使用此脚本
发表于 2022-3-3 23:42:01 来自手机 | 只看该作者
你这是osaka大阪啊
这个确实是东京 ip地址是大阪。
发表于 2022-3-3 23:48:03 | 只看该作者
太糊了
发表于 2022-3-3 23:51:52 | 只看该作者
zpone 发表于 2022-3-3 23:35
显示错误吧,我这是东京的啊
多少流量的,图看不清
 楼主| 发表于 2022-3-3 23:52:53 | 只看该作者
吹风秀跳刀 发表于 2022-3-3 23:51
多少流量的,图看不清
750G的,跟官网月付6刀的哪个应该是同一款
 楼主| 发表于 2022-3-3 23:55:15 | 只看该作者
不会传图片
RyzenKVMJP-1
1024MB RAM
1024MB SWAP
15GB NVMe SSD
1 core CPU
1 IPv4/112
IPv6
750GBBandwidth
1GbpsPort
Linux OS
SolusVM Control Panel
Tokyo Location
GMT+8, 2026-4-30 14:59 , Processed in 0.076168 second(s), 12 queries , Gzip On, MemCache On.
