查看: 5131|回复: 13
hax.co.id免费vps装宝塔同时跑了下分,性能强悍,富强神器
发表于 2022-1-4 10:52:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
家里面是电信ipv6的网络,
开了个免费的中国优化洛杉矶,
延迟在170ms,
直接文件下载速度大概7-9M/s,
跑满服务器100m带宽
也可以直接测试下载速度
安装好宝塔跑了个分
跑分脚本跑分
  1. -------------------- A Bench.sh Script By Teddysun -------------------
  2. Intro              : https://teddysun.com/444.html
  3. Version            : v2022-01-01
  4. Usage              : wget -qO- bench.sh | bash
  5. ----------------------------------------------------------------------
  6. CPU Model          : Intel(R) Xeon(R) E-2276G CPU @ 3.80GHz
  7. CPU Cores          : 1
  8. CPU Frequency      : 4654.206 MHz
  9. CPU Cache          : 12288 KB
  10. Total Disk         : 3.9 GB (2.0 GB Used)
  11. Total Mem          : 500 MB (439 MB Used)
  12. Total Swap         : 256 MB (2 MB Used)
  13. System uptime      : 0 days, 0 hour 1 min
  14. Load average       : 68.63, 67.33, 62.28
  15. OS                 : Debian GNU/Linux 11
  16. Arch               : x86_64 (64 Bit)
  17. Kernel             : 4.18.0-348.7.1.el8_5.x86_64
  18. TCP CC             : bbr
  19. Virtualization     : LXC
  20. Organization       : AS29432 TREX Regional Exchanges Oy
  21. Location           : Tampere / FI
  22. Region             : Pirkanmaa
  23. ----------------------------------------------------------------------
  24. I/O Speed(1st run) : 828 MB/s
  25. I/O Speed(2nd run) : 518 MB/s
  26. I/O Speed(3rd run) : 874 MB/s
  27. I/O Speed(average) : 740.0 MB/s
  28. ----------------------------------------------------------------------
  29. Node Name        Upload Speed      Download Speed      Latency
  30. Speedtest.net    27.74 Mbps        51.03 Mbps          0.50 ms
  31. Montreal, CA     89.07 Mbps        12.48 Mbps          265.40 ms
  32. Paris, FR        98.12 Mbps        16.40 Mbps          137.63 ms
  33. Amsterdam, NL    84.44 Mbps        16.90 Mbps          188.62 ms
  34. Nanjing, CN      79.04 Mbps        11.95 Mbps          407.43 ms
  35. Hongkong, CN     79.10 Mbps        48.30 Mbps          385.93 ms
  36. Seoul, KR        66.70 Mbps        9.48 Mbps           404.48 ms
  37. Singapore, SG    67.55 Mbps        20.91 Mbps          515.97 ms
  38. Tokyo, JP        76.27 Mbps        11.96 Mbps          417.17 ms
  39. ----------------------------------------------------------------------
  40. Finished in        : 6 min 7 sec
  41. Timestamp          : 2022-01-04 02:53:32
  42. ----------------------------------------------------------------------
发表于 2022-1-4 10:54:31 | 只看该作者
能成负的  牛哇  现在还是7天一续期吗
 楼主| 发表于 2022-1-4 10:55:22 | 只看该作者
wushuiyin 发表于 2022-1-4 10:54
能成负的  牛哇  现在还是7天一续期吗
是的,其实硬盘还可以再挂上90G。。。。
发表于 2022-1-4 11:03:45 | 只看该作者
宝塔跑分图一乐 我北京248也14000分
发表于 2022-1-4 11:07:25 | 只看该作者
不可能把,我搞过这个,他有限速的呀
发表于 2022-1-4 11:09:03 | 只看该作者
7天一续期,比较麻烦些,我都已经放弃了
 楼主| 发表于 2022-1-4 11:09:21 | 只看该作者
cachexy 发表于 2022-1-4 11:07
不可能把,我搞过这个,他有限速的呀
你试试上面我放出那个下载链接,直接跑满
 楼主| 发表于 2022-1-4 11:27:51 | 只看该作者
aeo 发表于 2022-1-4 11:09
7天一续期,比较麻烦些,我都已经放弃了
https://xshe.org/100MB.test
下载速度还是可以的
发表于 2022-1-4 11:31:34 | 只看该作者
下载速度还是可以的
已经没位置了,遗憾
 楼主| 发表于 2022-1-4 11:32:10 | 只看该作者
cachexy 发表于 2022-1-4 11:31
已经没位置了,遗憾
那就换个地区,用印尼或者别的地区
GMT+8, 2026-4-20 18:17 , Processed in 0.063385 second(s), 10 queries , Gzip On, MemCache On.
