查看: 3369|回复: 10
绿云香港25刀3年付开机
发表于 2021-12-23 13:25:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
yabs
  1. Basic System Information:
  3. Processor  : AMD Ryzen Threadripper 3960X 24-Core Processor
  4. CPU cores  : 1 [url=home.php?mod=space&uid=175]@[/url] 3799.956 MHz
  5. AES-NI     : ✔ Enabled
  6. VM-x/AMD-V : ✔ Enabled
  7. RAM        : 1.8 GiB
  8. Swap       : 2.0 GiB
  9. Disk       : 47.2 GiB
  10. fio Disk Speed Tests (Mixed R/W 50/50):
  11. ---------------------------------
  12. Block Size | 4k            (IOPS) | 64k           (IOPS)
  13.   ------   | ---            ----  | ----           ----
  14. Read       | 124.98 MB/s  (31.2k) | 1.75 GB/s    (27.3k)
  15. Write      | 125.31 MB/s  (31.3k) | 1.76 GB/s    (27.5k)
  16. Total      | 250.30 MB/s  (62.5k) | 3.51 GB/s    (54.9k)
  17.            |                      |
  18. Block Size | 512k          (IOPS) | 1m            (IOPS)
  19.   ------   | ---            ----  | ----           ----
  20. Read       | 2.34 GB/s     (4.5k) | 2.47 GB/s     (2.4k)
  21. Write      | 2.47 GB/s     (4.8k) | 2.63 GB/s     (2.5k)
  22. Total      | 4.81 GB/s     (9.4k) | 5.11 GB/s     (4.9k)
  23. iperf3 Network Speed Tests (IPv4):
  25. Provider        | Location (Link)           | Send Speed      | Recv Speed
  26.                 |                           |                 |
  27. Clouvider       | London, UK (10G)          | 494 Mbits/sec   | 759 Mbits/sec
  28. Online.net      | Paris, FR (10G)           | 886 Mbits/sec   | busy
  29. WorldStream     | The Netherlands (10G)     | busy            | 819 Mbits/sec
  30. WebHorizon      | Singapore (1G)            | 79.1 Mbits/sec  | busy
  31. Clouvider       | NYC, NY, US (10G)         | 547 Mbits/sec   | 638 Mbits/sec
  32. Velocity Online | Tallahassee, FL, US (10G) | 27.6 Mbits/sec  | 841 Mbits/sec
  33. Clouvider       | Los Angeles, CA, US (10G) | 517 Mbits/sec   | 999 Mbits/sec
  34. Iveloz Telecom  | Sao Paulo, BR (2G)        | 61.4 Mbits/sec  | 492 Mbits/sec
  35. Geekbench 5 Benchmark Test:
  36. ---------------------------------
  37. Test            | Value                                         |
  38. Single Core     | 1157
  39. Multi Core      | 1145
  40. Full Test       | https://browser.geekbench.com/v5/cpu/11762252
流媒体解锁
  1. ============[ Multination ]============
  2. Dazn:                                  No
  3. HotStar:                               No
  4. Disney+:                               No
  5. Netflix:                               Yes (Region: HK)
  6. 有图比 Premium:                       Yes (Region: HK)
  7. Amazon Prime Video:                    Yes (Region: HK)
  8. TVBAnywhere+:                          No
  9. Tiktok Region:                         US
  10. iQyi Oversea Region:                   HK
  11. Viu.com:                               Yes (Region: HK)
  12. 有图比 CDN:                           Hong Kong
  13. Netflix Preferred CDN:                 Hong Kong
  14. Steam Currency:                        HKD
  15. =======================================
  16. =============[ Hong Kong ]=============
  17. Now E:                                 No
  18. Viu.TV:                                No
  19. MyTVSuper:                             No
  20. HBO GO Asia:                           Yes (Region: HK)
  21. BiliBili Hongkong/Macau/Taiwan:        Yes
  22. =======================================
Superbench
  1. Superbench.sh -- https://www.oldking.net/350.html
  2. Mode  : Standard    Version : 1.1.7
  3. Usage : wget -qO- sb.oldking.net | bash
  4. ----------------------------------------------------------------------
  5. CPU Model            : AMD Ryzen Threadripper 3960X 24-Core Processor
  6. CPU Cores            : 1 Cores 3799.956 MHz x86_64
  7. CPU Cache            : 512 KB
  8. OS                   : CentOS 7.9.2009 (64 Bit) KVM
  9. Kernel               : 3.10.0-693.11.6.el7.x86_64
  10. Total Space          : 1.9 GB / 48.0 GB
  11. Total RAM            : 119 MB / 1839 MB (541 MB Buff)
  12. Total SWAP           : 0 MB / 2047 MB
  13. Uptime               : 0 days 0 hour 49 min
  14. Load Average         : 0.17, 0.10, 0.13
  15. TCP CC               : cubic
  16. ASN & ISP            : AS133752, 365 Group LLC
  17. Organization         : 365 Group LLC
  18. Location             : Central, Hong Kong / HK
  19. Region               : Central and Western District
  20. ----------------------------------------------------------------------
  21. I/O Speed( 1.0GB )   : 1.9 GB/s
  22. I/O Speed( 1.0GB )   : 1.9 GB/s
  23. I/O Speed( 1.0GB )   : 1.9 GB/s
  24. Average I/O Speed    : 1945.6 MB/s
  25. ----------------------------------------------------------------------
  26. Node Name        Upload Speed      Download Speed      Latency
  27. Speedtest.net    121.14 Mbit/s     3323.45 Mbit/s      (*)181.60 ms
  28. Fast.com         0.00 Mbit/s       208.3 Mbit/s        -
  29. Nanjing 5G   CT  250.31 Mbit/s     1200.02 Mbit/s      281.98 ms
  30. Hefei 5G     CT  132.82 Mbit/s     1194.60 Mbit/s      296.32 ms
  31. Guangzhou 5G CT  21.54 Mbit/s      288.98 Mbit/s       305.26 ms
  32. TianJin 5G   CU  374.19 Mbit/s     1164.45 Mbit/s      211.54 ms
  33. Shanghai 5G  CU  40.77 Mbit/s      1363.07 Mbit/s      307.37 ms
  34. Wuxi 5G      CM  299.30 Mbit/s     2095.53 Mbit/s      267.89 ms
  35. Nanjing 5G   CM  64.84 Mbit/s      461.57 Mbit/s       274.95 ms
  36. Hefei 5G     CM  930.12 Mbit/s     61.87 Mbit/s        74.65 ms
  37. ----------------------------------------------------------------------
  38. Finished in  : 5 min 27 sec
  39. Timestamp    : 2021-12-23 13:27:14 GMT+8
  40. Results      : ./superbench.log
  41. ----------------------------------------------------------------------
  42. Share result:
  43. · https://www.speedtest.net/result/c/0b7b8db4-1e71-45d8-b601-5d7a7e9617e0
  44. · https://paste.ubuntu.com/p/GXt2rhDpqt/
  45. ----------------------------------------------------------------------
来自 8#
 楼主| 发表于 2021-12-23 14:05:04 | 只看该作者
绿云香港(Pre-order)Ryzen10GbpsHK-2三网测试https://loc.qiche.eu.org/thread-944787-1-1.html
发表于 2021-12-23 13:27:28 | 只看该作者
这I/O也好恐怖,可惜D+不解锁
发表于 2021-12-23 13:27:45 来自手机 | 只看该作者
发表于 2021-12-23 13:45:16 | 只看该作者
25刀3年,这配置爽歪歪。
发表于 2021-12-23 13:49:30 | 只看该作者
hchen 发表于 2021-12-23 13:45
25刀3年,这配置爽歪歪。
是一年25刀付了3年
发表于 2021-12-23 13:56:19 | 只看该作者
老哥,你是啥ip段,合肥居然不绕
 楼主| 发表于 2021-12-23 14:10:56 | 只看该作者
langer 发表于 2021-12-23 13:56
老哥,你是啥ip段,合肥居然不绕
85.113.71.x
发表于 2021-12-23 14:41:56 来自手机 | 只看该作者
广州离香港那么近还要绕一大圈
GMT+8, 2026-4-27 20:26 , Processed in 0.073814 second(s), 12 queries , Gzip On, MemCache On.
