查看: 1483|回复: 4
我的dedipath被suspended了,大佬们进来看看啥情况
发表于 2022-2-24 13:41:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Dear Sir/Madam, We have detected abuse from the IP address 141.98.。。, which according to abusix.com is on your network. We would appreciate if you would investigate and take action as appropriate. Log lines are given below, but please ask if you require any further information. (If you are not the correct person to contact about this please accept our apologies - your e-mail address was extracted from the whois record by an automated process.) This mail was generated by Fail2Ban in a X-ARF format! You can find more information about x-arf at http://www.x-arf.org/specification.html. The recipient address of this report was provided by the Abuse Contact DB by abusix.com. abusix.com does not maintain the content of the database. All information which we pass out, derives from the RIR databases and is processed for ease of use. If you want to change or report non working abuse contacts please contact the appropriate RIR. If you have any further question, contact abusix.com directly via email (info@abusix.com). Information about the Abuse Contact Database can be found here: https://abusix.com/global-reporting/abuse-contact-db abusix.com is neither responsible nor liable for the content or accuracy of this message.
这啥意思,谷歌翻译成中文也看不明白
发表于 2022-2-24 13:43:05 来自手机 | 只看该作者
你滥用了呗,发包之类的
发表于 2022-2-24 13:44:18 | 只看该作者
你滥用了,被abusix.com查了
发表于 2022-2-24 13:46:04 | 只看该作者
你的网络IP 141.98.*.* 被侦测到滥用情况。滥用记录提供如下。
如果不是你的机器,请联络 info@abusix.com
GMT+8, 2026-4-24 19:49 , Processed in 0.063131 second(s), 10 queries , Gzip On, MemCache On.
