查看: 2913|回复: 10
历经一个星期,HostHatch斯德哥尔摩60刀终于开通了。
发表于 2022-1-11 14:35:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本来是最早开通的,结果网络不同,发无数工单等待了一个星期了,今天终于开通了,赶紧测试一下,看结果还算可以。
  3. #                     v2021-12-28                    #
  6. Tue Jan 11 01:09:46 EST 2022
  7. Basic System Information:
  9. Processor  : AMD EPYC 7551P 32-Core Processor
  10. CPU cores  : 1 [url=home.php?mod=space&uid=175]@[/url] 1999.984 MHz
  11. AES-NI     : ✔ Enabled
  12. VM-x/AMD-V : ✔ Enabled
  13. RAM        : 978.9 MiB
  14. Swap       : 508.0 MiB
  15. Disk       : 930.2 GiB
  16. fio Disk Speed Tests (Mixed R/W 50/50):
  17. ---------------------------------
  18. Block Size | 4k            (IOPS) | 64k           (IOPS)
  19.   ------   | ---            ----  | ----           ----
  20. Read       | 1.67 MB/s      (419) | 14.75 MB/s     (230)
  21. Write      | 1.69 MB/s      (424) | 15.22 MB/s     (237)
  22. Total      | 3.37 MB/s      (843) | 29.98 MB/s     (467)
  23.            |                      |
  24. Block Size | 512k          (IOPS) | 1m            (IOPS)
  25.   ------   | ---            ----  | ----           ----
  26. Read       | 51.78 MB/s     (101) | 81.85 MB/s      (79)
  27. Write      | 54.76 MB/s     (106) | 87.30 MB/s      (85)
  28. Total      | 106.54 MB/s    (207) | 169.15 MB/s    (164)
  29. iperf3 Network Speed Tests (IPv4):
  30. ---------------------------------
  31. Provider        | Location (Link)           | Send Speed      | Recv Speed
  32.                 |                           |                 |
  33. Clouvider       | London, UK (10G)          | 4.84 Gbits/sec  | 2.53 Gbits/sec
  34. Online.net      | Paris, FR (10G)           | 5.85 Gbits/sec  | 2.64 Gbits/sec
  35. WorldStream     | The Netherlands (10G)     | 6.97 Gbits/sec  | 1.35 Gbits/sec
  36. WebHorizon      | Singapore (400M)          | 270 Mbits/sec   | 249 Mbits/sec
  37. Clouvider       | NYC, NY, US (10G)         | 1.49 Gbits/sec  | 1.39 Gbits/sec
  38. Velocity Online | Tallahassee, FL, US (10G) | 1.50 Gbits/sec  | 1.37 Gbits/sec
  39. Clouvider       | Los Angeles, CA, US (10G) | 854 Mbits/sec   | 855 Mbits/sec
  40. Iveloz Telecom  | Sao Paulo, BR (2G)        | 691 Mbits/sec   | 839 Mbits/sec
  41. Geekbench 5 Benchmark Test:
  43. Test            | Value
  44.                 |
  45. Single Core     | 529
  46. Multi Core      | 553
  1. CPU Model          : AMD EPYC 7551P 32-Core Processor
  2. CPU Cores          : 1
  3. CPU Frequency      : 1999.984 MHz
  4. CPU Cache          : 512 KB
  5. Total Disk         : 932.0 GB (1.8 GB Used)
  6. Total Mem          : 978 MB (127 MB Used)
  7. Total Swap         : 507 MB (6 MB Used)
  8. System uptime      : 0 days, 0 hour 15 min
  9. Load average       : 0.01, 0.24, 0.24
  10. OS                 : CentOS Linux release 7.9.2009 (Core)
  11. Arch               : x86_64 (64 Bit)
  12. Kernel             : 5.15.12
  13. TCP CC             : bbr
  14. Virtualization     : KVM
  15. Organization       : AS63473 HostHatch, LLC
  16. Location           : Stockholm / SE
  17. Region             : Stockholm
  18. ----------------------------------------------------------------------
  19. I/O Speed(1st run) : 195 MB/s
  20. I/O Speed(2nd run) : 278 MB/s
  21. I/O Speed(3rd run) : 404 MB/s
  22. I/O Speed(average) : 292.3 MB/s
  23. ----------------------------------------------------------------------
  24. Node Name        Upload Speed      Download Speed      Latency
  25. Speedtest.net    933.32 Mbps       933.26 Mbps         0.30 ms
  26. Los Angeles, US  522.41 Mbps       2165.01 Mbps        155.51 ms
  27. Dallas, US       629.31 Mbps       2674.85 Mbps        127.66 ms
  28. Montreal, CA     643.34 Mbps       931.90 Mbps         98.90 ms
  29. Paris, FR        2476.66 Mbps      3187.75 Mbps        30.78 ms
  30. Amsterdam, NL    3268.77 Mbps      2328.38 Mbps        20.41 ms
  31. Shanghai, CN     354.61 Mbps       1550.66 Mbps        221.97 ms
  32. Nanjing, CN      364.14 Mbps       2637.47 Mbps        229.30 ms
  33. Guangzhou, CN    56.21 Mbps        887.19 Mbps         220.40 ms
  34. Hongkong, CN     387.61 Mbps       3589.11 Mbps        208.98 ms
  35. Seoul, KR        251.48 Mbps       644.32 Mbps         269.01 ms
  36. Singapore, SG    219.57 Mbps       2092.39 Mbps        340.96 ms
  37. Tokyo, JP        184.53 Mbps       5.40 Mbps           248.12 ms
  38. ----------------------------------------------------------------------
  39. Finished in        : 6 min 53 sec
  40. Timestamp          : 2022-01-11 01:30:08
发表于 2022-1-11 14:38:34 | 只看该作者
这io  是不是邻居在搞事
发表于 2022-1-11 14:39:16 | 只看该作者
我的IO也这样
发表于 2022-1-11 14:40:03 | 只看该作者
跑分感人,60刀是三年?
发表于 2022-1-11 14:51:20 | 只看该作者
解释下 什么网络不同。
原来是什么网络,现在又是什么网络?
 楼主| 发表于 2022-1-11 17:44:58 | 只看该作者
wey 发表于 2022-1-11 14:38
这io  是不是邻居在搞事
估计好多邻居都在测试
 楼主| 发表于 2022-1-11 17:49:38 | 只看该作者
louiejordan 发表于 2022-1-11 14:40
跑分感人,60刀是三年?
是的,3年60刀,1h1g1t4t。
 楼主| 发表于 2022-1-11 17:50:49 | 只看该作者
dahai0405 发表于 2022-1-11 14:51
解释下 什么网络不同。
原来是什么网络,现在又是什么网络?
原来分配的是美国的ip,网络不通,现在分配回了瑞典ip,所以一切都好了。
发表于 2022-1-11 18:41:42 来自手机 | 只看该作者
io烂的没话说了
发表于 2022-1-11 21:19:33 | 只看该作者
你咋登录的?为什么我root不能登录???
GMT+8, 2026-4-24 00:21 , Processed in 0.064698 second(s), 10 queries , Gzip On, MemCache On.
