Entering/Changing the Authorization Code
Transferring domains from a different registrar requires that you provide that domain's authorization code. The authorization code can only be retrieved from the current registrar of record, and they should provide a mechanism to easily access it. If you did not provide the authorization code at the time of your transfer request order, or if the authorization code you provided is not correct, a link will appear allowing you to enter or change it.
