查看: 3070|回复: 10
KS-1终于开机啦
发表于 2022-1-10 14:52:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1月4号下单的KS-1终于开机啦,先来个脚本测试一下
  1. Basic System Information:
  3. Processor  : Intel(R) Atom(TM) CPU N2800   [url=home.php?mod=space&uid=175]@[/url] 1.86GHz
  4. CPU cores  : 4 @ 889.364 MHz
  5. AES-NI     : ❌ Disabled
  6. VM-x/AMD-V : ❌ Disabled
  7. RAM        : 3.8 GiB
  8. Swap       : 512.0 MiB
  9. Disk       : 1.8 TiB
  10. fio Disk Speed Tests (Mixed R/W 50/50):
  11. ---------------------------------
  12. Block Size | 4k            (IOPS) | 64k           (IOPS)
  13.   ------   | ---            ----  | ----           ----
  14. Read       | 632.00 KB/s    (158) | 9.23 MB/s      (144)
  15. Write      | 663.00 KB/s    (165) | 9.73 MB/s      (152)
  16. Total      | 1.29 MB/s      (323) | 18.96 MB/s     (296)
  17.            |                      |
  18. Block Size | 512k          (IOPS) | 1m            (IOPS)
  19.   ------   | ---            ----  | ----           ----
  20. Read       | 36.28 MB/s      (70) | 51.29 MB/s      (50)
  21. Write      | 38.52 MB/s      (75) | 54.47 MB/s      (53)
  22. Total      | 74.81 MB/s     (145) | 105.77 MB/s    (103)
  23. iperf3 Network Speed Tests (IPv4):
  25. Provider        | Location (Link)           | Send Speed      | Recv Speed
  26.                 |                           |                 |
  27. Clouvider       | London, UK (10G)          | 94.0 Mbits/sec  | 94.1 Mbits/sec
  28. Online.net      | Paris, FR (10G)           | 94.1 Mbits/sec  | 93.9 Mbits/sec
  29. WorldStream     | The Netherlands (10G)     | 93.9 Mbits/sec  | 94.2 Mbits/sec
  30. WebHorizon      | Singapore (400M)          | 67.2 Mbits/sec  | 45.0 Mbits/sec
  31. Clouvider       | NYC, NY, US (10G)         | 91.8 Mbits/sec  | 92.4 Mbits/sec
  32. Velocity Online | Tallahassee, FL, US (10G) | 89.1 Mbits/sec  | 84.1 Mbits/sec
  33. Clouvider       | Los Angeles, CA, US (10G) | 88.9 Mbits/sec  | 89.6 Mbits/sec
  34. Iveloz Telecom  | Sao Paulo, BR (2G)        | 84.2 Mbits/sec  | 81.3 Mbits/sec
  35. iperf3 Network Speed Tests (IPv6):
  36. ---------------------------------
  37. Provider        | Location (Link)           | Send Speed      | Recv Speed
  38.                 |                           |                 |
  39. Clouvider       | London, UK (10G)          | 92.8 Mbits/sec  | 92.9 Mbits/sec
  40. Online.net      | Paris, FR (10G)           | 92.8 Mbits/sec  | 92.8 Mbits/sec
  41. WorldStream     | The Netherlands (10G)     | 92.6 Mbits/sec  | 92.8 Mbits/sec
  42. WebHorizon      | Singapore (400M)          | 80.0 Mbits/sec  | 34.6 Mbits/sec
  43. Clouvider       | NYC, NY, US (10G)         | 90.6 Mbits/sec  | 91.3 Mbits/sec
  44. Clouvider       | Los Angeles, CA, US (10G) | 87.8 Mbits/sec  | 88.3 Mbits/sec
  45. Geekbench 5 Benchmark Test:
  46. ---------------------------------
  47. Test            | Value
  48.                 |
  49. Single Core     | 111
  50. Multi Core      | 300
  51. Full Test       | https://browser.geekbench.com/v5/cpu/12086834
再来看一下硬盘通电时间:
  1. 9 Power_On_Hours          0x0012   091   091   000    Old_age   Always       -       64008
发表于 2022-1-10 15:08:40 | 只看该作者
6万4  比我还惨。不过我的ks-le也是6万多
发表于 2022-1-10 15:08:54 | 只看该作者
我11月24的ksle都还没开机了
发表于 2022-1-10 15:09:34 | 只看该作者
都是这个样的,我的也是6万多
发表于 2022-1-10 15:11:14 | 只看该作者
硬盘可以 我以为我5w+就够多了 还能开出6w+
发表于 2022-1-10 15:12:26 | 只看该作者
这io实属有点感人啊
 楼主| 发表于 2022-1-10 16:02:49 | 只看该作者
pxy185 发表于 2022-1-10 15:08
我11月24的ksle都还没开机了
这时间等的也太久了
发表于 2022-1-10 16:26:21 来自手机 | 只看该作者
我的4号的也开机了,然后居然不能访问NF!其他网站都可以正常访问…第一次碰到
 楼主| 发表于 2022-1-10 16:33:38 | 只看该作者
rayye 发表于 2022-1-10 16:26
我的4号的也开机了,然后居然不能访问NF!其他网站都可以正常访问…第一次碰到 ...
直接打不开?
发表于 2022-1-10 16:35:25 来自手机 | 只看该作者
zhaozs125 发表于 2022-1-10 16:33
直接打不开?
对直接打不开,其他fb 推特 有图比 各种网站均正常
GMT+8, 2026-4-23 08:06 , Processed in 0.066825 second(s), 10 queries , Gzip On, MemCache On.
