查看: 2982|回复: 24
HH黑五瑞典NVMe已开机
发表于 2021-12-19 19:43:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
刚才邮件推送,新机器已部署,账单日从2022年1月1日开始计算
Your billing date will also start from 1st January 2022 instead of today. Please do note that you can still fully use your server right away and there will be no reinstalls required to enable the above features.
跑分评测
  3. #                     v2021-12-03                    #
  6. Sun Dec 19 11:20:14 UTC 2021
  7. Basic System Information:
  9. Processor  : AMD EPYC 7443P 24-Core Processor
  10. CPU cores  : 4 [url=home.php?mod=space&uid=175]@[/url] 2844.654 MHz
  11. AES-NI     : ✔ Enabled
  12. VM-x/AMD-V : ✔ Enabled
  13. RAM        : 15.3 GiB
  14. Swap       : 0.0 KiB
  15. Disk       : 99.9 GiB
  16. fio Disk Speed Tests (Mixed R/W 50/50):
  17. ---------------------------------
  18. Block Size | 4k            (IOPS) | 64k           (IOPS)
  19.   ------   | ---            ----  | ----           ----
  20. Read       | 310.46 MB/s  (77.6k) | 2.87 GB/s    (44.9k)
  21. Write      | 311.28 MB/s  (77.8k) | 2.89 GB/s    (45.1k)
  22. Total      | 621.74 MB/s (155.4k) | 5.76 GB/s    (90.1k)
  23.            |                      |
  24. Block Size | 512k          (IOPS) | 1m            (IOPS)
  25.   ------   | ---            ----  | ----           ----
  26. Read       | 3.33 GB/s     (6.5k) | 3.59 GB/s     (3.5k)
  27. Write      | 3.50 GB/s     (6.8k) | 3.83 GB/s     (3.7k)
  28. Total      | 6.84 GB/s    (13.3k) | 7.42 GB/s     (7.2k)
  29. iperf3 Network Speed Tests (IPv4):
  30. ---------------------------------
  31. Provider        | Location (Link)           | Send Speed      | Recv Speed
  32.                 |                           |                 |
  33. Clouvider       | London, UK (10G)          | 1.75 Gbits/sec  | 6.64 Gbits/sec
  34. Online.net      | Paris, FR (10G)           | 3.03 Gbits/sec  | 2.11 Gbits/sec
  35. WorldStream     | The Netherlands (10G)     | busy            | 1.56 Gbits/sec
  36. WebHorizon      | Singapore (1G)            | 97.0 Mbits/sec  | 321 Mbits/sec
  37. Clouvider       | NYC, NY, US (10G)         | 661 Mbits/sec   | 1.42 Gbits/sec
  38. Velocity Online | Tallahassee, FL, US (10G) | 967 Mbits/sec   | 1.39 Gbits/sec
  39. Clouvider       | Los Angeles, CA, US (10G) | 773 Mbits/sec   | 1.06 Gbits/sec
  40. Iveloz Telecom  | Sao Paulo, BR (2G)        | 72.0 Mbits/sec  | 690 Mbits/sec
  41. Geekbench 5 Benchmark Test:
  43. Test            | Value
  44.                 |
  45. Single Core     | 1243
  46. Multi Core      | 4878
  47. Full Test       | https://browser.geekbench.com/v5/cpu/11693804
  1. ----------------------------------------------------------------------
  2. CPU Model             : AMD EPYC 7443P 24-Core Processor
  3. CPU Cores             : 4
  4. CPU Frequency         : 2844.654 MHz
  5. CPU Cache             : 512 KB
  6. Total Disk            : 100.1 GB (2.5 GB Used)
  7. Total Mem             : 15664 MB (105 MB Used)
  8. Total Swap            : 0 MB (0 MB Used)
  9. System uptime         : 0 days, 0 hour 17 min
  10. Load average          : 0.01, 0.18, 0.12
  11. OS                    : Debian GNU/Linux 10
  12. Arch                  : x86_64 (64 Bit)
  13. Kernel                : 4.19.0-18-amd64
  14. TCP CC                : cubic
  15. Virtualization        : KVM
  16. Organization          : AS63473 HostHatch, LLC
  17. Location              : Stockholm / SE
  18. Region                : Stockholm
  19. ----------------------------------------------------------------------
  20. I/O Speed(1st run)    : 1.4 GB/s
  21. I/O Speed(2nd run)    : 1.4 GB/s
  22. I/O Speed(3rd run)    : 1.4 GB/s
  23. Average I/O speed     : 1433.6 MB/s
  24. ----------------------------------------------------------------------
  25. Node Name        Upload Speed      Download Speed      Latency
  26. Speedtest.net    8047.44 Mbps      8936.10 Mbps        1.04 ms
  27. Shanghai   CT    1.34 Mbps         3142.18 Mbps        233.06 ms
  28. Shanghai   CU    145.86 Mbps       4030.69 Mbps        204.65 ms
  29. Guangzhou  CT    154.18 Mbps       1357.57 Mbps        212.59 ms
  30. Hongkong   CN    279.82 Mbps       3660.15 Mbps        218.36 ms
  31. Tokyo      JP    185.03 Mbps       1514.68 Mbps        247.66 ms
  32. ----------------------------------------------------------------------
发表于 2021-12-19 20:10:23 | 只看该作者
Mio 发表于 2021-12-19 20:04
100多刀一年还是略贵。。
4 CPU cores
16 GB RAM
100 GB NVMe storage
一年115//一个月就10刀。。
10刀这配置,难找
发表于 2021-12-19 19:56:50 | 只看该作者
多良心的商家
* 微笑吧,为你的曾经拥有。
发表于 2021-12-19 19:44:16 | 只看该作者
参考一下
发表于 2021-12-19 19:44:28 | 只看该作者
我看了下大盘鸡还没开
发表于 2021-12-19 19:44:41 来自手机 | 只看该作者
大盘鸡开了吗 卧槽
发表于 2021-12-19 19:44:51 | 只看该作者
我的天终于开机~~~
 楼主| 发表于 2021-12-19 19:44:52 | 只看该作者
刚开机用的人少,所以网速和CPU跑分会高一些,等稳定了估计就低了
发表于 2021-12-19 19:45:23 | 只看该作者
发表于 2021-12-19 19:45:46 | 只看该作者
要是之后还是这么高的cpu那可就太香了哈哈哈哈
有点东西噢
发表于 2021-12-19 19:45:53 | 只看该作者
大盘鸡还没开,香港也没开
GMT+8, 2026-4-23 19:50 , Processed in 0.073672 second(s), 11 queries , Gzip On, MemCache On.
