查看: 2617|回复: 9
[经验] NETCUP RS 2000 G9 WSV22 测试
发表于 2022-2-16 21:52:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
性能强了一点点(可能暂时超售不严重),网络还是不稳定,11.2€减免19%的税应该是9.072€才对,不知道为啥算的是减免16%的税,实际价格是9.408€,真奇怪。
  3. #                     v2021-12-28                    #
  6. Wed 16 Feb 2022 02:33:56 PM CET
  7. Basic System Information:
  9. Processor  : AMD EPYC 7702P 64-Core Processor
  10. CPU cores  : 4 [url=home.php?mod=space&uid=175]@[/url] 1996.248 MHz
  11. AES-NI     : ✔ Enabled
  12. VM-x/AMD-V : ❌ Disabled
  13. RAM        : 15.7 GiB
  14. Swap       : 0.0 KiB
  15. Disk       : 314.9 GiB
  16. fio Disk Speed Tests (Mixed R/W 50/50):
  17. ---------------------------------
  18. Block Size | 4k            (IOPS) | 64k           (IOPS)
  19.   ------   | ---            ----  | ----           ----
  20. Read       | 42.21 MB/s   (10.5k) | 498.36 MB/s   (7.7k)
  21. Write      | 42.30 MB/s   (10.5k) | 500.99 MB/s   (7.8k)
  22. Total      | 84.51 MB/s   (21.1k) | 999.35 MB/s  (15.6k)
  23.            |                      |
  24. Block Size | 512k          (IOPS) | 1m            (IOPS)
  25.   ------   | ---            ----  | ----           ----
  26. Read       | 1.35 GB/s     (2.6k) | 1.58 GB/s     (1.5k)
  27. Write      | 1.42 GB/s     (2.7k) | 1.68 GB/s     (1.6k)
  28. Total      | 2.77 GB/s     (5.4k) | 3.27 GB/s     (3.1k)
  29. Geekbench 5 Benchmark Test:
  30. ---------------------------------
  31. Test            | Value
  32.                 |
  33. Single Core     | 1015
  34. Multi Core      | 3731
  35. Full Test       | https://browser.geekbench.com/v5/cpu/12813494
  1. -------------------- A Bench.sh Script By Teddysun -------------------
  2. Intro              : https://teddysun.com/444.html
  3. Version            : v2022-01-01
  4. Usage              : wget -qO- bench.sh | bash
  5. ----------------------------------------------------------------------
  6. CPU Model          : AMD EPYC 7702P 64-Core Processor
  7. CPU Cores          : 4
  8. CPU Frequency      : 1996.248 MHz
  9. CPU Cache          : 512 KB
  10. Total Disk         : 315.0 GB (1.4 GB Used)
  11. Total Mem          : 16042 MB (100 MB Used)
  12. Total Swap         : 0 MB (0 MB Used)
  13. System uptime      : 0 days, 5 hour 47 min
  14. Load average       : 0.04, 0.23, 0.14
  15. OS                 : Debian GNU/Linux 10
  16. Arch               : x86_64 (64 Bit)
  17. Kernel             : 4.19.0-18-amd64
  18. TCP CC             : bbr
  19. Virtualization     : KVM
  20. Organization       : AS197540 netcup GmbH
  21. Location           : Frankfurt am Main / DE
  22. Region             : Hesse
  23. ----------------------------------------------------------------------
  24. I/O Speed(1st run) : 987 MB/s
  25. I/O Speed(2nd run) : 921 MB/s
  26. I/O Speed(3rd run) : 1.0 GB/s
  27. I/O Speed(average) : 977.3 MB/s
  28. ----------------------------------------------------------------------
  29. Node Name        Upload Speed      Download Speed      Latency
  30. Speedtest.net    624.31 Mbps       495.72 Mbps         0.93 ms
  31. Los Angeles, US  606.50 Mbps       1484.82 Mbps        148.30 ms
  32. Dallas, US       737.10 Mbps       1717.28 Mbps        118.94 ms
  33. Montreal, CA     575.77 Mbps       938.80 Mbps         91.41 ms
  34. Paris, FR        2478.12 Mbps      2359.20 Mbps        19.16 ms
  35. Amsterdam, NL    2458.71 Mbps      2391.08 Mbps        10.65 ms
  36. Shanghai, CN     1338.61 Mbps      2535.71 Mbps        180.95 ms
  37. Nanjing, CN      450.45 Mbps       1707.72 Mbps        200.48 ms
  38. Guangzhou, CN    0.67 Mbps         245.06 Mbps         233.15 ms
  39. Hongkong, CN     908.17 Mbps       2526.70 Mbps        212.87 ms
  40. Seoul, KR        359.64 Mbps       646.65 Mbps         222.46 ms
  41. ----------------------------------------------------------------------
  42. Finished in        : 6 min 6 sec
  43. Timestamp          : 2022-02-16 14:47:14
  44. ----------------------------------------------------------------------
发表于 2022-2-16 22:38:29 | 只看该作者
小学数学问题
如 a*(1+9.4%) = b
那 b*(1-9.4%) < a
发表于 2022-2-16 21:53:44 | 只看该作者
魔幻。
发表于 2022-2-16 22:08:16 | 只看该作者
网络有2.5G口很难得了,而且性能看着也是很不错的
  3. #                     v2021-12-28                    #
  6. Wed 16 Feb 2022 02:41:10 PM CET
  10. CPU cores  : 4 [url=home.php?mod=space&uid=175]@[/url] 1996.246 MHz
  13. RAM        : 15.7 GiB
  14. Swap       : 0.0 KiB
  20. Read       | 44.10 MB/s   (11.0k) | 461.32 MB/s   (7.2k)
  21. Write      | 44.18 MB/s   (11.0k) | 463.75 MB/s   (7.2k)
  22. Total      | 88.29 MB/s   (22.0k) | 925.07 MB/s  (14.4k)
  23.            |                      |
  26. Read       | 1.21 GB/s     (2.3k) | 1.61 GB/s     (1.5k)
  27. Write      | 1.27 GB/s     (2.4k) | 1.72 GB/s     (1.6k)
  28. Total      | 2.49 GB/s     (4.8k) | 3.33 GB/s     (3.2k)
  29. iperf3 Network Speed Tests (IPv4):
  31. Provider        | Location (Link)           | Send Speed      | Recv Speed
  32.                 |                           |                 |
  33. Clouvider       | London, UK (10G)          | 2.00 Gbits/sec  | 2.37 Gbits/sec
  34. Online.net      | Paris, FR (10G)           | 2.02 Gbits/sec  | busy
  35. WorldStream     | The Netherlands (10G)     | 2.15 Gbits/sec  | 2.38 Gbits/sec
  36. WebHorizon      | Singapore (400M)          | 415 Mbits/sec   | 510 Mbits/sec
  37. Clouvider       | NYC, NY, US (10G)         | 660 Mbits/sec   | 1.54 Gbits/sec
  38. Velocity Online | Tallahassee, FL, US (10G) | 510 Mbits/sec   | 1.88 Gbits/sec
  39. Clouvider       | Los Angeles, CA, US (10G) | 449 Mbits/sec   | 918 Mbits/sec
  40. Iveloz Telecom  | Sao Paulo, BR (2G)        | 118 Mbits/sec   | 885 Mbits/sec
  41. iperf3 Network Speed Tests (IPv6):
  43. Provider        | Location (Link)           | Send Speed      | Recv Speed
  44.                 |                           |                 |
  45. Clouvider       | London, UK (10G)          | 1.87 Gbits/sec  | 2.34 Gbits/sec
  46. Online.net      | Paris, FR (10G)           | 1.21 Gbits/sec  | 2.32 Gbits/sec
  47. WorldStream     | The Netherlands (10G)     | 1.74 Gbits/sec  | 2.33 Gbits/sec
  48. WebHorizon      | Singapore (400M)          | 273 Mbits/sec   | 407 Mbits/sec
  49. Clouvider       | NYC, NY, US (10G)         | 662 Mbits/sec   | 1.42 Gbits/sec
  50. Clouvider       | Los Angeles, CA, US (10G) | 472 Mbits/sec   | 1.01 Gbits/sec
  51. Geekbench 5 Benchmark Test:
  52. ---------------------------------
  53. Test            | Value
  54.                 |
  55. Single Core     | 1053
  56. Multi Core      | 4091
发表于 2022-2-16 22:10:24 | 只看该作者
发表于 2022-2-16 22:13:18 | 只看该作者
发表于 2022-2-16 22:14:27 来自手机 | 只看该作者
这款不是VDS吗?资源应该独享的啊。
发表于 2022-2-16 22:33:43 | 只看该作者
价格没问题,11.2是含税价,意思是9.4的原价加上19%的税
 楼主| 发表于 2022-2-16 22:37:11 | 只看该作者
学习到了,非常感谢。
GMT+8, 2026-4-16 04:25 , Processed in 0.063603 second(s), 11 queries , Gzip On, MemCache On.
