CeraNetworks网络延迟测速工具IP归属甄别
查看: 4061|回复: 5
刚买了款服务器。怎么跟标配不一样。
发表于 2011-12-19 10:42:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
是D525这款,但是硬盘确实80G。我晕倒。。
官方是显示500G啊,郁闷。 难道有问题??
发表于 2011-12-19 10:46:07 | 只看该作者
楼主看这个通知,会明白原因的,具体也可以看我发的另一个贴子:http://www.loc.qiche.eu.org/thread-94068-1-2.html
Dear Resellers -
We have a large demand for low end servers which are typically sold out quickly with our Atom 330 / Atom D510 and AMD 3800XP/4000XP plans. With hard drive prices escalating in prices we have come out with 2 options we believe will work best for your customers.
Option 1 - Cloud Atom
VMware Cloud Server with full Web KVM console managed at https://vcloud.krypt.com with pooled resource specs:
CPU: 2GHz
Mem: 2GB
HDD: 160GB
BW: 1500GB
Price: $79.95 before discount
Gold and Platinum resellers will still be able to use their bandwidth upgrade plans for these servers. The #1 selling point for virtualization that you should make to your customer is that there is no reliance on physical hardware. Cloud Servers can grow and scale up or even down based on your compute requirements. There is also zero to minimal downtime in upgrading certain resources. Physical hard drives can and eventually will break down and are prone to data corruption whereas the Cloud Servers use SAN based storage so the data is spread out over multiple drives.
Option 2 - Small Spec Atom D525
CPU: Atom D525
Mem: 2GB
HDD: 80GB SATA
BW: 1500GB
Price: $84.95 before discount
Due to recent flooding in Thailand, hard drive prices have increased. In order to keep costs down we're offering this new Atom D525 plan with 80GB hard disks. Resellers will need to pay for the upgrade from an Atom 330 if it is not in stock because the reseller did not check https://my.krypt.com. We ask that all resellers monitor inventory through https://my.krypt.com to ensure what you are selling is in fact in stock.
Remember when ordering servers we give the following priority:
1. Rapid Deploy
2. Orders from www.Krypt.com or my.krypt.com
3. Orders placed through tickets
亲爱的经销商,
客户对于我们的低端服务器经常有大量的需求,这些服务器方案诸如Atom 330 / Atom D510 和 AMD 3800XP/4000XP经常迅速售罄。由于硬盘价格的上涨,我们最近为客户提供了2种新的最佳方案选择。
方案1-Cloud Atom
拥有完全Web KVM控制台的VMware云服务器,https://vcloud.krypt.com,汇集了各种不同规格配置。
CPU: 2GHz
内存: 2GB
HDD: 160GB
带宽: 1500GB
价格: $79.95 (折扣前)
黄金和白金经销商将仍然能够使用带宽升级计划用于这些服务器上。您可以对您的客户隆重介绍虚拟化的No.1的卖点就是没有对物理服务器的依赖。云服务器基于您的计算要求进行可以扩展,甚至可以降级。在升级特定资源的时候通常没有或只有最少的停机时间。物理硬盘驱动器可能甚至将最终瘫痪并且容易造成数据损坏,而云服务器使用基于SAN的存储,所以数据分布在多个驱动器上。
方案2-小规格Atom D525
CPU: Atom D525
内存: 2GB
HDD: 80GB SATA
带宽: 1500GB
价格: $84.95(折扣前)
由于今日在泰国肆虐的洪水,导致了硬盘价格的上涨。为了将价格降到很低,我们最新推出了包含80GB硬盘的Atom D525方案。如果Atom 330已售罄而经销商不及时查看https://my.krypt.com 且仍然订购Atom 330的话那么经销商将支付此升级费用。我们希望所有的经销商及时通过https://my.krypt.com查看库存来确保您转售的服务器是有库存的。
请您记住在订货时我们给予的优先级别顺序是:
1. Rapid Deploy(快速部署)
2. 通过 www.Krypt.com 或 my.krypt.com提交的订单
3. 通过支持票提交的订单
Thank You,
发表于 2011-12-19 10:48:45 | 只看该作者
简单地说,就是因为泰国洪水,硬盘价格成倍上涨,KT想了这个办法来缓解大家对ATOM机型的需求。
 楼主| 发表于 2011-12-19 10:49:21 | 只看该作者
这个不错,了解
发表于 2011-12-19 11:07:38 | 只看该作者
楼上兄弟找淘宝代购的吧。一头升级,一头降级,算扯平了。
如果80G够用,速度也不错,就算了,大家做生意都不容易。
发表于 2012-4-18 14:34:57 | 只看该作者
现在atom330的都不怎么生产了!!
GMT+8, 2026-5-1 23:44 , Processed in 0.067781 second(s), 10 queries , Gzip On, MemCache On.
