查看: 1785|回复: 4
HH瑞典2T开机,跑个测试
发表于 2021-12-31 22:49:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
小跑了一下。
  1. ----------------------------------------------------------------------
  2. CPU Model             : AMD EPYC 7551P 32-Core Processor
  3. CPU Cores             : 2
  4. CPU Frequency         : 1999.984 MHz
  5. CPU Cache             : 512 KB
  6. Total Disk            : 1945.6 GB (1.1 GB Used)
  7. Total Mem             : 1837 MB (125 MB Used)
  8. Total Swap            : 0 MB (0 MB Used)
  9. System uptime         : 0 days, 10 hour 4 min
  10. Load average          : 0.00, 0.01, 0.05
  11. OS                    : CentOS Linux release 7.9.2009 (Core)
  12. Arch                  : x86_64 (64 Bit)
  13. Kernel                : 3.10.0-1160.45.1.el7.x86_64
  14. TCP CC                : cubic
  15. Virtualization        : KVM
  16. Organization          : AS63473 HostHatch, LLC
  17. Location              : Stockholm / SE
  18. Region                : Stockholm
  19. ----------------------------------------------------------------------
  20. I/O Speed(1st run)    : 1.4 GB/s
  21. I/O Speed(2nd run)    : 1.6 GB/s
  22. I/O Speed(3rd run)    : 1.5 GB/s
  23. Average I/O speed     : 1536.0 MB/s
  24. ----------------------------------------------------------------------
  25. Node Name        Upload Speed      Download Speed      Latency
  26. Speedtest.net    940.62 Mbps       934.21 Mbps         0.28 ms
  27. Shanghai   CU    72.60 Mbps        3829.61 Mbps        180.67 ms
  28. Guangzhou  CT    2.81 Mbps         958.30 Mbps         222.16 ms
  29. Hongkong   CN    346.66 Mbps       3826.81 Mbps        208.60 ms
  30. Tokyo      JP    181.41 Mbps       1586.50 Mbps        254.60 ms
  31. ----------------------------------------------------------------------
  32. [root@3g ~]# curl -sL yabs.sh | bash
  33. # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## #
  34. #              Yet-Another-Bench-Script              #
  35. #                     v2021-12-28                    #
  36. # https://github.com/masonr/yet-another-bench-script #
  37. # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## #
  38. Fri Dec 31 14:27:44 UTC 2021
  39. Basic System Information:
  40. ---------------------------------
  41. Processor  : AMD EPYC 7551P 32-Core Processor
  42. CPU cores  : 2 [url=home.php?mod=space&uid=175]@[/url] 1999.984 MHz
  43. AES-NI     : ✔ Enabled
  44. VM-x/AMD-V : ✔ Enabled
  45. RAM        : 1.8 GiB
  46. Swap       : 0.0 KiB
  47. Disk       : 1.8 TiB
  48. fio Disk Speed Tests (Mixed R/W 50/50):
  49. ---------------------------------
  50. Block Size | 4k            (IOPS) | 64k           (IOPS)
  51.   ------   | ---            ----  | ----           ----
  52. Read       | 7.94 MB/s     (1.9k) | 79.46 MB/s    (1.2k)
  53. Write      | 7.98 MB/s     (1.9k) | 79.88 MB/s    (1.2k)
  54. Total      | 15.92 MB/s    (3.9k) | 159.35 MB/s   (2.4k)
  55.            |                      |
  56. Block Size | 512k          (IOPS) | 1m            (IOPS)
  57.   ------   | ---            ----  | ----           ----
  58. Read       | 222.77 MB/s    (435) | 410.67 MB/s    (401)
  59. Write      | 234.61 MB/s    (458) | 438.02 MB/s    (427)
  60. Total      | 457.39 MB/s    (893) | 848.70 MB/s    (828)
  61. iperf3 Network Speed Tests (IPv4):
  62. ---------------------------------
  63. Provider        | Location (Link)           | Send Speed      | Recv Speed
  64.                 |                           |                 |
  65. Clouvider       | London, UK (10G)          | 1.16 Gbits/sec  | 5.24 Gbits/sec
  66. Online.net      | Paris, FR (10G)           | 3.85 Gbits/sec  | 2.54 Gbits/sec
  67. WorldStream     | The Netherlands (10G)     | 2.50 Gbits/sec  | busy
  68. WebHorizon      | Singapore (400M)          | 226 Mbits/sec   | 168 Mbits/sec
  69. Clouvider       | NYC, NY, US (10G)         | 634 Mbits/sec   | 1.95 Gbits/sec
  70. Velocity Online | Tallahassee, FL, US (10G) | 855 Mbits/sec   | 308 Mbits/sec
  71. Clouvider       | Los Angeles, CA, US (10G) | 549 Mbits/sec   | 1.05 Gbits/sec
  72. Iveloz Telecom  | Sao Paulo, BR (2G)        | 113 Mbits/sec   | 703 Mbits/sec
  73. Geekbench 5 Benchmark Test:
  74. ---------------------------------
  75. Test            | Value
  76.                 |
  77. Single Core     | 671
  78. Multi Core      | 1261
发表于 2021-12-31 22:50:37 | 只看该作者
这大盘鸡真不错,口水啊
发表于 2021-12-31 23:11:21 | 只看该作者
CPU还是锁的死死的。这大盘鸡没 2C 估计用起来都蛋疼。
 楼主| 发表于 2022-1-1 22:54:44 | 只看该作者
今天开BBR又试了一下,不得不说,BBR果然是神器。
  1. CPU Model          : AMD EPYC 7551P 32-Core Processor
  2. CPU Cores          : 2
  3. CPU Frequency      : 1999.984 MHz
  4. CPU Cache          : 512 KB
  5. Total Disk         : 1946.6 GB (7.4 GB Used)
  6. Total Mem          : 1985 MB (810 MB Used)
  7. Total Swap         : 507 MB (10 MB Used)
  8. System uptime      : 0 days, 0 hour 12 min
  9. Load average       : 0.46, 0.47, 0.24
  10. OS                 : CentOS Linux release 7.9.2009 (Core)
  11. Arch               : x86_64 (64 Bit)
  12. Kernel             : 5.15.12
  13. TCP CC             : bbr
  14. Virtualization     : KVM
  15. Organization       : AS63473 HostHatch, LLC
  16. Location           : Stockholm / SE
  17. Region             : Stockholm
  18. ----------------------------------------------------------------------
  19. I/O Speed(1st run) : 1.8 GB/s
  20. I/O Speed(2nd run) : 1.7 GB/s
  21. I/O Speed(3rd run) : 1.9 GB/s
  22. I/O Speed(average) : 1843.2 MB/s
  23. ----------------------------------------------------------------------
  24. Node Name        Upload Speed      Download Speed      Latency
  25. Speedtest.net    907.11 Mbps       814.74 Mbps         0.28 ms
  26. Los Angeles, US  519.66 Mbps       2930.25 Mbps        155.78 ms
  27. Dallas, US       644.31 Mbps       3718.91 Mbps        127.18 ms
  28. Montreal, CA     640.28 Mbps       939.54 Mbps         98.62 ms
  29. Paris, FR        2677.01 Mbps      5204.41 Mbps        31.40 ms
  30. Amsterdam, NL    3644.74 Mbps      4910.67 Mbps        19.91 ms
  31. Shanghai, CN     259.30 Mbps       3150.40 Mbps        190.21 ms
  32. Nanjing, CN      362.00 Mbps       3419.36 Mbps        227.73 ms
  33. Hongkong, CN     387.27 Mbps       3807.23 Mbps        208.57 ms
  34. Seoul, KR        264.06 Mbps       678.66 Mbps         275.10 ms
  35. Singapore, SG    229.23 Mbps       2208.26 Mbps        326.82 ms
  36. Tokyo, JP        165.87 Mbps       1577.46 Mbps        242.19 ms
  37. ----------------------------------------------------------------------
  38. Finished in        : 6 min 6 sec
  39. Timestamp          : 2022-01-01 22:52:02
  40. 2022年 01月 01日 星期六 22:37:26 CST
  41. Basic System Information:
  43. Processor  : AMD EPYC 7551P 32-Core Processor
  44. CPU cores  : 2 [url=home.php?mod=space&uid=175]@[/url] 1999.984 MHz
  45. AES-NI     : ✔ Enabled
  46. VM-x/AMD-V : ✔ Enabled
  47. RAM        : 1.9 GiB
  48. Swap       : 508.0 MiB
  49. Disk       : 1.8 TiB
  50. fio Disk Speed Tests (Mixed R/W 50/50):
  51. ---------------------------------
  52. Block Size | 4k            (IOPS) | 64k           (IOPS)
  53.   ------   | ---            ----  | ----           ----
  54. Read       | 5.28 MB/s     (1.3k) | 49.76 MB/s     (777)
  55. Write      | 5.30 MB/s     (1.3k) | 50.11 MB/s     (782)
  56. Total      | 10.58 MB/s    (2.6k) | 99.88 MB/s    (1.5k)
  57.            |                      |
  58. Block Size | 512k          (IOPS) | 1m            (IOPS)
  59.   ------   | ---            ----  | ----           ----
  60. Read       | 178.13 MB/s    (347) | 258.51 MB/s    (252)
  61. Write      | 187.60 MB/s    (366) | 275.72 MB/s    (269)
  62. Total      | 365.73 MB/s    (713) | 534.23 MB/s    (521)
  63. iperf3 Network Speed Tests (IPv4):
  64. ---------------------------------
  65. Provider        | Location (Link)           | Send Speed      | Recv Speed
  66.                 |                           |                 |
  67. Clouvider       | London, UK (10G)          | 6.00 Gbits/sec  | 4.94 Gbits/sec
  68. Online.net      | Paris, FR (10G)           | 5.97 Gbits/sec  | 1.99 Gbits/sec
  69. WorldStream     | The Netherlands (10G)     | 7.35 Gbits/sec  | 1.28 Gbits/sec
  70. WebHorizon      | Singapore (400M)          | 271 Mbits/sec   | 282 Mbits/sec
  71. Clouvider       | NYC, NY, US (10G)         | 1.72 Gbits/sec  | 1.93 Gbits/sec
  72. Velocity Online | Tallahassee, FL, US (10G) | 1.52 Gbits/sec  | 1.39 Gbits/sec
  73. Clouvider       | Los Angeles, CA, US (10G) | 912 Mbits/sec   | 1.05 Gbits/sec
  74. Iveloz Telecom  | Sao Paulo, BR (2G)        | 667 Mbits/sec   | 707 Mbits/sec
  75. Geekbench 5 Benchmark Test:
  76. ---------------------------------
  77. Test            | Value
  78.                 |
  79. Single Core     | 633
  80. Multi Core      | 1271
发表于 2022-1-3 17:49:25 | 只看该作者
这cpu真垃圾,快赶上三毛了
八周年瑞典好歹还800分
GMT+8, 2026-4-24 02:38 , Processed in 0.060807 second(s), 10 queries , Gzip On, MemCache On.
